My dishwasher is stuck on SMART AUTO and does nothing. Have already reset it. This is the 3rd different issue with this thing and only bought it in Jan. Piece of JUNK
JDeRuvo
  • 48 Answers
SOURCE: A piece of junk dvd player I just bought
Here's the support site with contact information. When you say it "quit working," how so? Does it spin up/power up? Are you having trouble playing DVDs? What model? It'll help to troubleshoot if you can give us more details.
Posted on Dec 01, 2007
Geekman
  • 32281 Answers
SOURCE: keyboard key issue in laptop
The metal bar needs to be clipped on to the plastic shift key. Look under the plastic shift key and you can see recess where the metal bar fits. Place the shift key over these recess and push down until it clicks into place.
Posted on Jun 13, 2008
  • 109 Answers
SOURCE: put a 727 in place of current piece of junk
you cannot put a 727 trans in place of a a518 trans, will not function due to electronics of gov and o/d, as well as fitting in place, from the looks of your truck is 4x4, repair your a518 trans, les headache in the long run and convent of o/d. have a shift kit put in or modify vavle body for better shifts and cooler flow, power reverse flush your cooler, GOOD LUCK RDJRP
Posted on Aug 03, 2009
SOURCE: my smart car has 2 different chassis numbers 1
You have to contact the Smart dealer in your area , so that they can rectify the problem , as Chassis number is saved into the ECU too and can be extracted from the car ECU it self to show the original chassis number, assuming it has the original ECU in it. Or you can check with any shop that aervice Smart for the same. By the way before you do that, which VIN does not match , the sticker in the back or the engraved one in the front??
Posted on Oct 22, 2009
  • 1564 Answers
SOURCE: Every time I use my New Hoover steam vac it leaks all the time I've tried every thing, I even bought a new tank same problem, I'm not taking it to be repaired its the 3rd one thats done it an
After the second time I would have asked for a refund. Maybe you need to do some diagnostic work.
1. Does it leak while sitting unplugged?
2. Does it leak while plugged in but not being operated?
3 Does it leak when the solution is above or below a certain level.
4. Are you over filling it?
5. Does it leak only when you pull the trigger? (valve problem)
Keep asking yourself questions to discover where and why it's leaking.
Good luck.
Posted on Nov 13, 2012
2007 Lexus IS 250 stuck in 3rd gear
That code has zero to do with the transmission issue. You have a mechanical failure in the tranny most likely, but have the TCM module scanned first before doing any parts replacement. P0171 is most likely an O2 sensor issue, it is indicating lean fuel.
Sep 13, 2016 | 2007 Lexus IS 250
Tip
Thank God for smart people and information on the internet!!! We just moved into...
The blinking "clean light" is a common problem with some of the Kenmore and Whirlpool models dishwashers. The problem is usually attributed to water supply temperatures being too low when filling. Apparently, there are some issues with the temperature sensing circuits in some dishwashers that causes an error code to be generated if a certain water temperature is not achieved in a specified time interval (this time may differ between models). There is a reset sequence that you can try to clear the fault. Push the NORMAL WASH then HEATED DRY buttons in that sequence two to three times. The unit will enter diagnostics mode, but can be stopped by pressing the CANCEL button. This will clear any existing faults and should return the dishwasher to normal operation.
To keep the fault from returning, it is recommended that you run your hot water faucet in the kitchen until it runs hot BEFORE you start the dishwasher. This will heat the water in the supply line for the dishwasher (most dishwashers are fed from the kitchen sink supply line). The theory is that if you fill the dishwasher with hot water from the start of the wash cycle instead of the cool water that is normally in the lines (especially if you have a hot water tank located far away from the kitchen), this should satisfy the requirements of the temperature sensing circuits. If the fault reappears, there should be a tech sheet located inside the lower panel under the door that explains what the fault is. The flashing light will be a series of flashes, followed by a pause. If you indeed have a component problem, it will depend on the number of flashing lights in the sequence. Refer to the tech sheet to determine WHAT component is affected and how to troubleshoot.
on Oct 06, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Samsung dishwasher fills and drains repeatedly
I would check the drain itself. Make sure there aren't any eating utensils getting caught in the drain area.
Jun 01, 2015 | Samsung Dishwashers
My scale is not measure correct results. Already tried resetting, replacing batteries, etc. Nothing seems to work. Please help!!
Your body composition can change throughout the day reading differently in these types of scales. Eating, working out, or different times of the day will all change your results. Try using it in the morning only and on an empty stomach.
Jun 22, 2014 | Withings WS-50 Smart Body Analyzer - Black...
Dishwasher not running through entire wash cycle
If I understand right, you saying no/little water is entering the washer?
First, look for the float switch valve.
Here's an example of what you're looking for:
http://appliancejunk.com/forums/gallery/1_12_08_07_8_34_08.jpg
It's the item in the lower right, with the spoon stuck under it.
If this float is stuck/hung-up in the UP position, it won't allow water to flow, as it senses that the water level is already at maximum.
Try to lift yours and see if it freely drops back down on it's own.
Sometimes they get gummed up and stick, or get pulled up and tilted a little, or have something (like a spoon) stuck under them.
Nov 21, 2013 | Asko 24 in. 1585 Built-in Dishwasher
Low water level
I have a Samsung DMT400RHS and I started getting the low water level error ('Normal'+Heavy'+Smart Auto' LED blinking). The error started intermittently a few weeks ago, but the the last day or two the problem was solid, and simply restarting the cycle no longer worked.
I looked of the code in the dishwasher user guide and it said 'low water level.' Searched the internet and located the repair manual at tradebit.com for $15. The manual was well worth the $15.
The manual suggested: 1) loose level sensor connector 2) Faulty Assy case sensor or stuck floater aka 'remove foreign matter' 3) Bad Main PBA assy.
Since we do 10+ loads a week for the last 18 months the stuck floater seemed to be the most likely cause.
Go to Samsung DMT400RHS Low Water Level Error ('Normal'+Heavy'+Smart Auto' LED) (new link is https://photos.google.com/album/AF1QipNtp1neOR7icVG8cSs71bLpxQD5k_xljiWcJD2P click the i on each picture to see the caption - DM 04/17/2016) to see the pictures and read the captions documenting what I did. Do this at your own risk. You must turn off and disconnect the electric power and turn off the water supply before you begin.
Jul 24, 2013 | Samsung DMT400RHS Builtin Dishwasher
I am recieving an SE code on my samsung dishwasher. I tried to reset the dishwasher by switching off the power to the machine for 20 minutes. still SE message
I'm getting the same message too. I turned it off for awhile and I had a technician come out and take a look. My drainage pipes are all clear (SE code can mean that drainage is not working properly). He suggested that I get a "Samsung" tech out to take a look at the circuit board/electrical issue. Want to know the crazy thing? This is my second dishwasher that Samsung replaced....all the same electrical issue.....and just last week someone called me to see if I wanted to buy an extended warranty on it. Hmmmm.....do they know that this a piece of junk? It was an expensive dishwasher too.....doesnt clean any better than my cheap model did and it sure has a lot more problems in this first year than the whole 5 years that I had my other dishwasher. Can you tell im disgruntled?
I would love to hear if there is a simple fix to this SE problem.
Sep 25, 2010 | Samsung 24 in. DB5710DT Stainless Steel...
Whirlpool Dishwasher GU15ooXTLT3
one of 2 things, either you have a bad door switch/latch assy and its not recognizing the door closing, or up have a "stuck keypad" preventing proper operation in which case youll need to replace the keypad/console. if you remove the lower acess panel there is a "tech sheet" explaining different faults and checks for your issue
Oct 26, 2008 | Whirlpool 24 in. ADP5966 Free-standing...
Dell 1720dn Error and Toner light on
After replacing the drum unit you have to tell the printer that you've done it(it's not smart enough to figure it out itself). Have the front door open and press and hold the Cancel button on the printer until all lights flash in sequence then let go. Then close door and try.
Apr 09, 2008 | Dell 1720dn Laser Printer
Fisher and Paykel dishwasher double drawer problem
Hi there FM, Your Dishdrawer is it intergated or does it have a factory finish on it? This will help me ask the next question? Kind Regards Carmen
Aug 08, 2007 | Fisher and Paykel 23 in. DD-603SS Built-in...
573 people viewed this question
 Grubhead
Grubhead
