Question about GE (PSS26MSRSS) Side by Side Refrigerator
Ge side by side not cooling
I think i need a new defrost timer...how can i test that and where is it??
  • bzfthv Nov 22, 2007
    I also have similiar issue.. It is a GE Model ESS25XGMC BB.. There is ice built up on the coils.. Not sure if it is an issue with defrost or something else.. Also found something for this model with a known issue for mostuire issues not sure if related..
  • 473 Answers
What is the complete model # from the sticker inside the fridge section?
Posted on Nov 11, 2007
The engine is still running, but the frig is warm a friend turned the timer and the freezer is freezing now, but the frig is still warm. Do I need a new timer?
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Aug 24, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Profile PSC25SGSA Side by side refrigerator No defrost cycle for coils in bottom of fridge side. Completely ices over every 5-7 days and a hairdryer plays the role of defroster. No problem with...
The defrost timer is usually found behind the front grill "toe kick" of the refrigerator. It may also be found behind a cover plate inside the refrigerator or freezer, in the temperature control console, or behind the refrigerator near the compressor.
To test whether the defrost timer is simply failing to advance, locate the advance screw and turn it clockwise until you hear it click. This advances it to the next mode. If it was cooling before, it is now in defrost mode. Simply wait about 35 minutes and check whether it has left defrost mode and has resumed cooling (listen for the compressor). If it does not advance, the timer motor is probably bad and the entire timer needs to be replaced. If it advances as it should, then you can follow the steps below to test the switch electrically.
The timer is usually held in place with one or more screws. Remove the screws and gently pull the timer out far enough to disconnect the wiring connector. The connector can be removed by firmly pulling and rocking it left and right. It is not necessary to note the position of the wires because the connector plug is keyed so that it can be replaced in only one way.
Oct 10, 2009 | GE PSC25PSS Side by Side Refrigerator
GE side by side. The freezer will freeze up with
Replace the defrost heater, located at the bottom of the cooling coils, behind the back wall of the freezer.
Aug 04, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Model TFX20D not cooling!
Hi, If the defrost heater doesn't come on, check continuity on the bi-metal swtch located on the top of the evaporator coil. The bi-metal needs to be cold when testing it. If the switch is cold and shows an open circuit, it will need replaced. The bi-metal switch is a thermostat that turns the defrost heaters off when the desired tempurature is reached,.
Please let me know if this has helped you at all or if I can assist you further.
Thanks
Vic
Jul 24, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Where is the defrost timer located on ge side bty side model gss25jfmdww
Hi, This model has a mother board instead of a defrost timer. If you are having a defrost issue, the first part you want to test is the defrost heaters. If you need instruction on testing the defrost cycle, please let me know so I can assist you further.
Thanks
Vic
Jul 15, 2009 | GE GSS25JFM Side by Side Refrigerator
Freezer is not keeping cold and forming icicles along wall
It may just be a defrost timer. Search online for information. There is plenty to be had. Check with the website of GE for a parts breakdown or your manual if you still have it for the location of the defrost timer. You can turn it manually so it goes into defrost. Does the unit seem to be running all the time and never shuts off? If so that timer could be stuck in the cool mode and the evaporator is freezing up solid so air wont flow over it to properly cool. I've had two refrigerators I've had to repair that had defrost timer problems. One stuck in the defrost cycle and wouldn't turn on to cool, the other did what you are describing. It stuck in the cool cycle and wouldn't defrost you may need to manually bypass the cooling cycle several times to allow it to completely defrost. Usually it cycles in cool from 6,8 or ten hours and only stays in defrost for over twenty minutes. That should defrost it and allow it to start cooling again. If you notice that frost has disappeared inside on the wall replace the timer.
May 22, 2009 | GE Monogram Side by Side Refrigerator
My model no is GE HSS25GFPJ ALL OF SUDDEN STOP COOLING
If you open the refrig door and the light comes on you have power.
Most likely the defrost timer has stopped working.
The timer is often located inside the refrigerator part of the unit, or under the remove-able face on the bottom of the frig.
You can manually advance the timer with a screw driver or a coin. The place that you advance the timer is a round object in the middle of the face of the timer. You must rotate this part of the timer. The design is such that you can only rotate the timer in one direction.
If you rotate this and the compressor motor begin to work then you can be sure the problem is the timer motor. Sometimes the wire breaks off the contacts that run the little motor inside the timer.
You can buy a new one and replace this quickly.
Do replace the timer if rotating the compressor starts. Rotating the timer is not a fix, it is only a test. The timer is designed to defrost the refrig Failure to have a defrost cycle is bad.
Jun 22, 2008 | GE GSS25JFPCC / GSS25JFPWW Side by Side...
GE Profile SxS Refrigerator wont defrost after new heaters installed
The answer to your last question would be yes. You can test for voltage at the harness where you plugged in the new assembly. With the refrigerator defrost timer in the defrost mode do your voltage test. The thermo stat for the defrost does not close until the temperature drops to about 16°F. If you have and Ohm meter you can test for continuity through the heater assembly by testing heater end to end and bypassing the thermo disk. If you have voltage at the first point test where you connected the harness your timer is O.K.. If there is no voltage with timer in the defrost position it could be bad.
Apr 30, 2008 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
128 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
richie46
