Question about Food Mixers
How to fix a loosened head
Head has become loose
  • Food Mixers Master
  • 1,305 Answers
What brand? What model?
Posted on Nov 10, 2014
My dough hook is stuck in my K mix kmx50.
yes the dough hook is a firm fit on those
Instruction Book KMX50, KMX59 English - Kenwood
www.kenwoodworld.com/.../Instruction-Manuals/kMix.../kMix.../18362iss2%20KMX..
Apr 29, 2017 | Kenwood Kmix Kmx50 Stand Mixer, White
Hinge pin came out from head of mixer and can't put it back..will only go through part way.
did you turn your mixer over and unscrew the set screw on the hinge shaft before trying to put back in? there is a small set screw that holds the hinge pin in place during normal operation. the screw sometimes comes loose and the shaft will vibrate out of it's normal operating position but when you try to push it back in the screw now stops the hinge shaft from going in, You have to turn the mixer upside down and look into the base cavity and you will see the set screw in the middle. Loosen first, return hinge shaft to normal operating position and the re tighten the setscrews, you can be firm with this screw, let us know if this helped
Feb 06, 2013 | KitchenAid Artisan Series Tilt-Head Stand...
The tilt release on my 2350 model will not release no matter what I do. Am I just over looking something?
A screw has come loose and is jammed. You need to take bottom cover off and loosen bolts in neck (2). This will seperate neck from motor head and you will find loose screw jammed in tilt section.
Jul 06, 2011 | Sunbeam 2350 Heritage Series Mixer
My KitchenAid tilt head lock keeps coming loose while beating small amount of dough allowing the head to wobble gradually bad? This is the second mixer with same problem! I've heard some people talking...
In my case the lock was not engaging fully because the internal mechanism was bent too short. I'm not sure if this happened over time or if it is just a manufacturing defect. If your mixer still has some up-and-down play to it when the lock is engaged, then you might have the same problem as me
To fix it, search this site and others for instructions on how to remove the motor cover. I found this video useful: http://www.youtube.com/watch?v=VeCiivPt7hk
With the cover removed you have access to the locking mechanism. In my case, the latch is connected to the locking lever via a bent S-hook. The hook was just slightly too short which kept the latch from engaging completely. If you remove the two screws holding the hook in place and that allows the lock to close completely, then you have the same problem as me. (You'll feel the difference immediately. When fully locked, there is practically no wobble in the mixer head.)
I lengthened the hook by placing it against a flat surface and hammering the bend out a bit.
Jan 05, 2011 | KitchenAid KSM90 Ultra Power Series Stand...
Mixer head loose
Turn the mixer upside down and you'll see the screws up inside that hold the head to the base. You'll need a long screw driver.
May 15, 2010 | KitchenAid KL26M8XOB Stand Mixer
MY MIXER IS LEAKING GREASE OR OIL FROM THE HEAD THAT TURNS THE MIXER. WHAT IS THE FIX? IS THIS A FIXABLE PROBLEM? CAN I FIX THIS MYSELF?
I'm assuming yours is an older model with the tilt-head feature.
It's not oil, it's grease. Here is a very detailed article on how to add grease to the mixer. After you have added some new grease and tightened the screws it will stop leaking. The temporary fix is to simply remove the chrome ring as is done in the picture on the attached link, clean out the oil and stick it back on till it fills up again. It is called a drip ring for the reason that it catches the oil component of the grease which drips from the gasket when the screws loosen:
http://www.artisanbreadbaking.com/discussions/kitchen-aid.htm
Apr 13, 2010 | KitchenAid 32685 Mixer
Mixer head is loose beater scrapes bottom of bowl makes loud thumping noise
I assume you mean that the top half of the mixer, above the pivot pin, moves with respect to the lower half of the mixer, the stand part. There is a pin on which the top half pivots which becomes loose.
Turn the mixer over and look up where the pin goes through the two pieces. There is a screw there which secures the pin. Tap the pin into position and tighten the screw.
Apr 10, 2010 | KitchenAid Artisan Series Tilt-Head Stand...
Kitchenaid mixer. Top is loose so it bounces when
Hi MJANKOW520. I?m going to assume your KA mixer is a ?Tilt-Head? mixer. You don?t say specifically. Based on your description of the symptoms you mixer exhibits, I would say that your head locking mechanism (or a component) of it is either broken, worn or loosened due to normal wear and tear and need to be readjusted (or repaired) for it to keep your mixer head stationery. The inspection and troubleshooting of the inside of your mixer is a DITY capability, particularly if your mixer is out of warranty. Just be sure to have the Parts List manual on hand. If you're lacking one, you can download a PDF version from the KA website: http://www.kitchenaid.com/flash.cmd?/#/page/home. Click on Customer Care>Locate Manuals & Guides> Enter the 6 character model number, in your case, try K45SSW, and select the file listed under Parts List (check to see it this matches your mixer model). This parts list manual provides an exploded view for the disassembly and reassembly of your mixer, along with all the part name and numbers. Turn to page3, titled: Base and Pedestal Unit. You?ll want to focus on Illus. #9, Link & Lever Latch assembly, which locks the mixer head to the pedestal when run your mixer. Check to see if something is just loose, exceedingly worn or broken. If something has broken, you can order replacement parts and install yourself. As far as parts go, here are four potential vendors in no particular order: RepairClinic.com; mendingshed.com; searspartsdirect.com; partstore.com. Prices for the same part can vary widely between vendors, so do your comparison shopping. Once apart you can check for any other unseemly wear and tear on other mixer components. It can be messy but quite gratifying to diagnose and repair your mixer yourself. Finally, here's a link to an excellent site that details the disassembly and replacement of a mixer's grease, which might be helpful, too. http://www.foodonthefood.com/food_on_the_food/2009/04/how-to-repair-a-kitchenaid-mixer-yourself.html If you feel this is beyond your capabilities and would be too difficult to do yourself you can take your mixer to a local small appliance repair shop and have them troubleshoot and fix your mixer. KA Customer Care can provide you with the name and phone # of the closest authorized KA repair shop in your area or you can do a Online web search, but be sure to get at least three estimates before deciding to commit to one repair shop. Good luck. I hope this helps. Howard, Burke, VA If this solution has helped you, please rate it, thanks! - hslincoln
Nov 30, 2009 | KitchenAid K45SS Classic Stand Mixer
Mixer head very wobbily.
This sounds like an issue of beater to bowl adjustment, which can come out of alignment naturally over time and with use of the machine.
If the flat beater is striking the bottom of your bowl, this may cause the locking mechanism to loosen and may cause the mixing head to "bounce" during use.
Your Use and Care Guide will cover the "beater to bowl adjustment," which you can do at home in a few minutes with a flathead screwdriver.
Nov 08, 2008 | KitchenAid K45SS Classic Stand Mixer
Tilting too much
i had this same problem. so i wented to the kitchenaid website and looked up the user manuel. it said to adjust the screw that is in the middle of the hinge part between the head and the stand. you can only see it if the head is lifted. you have to turn it counter clockwise to raise the head and clockwise to lower it until the flat mixing head just clears the bottom of the bowl. i hope this helps and it is clear enough to understand
Dec 25, 2007 | KitchenAid K45SS Classic Stand Mixer
Food Mixers Logo
Top Food Mixers Experts
Oscar Netto
Oscar Netto
Are you a Food Mixer Expert? Answer questions, earn points and help others
