I can not eject the disc tray for sony hbd tz210
Just brinking open
Benimur
  • 6966 Answers
SOURCE: CW088D CD-RW drive
If I may add to sandrew, it may be a hardware problem. Normally below the tray is a small motor that drives a belt/gear mechanism that ejects/loads the CD tray. Sometimes, the belt slips, is worn out or plain cut, whichever case, the tray won't come out. If you care to take the risk, remove it from your pc (assuming desktop) , remove the 4 screws underneath, carefully pry open the plastic fron and tray cover and check for mechanical/physical faults. It is also possible that something is simply lodged in between the gears. Should you like to try a temporary remedy, normally just below the tray is a pinhole wherein you can push a stiff but sturdy pin (straightened metal paperclip will do) till you feel something yielding. push gently but firmly and the tray should open partways. You may then manually pull it out and try loading/ejecting. If it won't load/eject using the normal switch, guess you're back to the first paragpraph. Hopes this be of help to you. Good luck.
Posted on Apr 23, 2007
SOURCE: Disc tray
Something is causing the disc to get stuck inside the DVD player. Open it and inspect. If something is broken, take it to a repair center.
Posted on Aug 23, 2007
SOURCE: disc tray will not open and standby indicator is flashing
I can't get the tray to close
Posted on Jul 04, 2008
  • 59 Answers
SOURCE: Sony DVP-NC85H Multi-disc DVD Tray locked
Look on the bottom of the unit. There is a hole with the letters ex and op. Shine a light in the hole and you will see a white plastic object with a slot for a slot screwdriver. You can turn this either way but be careful. If you feel resistance and the object does not turn, turn the other direction and the unit will open. Remember if the disc loaded the clamping of the disc is in place so you must turn it the proper way to let the current disc loose hence the op and the ex. Op is open. Ex is exchange.
JC
Posted on Jul 27, 2008
SOURCE: dvd tray do not open
need help on how to get my tray to open
Posted on Oct 18, 2008
HBD-TZ210 Push power Protector
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Mar 08, 2016 | Audio Players & Recorders
I have satellite C50D-B-10q. How do I open the CD/DVD drive?
Removing discs
To remove the disc, follow the steps as detailed below:
Do not press the eject button while the computer is accessing the optical disc drive. Wait for the optical disc drive indicator to go out before you open the disc tray. Also, if the disc is spinning when you open the disc tray, wait for it to stop before you remove it.
1. To pop the disc tray partially open, press the eject button. Gently pull the disc tray out until it is fully opened. When the disc tray pops open slightly, wait a moment to make sure the disc has stopped spinning before pulling the disc tray fully open.
2. The disc extends slightly over the sides of the disc tray so you can grasp it. Gently lift out the disc.
3. Push the center of the disc tray to close it. Press gently until it locks into place.
How to remove disc when the disc tray will not open:
Pressing the eject button will not open the disc tray when the computer power is off. If the power is off, you can open the disc tray by inserting a slender object (about 20 mm) such as a traightened paper clip into the manual eject hole near the eject button.
Manual eject hole:
Turn off the power before you use the manual eject hole. If the disc is spinning when you open the disc tray, the disc could fly off the spindle and cause injury.
See page 4-8 of the user manual:
http://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=11&cad=rja&uact=8&ved=0CB0QFjAAOAo&url=http%3A%2F%2Fwww.mytoshiba.com.au%2Ffile%2Fdownload%2Fresource%2Ffile%2F25248%2Fsatc50-satpro%2520c50%2520userguide.pdf&ei=hP8qVL7FH8jygwSZtIDwDw&usg=AFQjCNG3BeuYjMmp05rKf6DHmKe2CwfZxQ&sig2=5VtO-__wyjN_V8vBe9na3g&bvm=bv.76477589,d.eXY
Jun 05, 2015 | Toshiba Computers & Internet
Sony slv-350p dvd combo disc tray wont open
Might be to a broken loading belt, or damaged loading gear wheels. Check it. If gear wheel is faulty, it will be best to repalce the disc loading mechanism.
May 14, 2012 | Sony SLV-D350P DVD Player/VCR
My sony dvp sr200p cannot eject the disk inside. i tried all the 4-digit code but i failed.
From www.sony.com
Unable to eject a disc.Solution
Follow the steps below to troubleshoot this issue.
IMPORTANT: If model-specific information is required to complete any of the steps in this solution, refer to the operating instructions supplied with the product. Manuals are available online through the Manuals/Specs/Warranty link on this page.
  1. Ensure the child lock feature is disabled.
  2. Attempt to open the disc tray.
  3. If the issue is not resolved, turn off the DVD player.
  4. Unplug the power cord from the electrical outlet for 30 seconds.
  5. Plug the power cord back into the electrical outlet.
  6. Attempt to open the disc tray.
  7. If the disc tray still does not open, simultaneously press the POWER + STOP + EJECT buttons.
  8. If the disc tray still does not open, simultaneously press the DISC1 + STOP + EJECT buttons.
    NOTE: This step may not apply to all models.DISC1 is not available on all DVD players.
Feb 29, 2012 | Sony DVP-SR200P DVD Player
The tray will not open/eject on either deck; it tries to open but just says TOC no disk.
I have the same problem with both trays on a Sony RCD-W3 not ejecting. If you push the tray sometimes it opens, but takes a few attempts. the recording CD sometimes doesn't see the disk but ejecting and re-entering it normally gets around that. I have no permanent solution, I'm afraid. Probably needs to be opened up and rails greased/oiled or something like that.
Aug 31, 2010 | Sony RCD-W1 2-Disc CD Recorder
HOW DO i UNLOCK THE CODE MODEL NO QPD130B [63120
Ensure the child lock feature is disabled. Attempt to open the disc tray. If the issue is not resolved, turn off the DVD player. Unplug the power cord from the electrical outlet for 30 seconds. Plug the power cord back into the electrical outlet. Attempt to open the disc tray. If the disc tray still does not open, simultaneously press the POWER + STOP + EJECT buttons.
If the disc tray still does not open, simultaneously press the DISC1 + STOP + EJECT buttons or the RETURN + ENTER+ POWER buttons.
If the issue is still unresolved, service may be required. The Sony eService Web site at http://eservice.sony.com/ can assist you in obtaining service from a Sony Service Center or locating a Sony Authorized Servicer.
Jul 24, 2010 | Sony DVP-SR200P DVD Player
Unlock Sony DVP NS725p
Ensure the child lock feature is disabled. Attempt to open the disc tray. If the issue is not resolved, turn off the DVD player. Unplug the power cord from the electrical outlet for 30 seconds. Plug the power cord back into the electrical outlet. Attempt to open the disc tray. If the disc tray still does not open, simultaneously press the POWER + STOP + EJECT buttons. If the disc tray still does not open, simultaneously press the DISC1 + STOP + EJECT buttons or the RETURN + ENTER+ POWER buttons. If the issue is still unresolved, service may be required. The Sony eService Web site at http://eservice.sony.com/ can assist you in obtaining service from a Sony Service Center or locating a Sony Authorized Servicer.
Jul 24, 2010 | Sony DVP-NS725P DVD Player
How do i get my sony dvd off lock
Jul 23, 2010 | Sony Televison & Video
I can't eject my DVD? says locked...what do I do?
If you are unable to eject the disk, please try the following steps.
You can also download the manual at the following link:
http://www.docs.sony.com/release/DVP-NS55P.pdf
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. (Two Thumbs Up)
Please Note: If you cannot rate this post with the highest rating, then please do not leave any rating. I am doing this for free and I do not think that any rating other that the best is needed.
If you need further assistance please comment to this post and I will try to help you further.
Jul 11, 2009 | Sony DVP-NS55P DVD Player
Dvd tray will not open
In order to open the disc tray.apply one of the following solutions;
--- Turn off the DVD player. Unplug the power cord from the AC outlet for 30 seconds.
Plug the power cord back into the AC outlet. Try to open the disc tray.
--- If the disc tray still does not open, simultaneously press the POWER + STOP + EJECT buttons.
--- If the disc tray still does not open, simultaneously press the DISC1 + STOP + EJECT buttons ,
- If the disc tray still does not open simultaneously press the RETURN + ENTER+ POWER buttons.
If the problem is still unresolved, a service may be required.
good luck...
Apr 06, 2008 | Sony DVP-NS400D DVD Player
50 people viewed this question
 Grubhead
Grubhead
