Question about Garden
Karcher hds745 m-eco builds up to pressure. Runs fine for 300 seconds then loses pressure buids up runs for 20 seco ds loses prwssure again checked. Dilter strainer water pressure seems good any ideas anyone
    Problem Solver:
  • 14 Answers
If nozzle is partially clogged, it can cause unloader valve to shift back and forth from high pressure to bypass. Air in the feed line can also cause this symptom. Some Karcher models have auto start/stop system which can behave this way if worn out, or out of adjustment.
Posted on Nov 26, 2014
3 Suggested Answers
SOURCE: Karcher K3.91 compressor run for a few seconds every 10-15 second
They have a problem. I removed both valves and lubed with lithium grease as I was told. Unit is now working for how long who knowes.
Posted on May 19, 2009
  • 1388 Answers
SOURCE: pressure washer does not spray consistent flow of pressure
Pressure washers have a pressure regulator/unloader that bypasses the water back into the intake when you let go of the trigger with motor running. If you let the machine run for long preiods in bypass the system could be damaged due to heating of the water being bypassed. The water is in a closed loop. The as the unloader wears it will tend to want to bypass which is what is happening in your case. Dirt trapped at the tip will cause this also. Install clean tip to solve problem. If clean tip did not help then try lowering the pressure by turning pressure regulator counterclock wise. If problem is gone then parts are failing but keep using pump. Good luck.
Posted on Jul 11, 2010
Karcher 2500ph pressure washer spill valve has been replaced pull wand trigger pressure good for 3 or 4 seconds drops off for a second or 2 goes back to good pressure for 3 or 4 seconds drops off again for...
If you have a Karcher then you should always post your machines barcode.
full article on nozzles :
http://repairshed.blogspot.com/2013/09/pressure-washer-lance-nozzles-what-you.html
The spill valve operates at approx 20% higher than specified pressure washer operating pressure. If you have any lance issues then the pressure could be running higher than specified (machine running at same pressure as spill valve operation pressure)
your machine produces a fixed flowrate of water (maybe 8 litres per minute) and your nozzle is a fixed size. the diameter of the nozzle determines the back pressure. A piece of debris could further close your nozzle orifice and increase the back pressure. Using a new lance that has the wrong nozzle fitted can also cause this issue.
The karcher barcode is on a silver sticker and is usually 15 digits long. Example 156987400000123 is actually model 1.569-874.0 and serial number 00123....
Aug 15, 2013 | Garden
Karcher 300 runs great but no water coming through
hose is stopped up you have to plug the ends up when not in use mud dobbers and other bugs like to get inside had same problem before
Feb 03, 2012 | Karcher G3025OH Pressure Washer
Dishlex Global 300 Dishwasher - ECO Light flashing - Manual indicates incorrect fill level - Manual suggests hold ECO button for 10 Seconds. No success. Have tried pressing and holding buttons - no...
eco light sometimes indicates that water has got into the bottom panel of the machine. A float switch is underneath to protect the machine ( and your kitchen floor from being flooded. ( Either from overfilling or a leak) If you tilt the machine backwards see if any water runs out. If the machine restarts , then you will have sourced the problem. Should the flashing start again later, you may have a water leak underneath. Also check the lower door gasket to make sure its clean. If the gasket is dirty, sometimes water builds up behind the gasket and drips over the front of the tub into the bottom panel underneath causing this symptom. When cleaning the gasket, be very carefull!! The edges of the door at the bottom are razor sharp..
Jul 26, 2011 | Dishwashers
Karcher K4.97M electric waterblaster cycling
It sounds to me like the unloader valve is bypassing internally.
Nov 16, 2009 | Karcher K2.26 Electric Power Washer
The motor keeps surging
If there's a lot of sediment in your water supply, there's a chance that sediment has gummed up the pressure switches. I'm assuming it has a full power switch and high power switch. It runs on full power until a pressure switch is satisfied, and runs on low power to slowly build the pressure back up, at which a second switch is satisfied from the pressure and turns the motor off. These things are not easy to work on, and are made of metal probably too fragile to try any chemicals. You should probably contact the manufacturer.
Sep 19, 2009 | Karcher 1750 psi Electric Pressure Washer
WILL NOT BUILD UP AIR PRESSURE PAST 20 LBS.
Check to see if air is leaking past 'pressure relief' valve. It's probably leaking and that's where all the air is going.
Sep 11, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Troy bilt pressure washer will not build or reach high pressure
check the non-return valves in the pump block. if these are damaged or dirty you pressure will be greatly reduced. they are located behind the 3 lage brass hexagonal caps.
I hope this helps
Sep 04, 2009 | Karcher 2500 PSI Pressure Washer
I require a karcher hds745 pressure washer as i cant seem to get the chemical to work
hi, this can be a problem with the hds745 machine, there are a few different versions on the market.
you first need to put a piece of pipe direct to the pump and bypass the chem valve and filter.
if still no look then you will need to have a look at the brass soap hose tail and see if it has a ball bearing in and if its stuck.
some model have a valve in the head when you have taken the brass soap hose tail out.
Apr 25, 2009 | Karcher Garden
Karcher 2500 no pressure problem
sounds like you have an inlet blockage to the pump or not enough volume to feed the pump. make sure hose is turned full on when washing and see what happens. if not you may have to remove adapter wher hose screws in and check for a blockage.
Jul 13, 2008 | Karcher 2500 PSI Pressure Washer
Karcher Pressure washer
Hi
don't know if this will help, but when I use mine, to start the pressure up I have to turn the nozzle to fine spray then turn it to the power spray and it works every time, shouldn't have to do this but I got it for nothing.
May 29, 2008 | Washing Machines
Garden Logo
98 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
