Question about Irons
I have a rowenta iron model DA-82.I used it 3 times and put it away as it leaked so bad my garments were soaked! when I tried to press them.I called the company and they basically said too bad buy a n
Leaks all the water out when trying to use it clothing and ironing board is too wet to continue
    Novelist:
  • 193 Answers
Dump out the water after each use.
Posted on Nov 13, 2014
satscoop
  • 59 Answers
SOURCE: Brown spots coming from steam iron
you can mix 50% water with 50% vinager let it set in the iron overnight then turn it on and let the steam run out.What happens is the inside of the iron where the water is had corroded or rusted or has lime deposits.the vinager will break this loose overnight.also after you let the iron steam out all the mixture,flush the iron 4 to 5 times and start using fresh water from a store bought gallon.your tap water is probably full of iron.
Posted on Nov 15, 2007
geokohler
  • 304 Answers
Fill with 50/50 water vinegar solution. Get it good and hot and let it sit for two hours. Rinse and repeat if necessary. Buy a gallon of water from the market and use that from now on. This will fix your problem. The Iron is concentrating the iron in you water and this is what is causing the brown spots. Hope you find this helpful. If you do please take the time to rate it fixya and maybe I will keep helping people for free.
George
Posted on Jul 24, 2008
SOURCE: Rowenta Steam Iron Leak
I have purchased two Rowenta irons. Both have the problem with water leakage. The entire iron looses all of it's water....both in the stand up position and the sitting down position. This happened after a couple of months for both items. I contacted Rowenta and they never responded. I will never purchase another item from them. Obviously, the irons must be defective. I'm going to contact consumer affairs.
Posted on Sep 03, 2008
heatman101
  • 43501 Answers
SOURCE: My Rowenta iron is leaking down by the cord. can
Try using different water...
Here is a tip that will help you with that problem...
My Steam Iron is Leaking Water
http://www.fixya.com/support/r5301301-steam_iron_leaking_water
heatman101
Posted on Jul 14, 2010
heatman101
  • 43501 Answers
SOURCE: Rowenta model 1700W. Water leaks out front of iron
heatman101
Rowenta superpress DG 050 leaks water while steaming all over garment. Do I need to Descale the unit?
I've had the same problem with two Rowenta irons. When set to a lower temperature, the iron has a bad habit of leaking water when the steam option is on. I have to either turn up the temperature setting or shut off the steam option.
Feb 28, 2015 | Rowenta Irons
How to clean a Rowenta steamer
WHen cold tilt over sink and empty and rince every 3-5 uses depending on how much you use it. Water sitting in the tank gets moldy and bad, rinse tank and use Britta type filtered water only.
Jun 18, 2014 | Rowenta Commercial Garment Steamer - White
Rowenta 1600w iron
not possible as the iron is out of date
why would be interested in getting such a bad iron after the first failure and reading all of the bad reviews
Jun 07, 2017 | Irons
Orange light is lighting but no steam is coming out ..
Hi, I believe you have a build up of calcium in steam lines and other parts ( clean out parts)
Use white vinegar or CLR will do. Let it soak for an hour and then put together. Good luck
Jun 12, 2011 | Rowenta Commercial Garment Steamer - White
My rowenta iron shuts off in the middle of ironing & spits water
heatman101
Jun 09, 2010 | Rowenta Powerglide DE011 Iron with Auto...
ROWENTA STAM IRON - NO STEAM !!!!
heatman101
May 22, 2010 | Rowenta Commercial Garment Steamer - White
I have a rowenta iron that leaks a lot of water
Here's a solution . . . Do NOT buy ROWENTA! I've had 3 Rowenta irons. All of them have eventually began to dump water out of the base. . . heck, the Titanic didn't leak as much as a Rowenta iron!
Dec 31, 2009 | Rowenta Perfect Iron
Hardly any steam comes out...hose is getting pretty hot...How do I clean it out..Iv'e had it for a while.
Soak the nozzle in white vinegar for 10-15 minutes. Dip it into plain water to rinse the vinegar out. The deposits in the nozzles will be melted away.
Oct 29, 2009 | Rowenta Commercial Garment Steamer - White
How do I clean a rowenta DX8800 iron that leaves deposits on my garments
Use a white vinegar and distilled water solution in the iron, but don't do any clothes with it. Let it soak for a while, then heat the iron and let it blow out any debris. Fill again with distilled water, shake well, and let it steam out. Do this again until there is no vinegar smell coming out. If you use only distilled water, you should have no further problems like this.
Sep 18, 2009 | Rowenta Professional DX8800 Iron
At high temp settings water leaks out of steam holes in bottom
You want to run the self-clean mode. Fill with water, then over a sink, with the iron facing down, press the self-clean button. Steam will eject, along with sediment and water deposits. You may have to repeat numerous times. The iron requires soft water, if you don't have soft water at the tap then buy bottled water at the grocery store to prevent this problem.
You can also buy a cleaning solution that you mix into the water reservoir, or you can make your own by filling the iron half-full of water then add white vinegar to the fill line, then perform the self-clean mode or steam mode over a sink.
Here is a Rowenta suggestions:
The iron is leaking.
Water: Use tap water in the iron. If tap water is hard or high in organic matter, we recommend using bottled spring water or mix tap water with distilled. Do NOT use 100% distilled water. Many softening systems may cause issues as well.
Auto-Off: If iron is equipped with auto off, you need to move iron or gently shake it an allow it to heat back up before beginning to iron.
Overuse of Burst of Steam: Allow more time between each burst of steam.
The Rowenta site does not list a manual for your older model, but here is their link:
http://www.rowentausa.com/rowenta/frame.aspx
Mar 21, 2009 | Rowenta Powerglide DE013 Iron
Irons Logo
91 people viewed this question
Top Irons Experts
Are you an Iron Expert? Answer questions, earn points and help others
