The picture shows for a minute or two then goes
The picture shows for a minute or two then goes out but I still have volume
    Novelist:
  • 112 Answers
Sonds like the power supply for the lamp needs to be replaced. Sometimes the power supply modules contain a heat sync protection that can fail over time. I would begin here and go from there. I hope this helps. Good luck.
Posted on Nov 10, 2014
Volume up then pic gone
You've got a bad solder connection,or broken foil line,s on the pcb (printed circuit board1.gif).Narrow it down by pressing in different places,or use plastic or rubber tip.If not,then you got a shorted load on this fuse and diode.do you have a schematic,whats at the end's of this circuit.D represents a <Diode> not a transistor.
Jan 28, 2008 | Mitsubishi WT-46807 46" Rear Projection...
Tv's volume won't stay at set level,volume goes up stays for a few minutes and then goes down to zero.
This particular model at the time of assembly had jumper cables that were tight fitting. You may have to take this TV to a repair shop. There they will have to loosen the jumper cables by peeling back the insulation that shields the internal wiring. Or have them install longer jumper cables. Thanks for asking and show a few hands of support.
Dec 12, 2010 | Sylvania Televison & Video
Picture goes off
unplug for two hours and try it again. if that doesnt fix powersupply is probably going bad.
Jul 11, 2009 | Panasonic PT-53TW53 53" Rear Projection...
TV only stays on for a minute. Screen goes blank for about 2 minutes. Then the picture pops back up on the TV. Model number is KDF-E55A20. Sony Wega HDTV. Made in 08/2006. Please advise....
I think TV on for minute or so, goes to standby and again power up, show picture for minute and again standby.
If above are symptoms then its time to replace lamp in TV.
Let me know if symptoms are different.
May 11, 2009 | Sony Televison & Video
It's the 26 inch version but have problem with picture
Hi Paul,
It looks like your TV might have a main board failure if the screen stays white without video. Since your TV is less then a year, I would suggest to contact the manufacturers to get fix under warranty. Most electronics devices carry one year warranty.
Good Luck.
Dec 19, 2008 | Olevia LT32HVE 32 in. LCD Television
Good Day;
The TV's front panel may be bad, manual buttons. TEMPT FIX; remove speaker, cloth covered, cover, disconnect cables. TV will work but only with remote.
Good Luck!
Jun 12, 2008 | Mitsubishi WD-52525 52" Rear Projection...
HCM4215W 42 in. Rear Projection Television
When the screen goes blank, hit any remote function that will show up on the screen-like volume bar. If the display is missing as well, then you have a tv problem. If the volume display is there when the tv picture is not, you may require a software upgrade.
Mar 06, 2008 | Samsung HCM4215W 42" Rear Projection...
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
