Question about Orion 32RTC 32" LCD SECURITY MONITOR, 1366X768 WXGA
What is the red blinking light on Orion 32rtc monitor
what is the red blinking light on Orion 32rtc monitor
How to program a Orion flat screen tv with ccd remote control
make sure your tv is on.. On the remote control, press TV once.
. Press and hold set until the l.e.d. red light blinks twice,
then release set.. Enter the first four-digit code for your tv
the l.e.d. will blink twice. If the l.e.d. did not blink twice, repeat steps 2 through to 4 and enter the code again.
.point the remote control at the tv and press power once.your tv should turn off. If it does not, repeat steps 2 through to 5...i think these codes might work for you set .0236, 0463.
Nov 08, 2016 | Orion Televison & Video
Orion tv codes
Hello
Three digit universal remote codes for Orion TV are:
035/ 121/ 135
Four digit codes are:
0121 0135 0035
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Feb 12, 2012 | Orion1934 19" TV
Need remote code for orion tv
Hello
Three digit universal remote code for Orion are:
035/ 121/ 135
Four digit universal remote code for Orion Tv are:
0121 0135 0035
Direct Code Entry
NB: Switch OFF and switch ON your TV, with its FRONT PANEL POWER CONTROL SWITCH EACH TIME before tring an other code.
OK.
Mar 12, 2011 | Orion Televison & Video
Remote codes for a universal remote
Hello
Three digit universal remote code for Orion TV are:
035/ 121/ 135
Four digit universal remote codes for Orion TV are:
0121 0135 0035
Direct Code Entry
OK.
Feb 21, 2011 | Orion1934 19" TV
Please tell me about orion Remote code
Hello
Three digit universal remote code for Orion are:-
035/ 121/ 135
Four digit universal remote code for Oriona are:-
0121 0135 0035
Direct Code Entry
OK.
Jan 02, 2011 | Orion Televison & Video
Orion tv codes
Hello
Try with these codes
Four digit universal codes for Orion are
0121 0135 0035
Three digit universal codes for Orion are
035/ 121/ 135
Code Search If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
Nov 19, 2010 | Televison & Video
Need codes for one for all remote control 3021. need codes for orion tv.
The codes for an Orion TV are 0236, 0463.
To program your device:
  • On the remote control,press a device key once.
  • Press and hold SET until the LED (red light) blinks twice, then release SET.
  • Enter one of the codes above into the device. If performed correctly, the LED will blink twice
  • Aim the remote control at the device and press POWER
  • once.The device should turn off.
If either of these codes will not work you can try scanning the internal memory to locate one that does.
Below is a link to the manual for your remote. It will explain how to search the memory for the code.
Hope this helps.
Oct 10, 2009 | One For All URC-3021 Remote Control
Need Universal Remote codes for Orion tv- One for All Remote
The TV codes for a URC-3021 and an Orion TV are:
0236, 0463
These are the steps to program your remote:
To setup your URC-3021 for a TV, these are the steps:
1. Turn on your TV.
2. On the remote control, press TV once.
3. Press and hold SET until the LED (red light) blinks twice,
then release SET.
4. Enter the first four-digit code for your device. If performed correctly,
the LED will blink twice. If the LED did not blink twice, repeat steps 2 through 4 and enter the same code again.
5. Aim the remote control at the device and press POWER once. The device should turn off. If it does not, repeat steps 2 through 5, trying each code until you find one that works.
Oct 05, 2009 | One For All URC-3021 Remote Control
Oneforall remote control code
all for one code for orion tv ...0236 or 0463...........press tv button..press and hold SET untill the red light blinks twice, then release set button...enter one of the 4 digit codes...the red light will blink twice...press pwr button... if this fails,try other code no.
Oct 25, 2008 | One For All URC4220 Remote Control
Orion 32RTC 32" LCD SECURITY MONITOR, 1366X768 WXGA Logo
47 people viewed this question
Top Orion Computers & Internet Experts
David Payne
David Payne
Are you an Orion Computer and Internet Expert? Answer questions, earn points and help others
