Question about Garden
How to fix the choke on homlite 38 cc 16 inch gas chain saw
Fix choke
    Master:
  • 240 Answers
More than likely, your choke became disconnected. I have attached a link from YouTube of a video on this.
There are many useful video's on fixing chainsaws, from simple fixes such as reattaching a choke lever, to complete tear down and rebuilds.
I hope this helps you get back up and running.
Short video on fixing chain saw choke
Posted on Nov 13, 2014
Idaho_Biker
  • 32 Answers
SOURCE: 38 cc Poulan Chain Saw
Since You weren't Model Specific...I assumed you meant a Poulan Pro 38cc, here's a Contact Site for OEM Manuals:
http://www.poulan.com/poulanpro/manualSearchResultsAJAX.do
Posted on Jan 18, 2009
Editor925
  • 285 Answers
SOURCE: new chain for 16'' 35 cc mcculloch
You need one of these chains or something similar:
Oregon 16-Inch Pro-Guard Chain Saw Chain Fits Cub Cadet, Echo, Homelite, McCulloch, Makita, Partner, Poulan #H66
Posted on Mar 17, 2009
slohry
  • 87 Answers
SOURCE: Owners manual for Craftsman 20 in chain saw, needed
Parts manual, have model # available
http://www.searspartsdirect.com/partsdirect/index.action?sid=PSHx20080129x00001
Posted on Apr 09, 2009
lemmingleejn
  • 173 Answers
SOURCE: echo chain saw 16 inch will not start
You need to play about with the timing adjustment.
You can adjust the timing by two different methods.
The first is to adjust the space on the spark plug.
The other is to adjust the gap between the contact, and the coil/magneto.
There ya go, FixedYa !))
Don't forget to rate, thanks.
Posted on Aug 01, 2009
dontbother10
  • 2220 Answers
SOURCE: 2.0 Cubic Inch Montgomery Ward gas chain saw, 10 inch cutting bar
Fuel/Oil Mixture
  1. Use a quality 2 cycle oil and mix it to the OIL supplier's recommended ratio. Today I use Stihl 2 cycle oil mixed @ 50:1 in a Pioneer that I purchased new in 1980. There are no gouges or scratches on the piston or cylinder and I have no carbon build up on the piston top. The manual (on stone tablets) recommends 24:1. Over the years the mixture has leaned from 24:1 (Saw Recommendation) to 28:1 (Lawn boy mower recommendation) to 32:1 (Oil provider 8oz/2gal - used for many years) and finally the last 5 (±) years 50:1 (Stihl 2.6oz/1gal)
  2. Any fuel containing ethanol is not good with chainsaws. Mix what you expect to use within a few months. Anything over 3 months old use up in a 4 cycle engine. HTH
Lou
Posted on Oct 26, 2009
Why pole saw wont saw?
There could be a couple of reasons why your saw won't cut.
The first thing I would check is to make sure you have your chain facing the right way.
The chisel edges should be facing forward, or in the direction the saw chain is rotating.
If this is not the problem, then I suspect the chain itself is dull.
Jul 08, 2014 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
16 inch poulan chainsaw got hot and started to smoke and now the recoil no longer works. I took the cover off and there is two springs that seem sprung. should I toss it and forget it or this something I...
how old is the polan 16 inch is it a solid body saw or does it have anti vibration handles, so your hands dont go numb after cutting for 15 minutes.reason i asked is: you can buy a brand new reconditioned homelite with anti vibration handle for 85.00&shiping.
at the very least,your polan needs the recoil starter fixed
and that does not address why the poulan got hot & started to smoke.
For the problems you described , at least $100.00 labor plus parts to fix at a chain saw shop
It might barely be worth it if you were a do it yourselfer and wanted to try to fix it.
if you dont want to be a diy chain saw mechanic, sell your polan for parts for $20.00 on ebay and buy a new homelite
16 inch 38 cc with anti vibration handle ,so you can cut for 6 hours straight, if need be. You get a reconditioned saw that is ready to go and a 90 day warranty. or buy the saw brand new for $110.00 and free shipping@ amazon.com
Oct 07, 2013 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Can i upsize my chain from a 14 inch to a 16 inch i have a 14 inch mcculloch and i want to put a 16 inch bar and chain on it. it is a 35 cc engine
There will be a 16" option, however things to remember, you will have a drop in power, so you need to keep the chain sharp, the oiling system will probably on its limit.
Apr 19, 2011 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
How check for proper coil out put on a poulan chain saw
I gallon of gas and a 7.5 onz (small bottle) of 2cycle oil.
Oct 05, 2010 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Poulan chain saw will not stay running after i start it. What are the carb settings ?
a good starting point is the low speed screw at 1 3/4 turns and the high side at 1 1/2 turns. Hope it helps
May 20, 2010 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Gas ratio
Most saws built within the last 30 years or so can be run with 40:1 using modern synthetic saw oils. A number of late model units run 50:1. Make sure to premix the fuel and oil before adding to the saw. Hope this helps!
May 04, 2010 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Will not start - brand new
i bought a new dirtbike as a kid n same thing.it turned out ,it needed to be a synthedic oil in the mix.try seeing for spark to begin with by putting sparkplug in the wire n touching diode to the engine block while pulling the cord.thats a good starting point to diagnosing your problem.maybe try warming it up in the house then try starting it with no choke needed.the saws i ve used needed you to give it throttle after you pull,n no throttle with choke.
Mar 12, 2009 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Garden Logo
81 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
