Question about HP Officejet 6600 e-All-in-One - multifunction fax / copier / printer / scanner color
A little gray rubber piece fell off of my officejet 6600 and now I can't feed multiple papers. Does anyone know where this little gray rubber piece goes?
    Scholar:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 150 Answers
Look inside the paper feed it sits behind the paper pickup roller
Posted on Feb 12, 2015
Stating that there is no paper but there is paper in the tray
Usually this means that the paper can't be picked up. First take out the paper and check for curled edges or wrinkled paper. Discard damaged pages. Check for torn corners and remove any small foreign objects. Make sure that the paper is aligned properly when you return the paper to the tray. If you only have a few sheets in the paper tray, add more paper.
Next check if the rollers are dirty. They can be cleaned with a damp lint-free cloth. (Just a little water is needed.) Check that the feed mechanism is undamaged. My home inkjet printer (an HP OfficeJet 7000) had a part of the paper lift mechanism break a few days ago. If you pushed the top sheet of paper just right, the printer would still pick it up. We noticed a loose piece when we opened the back of the printer for the straight-through paper feed. After attempting to replace that piece, we looked closer and another part fell out of the printer.
Some find it worthwhile to take apart the printer and re-attach the parts. If the printer is still under warranty, let HP do the job.
I hope this helps.
Sep 12, 2015 | HP OFFICEJET PRO 6830 E-ALL-IN-ONE PRINTER
HP Officejet Pro 8500 Wireless All-In-One InkJet Printer Paper feed will not drop down every time, and is making a grinding noise. Is replacing that piece available?
Hi. You leave a question mark?
I don't understsand what you mean by Papaer feed will not "DROP DOWN"?
I to have the same printer, the paper feeds from the tray (s) from below.
A little more info please?
The grinding in the system trying to feed through the paper.
Just a thought, turn the printer round find the release levers and check the internals for paper jam.
Mar 13, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
Canon ip 2600 printer. Paper does not feed
Hey I had the same problem. Called the company; we couldn't fix it. Well I turned it upside down and a 2" flower stem fell out from when I cut some flowers next to my desk. It still didn't work. I was examining the feed area while it was running and I found another little piece of stem that was lodged way in there. I had to get it out with tweasers and it turned out to be 1" long. Couldn't really see it at all. Works fine now.
Oct 25, 2009 | Canon Pixma iP2600 Photo InkJet Printer
2 small rubber pieces have fallen out. any idea
Those pieces go on the clean station and can easily be replaced. They each fit over a stud where the printhead parks and just press on.When they are missing the ink will dry out on your ink cartridges and the machine won't be able to clean them properly.
Jul 24, 2009 | HP Officejet 5610 All-In-One InkJet...
Canon NP 6050 Paper Feeder won't feed
Seems the wheels on the left side of the feeder maybe slipped or something, I turned them 1/2 way over so the gray rubber part shows, then they were able to grip the paper and feed it into the copier. That worked for a little while, then it did it again, I turned them again and it worked. Maybe I just need to make sure they have a little traction to solve the problem. Thanks for your website.
Apr 01, 2009 | Canon NP 6050 Copier
Roller pulls several sheets of paper instead of one
You need a separation pad for the paper tray. It would be advised to replace the feed rollers at the same time.
In the short term, you can pull out the paper tray, and on the very front (where the paper feeds out), you will see a black (or gray) rubber pad that is spring loaded. Scrub this pad with a little alcohol, on a cloth. You can even rough it up a little with a brillo pad. This should improve the feeding for the short term.
*please rate me :)
Mar 31, 2009 | HP LaserJet 4650n Printer
HP 7580 Paper Jam made piece pop up in the way of carriage
Two choices; 1. Take the machine apart and take the roller out and then bend back the little follower.
2. Break the offending follower off and hope the paper still feeds through OK.
Apr 28, 2017 | HP Officejet Pro L7580 All-In-One InkJet...
Paper feed
Have you tried a different brand of paper?. When choosing the paper try and select one which the sheets can slide easily over each other. I had loads of problems with multiple feeds and paper jams with a cheap paper. I then changed to a heavier 90gsm all in one paper from staples and have had no more problems since.(and i just chuck the paper in straight from the packet with no fanning etc)
Dec 15, 2008 | HP OfficeJet Pro k550 Printer
Paper feed not feeding properly
There is a gray rubber pad on the upper half of the feeder.
Take the white piece off and turn the pad 180 degrees.
Aug 28, 2008 | Samsung SF-560 Plain Paper Laser Fax
HP Officejet 6600 e-All-in-One - multifunction  fax / copier / printer / scanner   color Logo
64 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
