Question about Craftsman Garden
My craftsman garden tractor clicks when it try to start it down in the motor and the rear wheels won't turn and i cannot get it into neutral
  • 4,348 Answers
That sounds like a dead battery. No go, but of course you figured that out. Consider disconnecting the battery and recharging it.
Posted on Nov 10, 2014
No parking brakes
Go to searspartsdirect.com type in your model no. It will be something like 700.000111 be sure and include . Then look at diagrams and try finding brake system.
Nov 16, 2017 | Craftsman GT 5000 26 HP54" Garden Tractor...
Craftsman lt1000 stuck in neutral
The rear wheels are keyed to the axle shafts with a sqaure key, if the last owner forgot to replace one of the keys the axle will just turn in the centre of the wheel and not turn it, because the gearbox has a diff it means neither wheel will turn if either side has the square key missing, pull the wheels off and check the key is there.
Jul 08, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Wheels are locked cannot move in neutral
If, t's a Craftsman You might can go to rear of your Mower and Release the Freewheel Control Level.
Nov 11, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I put the rear end of my craftsman lawn tractor on a cinderblock to take the rear wheel off and fix it. It was on the block for a couple of day. Now my tractor won't go forward or backward. the belt...
Did you forget to reinsert the key or did it slide out while putting the wheel on. A quick way to check is if you remove the center cap and have someone put it in gear and try to go while you are watching the axle. If the axle is turning and the wheel is not then the key is missing.
Sep 12, 2011 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Is there a fuse on my bob villa 21 hp craftsman lawn tractor? The battery is charged but it won't start, won't even turn over.
Check you safety switches, brake, neutral, seat, blades, and reverse (if equiped). Then if that does not work I check the starting solinoid and the ignition switch.
Aug 08, 2011 | Garden
I have a craftsman gt6000 18hp kohler garden tractor. I has been working fine, but last week I noticed a loud single click when i turn on the ignition and a loud single click when i turn off the ignition....
The noise is likely coming from the starter solenoid which is the heavy duty relay that sends battery power to the starter motor. If this is the case clean the wire connections going from the battery, to the solenoid and to the starter and try it again.
May 25, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Motor won't start and mower very difficult to push
is there a puddle of oil under where it made the clunking sound, that would mean the engine is blown. another thing to check is to see if the motor bolts that hold down the motor came loose and is hanging down there by keeping the pullys from moving right..good luck
Apr 03, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
My tiller runs great but wheels will not turn forward or backward. It is a craftsman rear tiller
The drive belt going from the motor to the gearbox may have broken or come off.
Mar 11, 2010 | Craftsman Rear Mount Tiller
Craftsman 42 in. deck lawn tractor. Will start and idle fine but when you let out on the clutch the motor bogs down and dies
few reasons will try to narrow down first start it and put in neutral and deck disengaged release clutch if bogs then fuel problem the carb may need adjustment or repair or fuel filter needs replacement----if no bog step on clutch no put in gear release clutch if bogs check drive belt -upper belt on engine pulley and check for binding an idler pulley problem -debris -or rear unit binding -needs service-drive pulley damaged-rear locked--if not bogging in gear step on clutch engage deck release clutch if bogs need to check deck -belts-pulleys -mandrels -bearings and for bent or binding blades good luck
Mar 10, 2010 | Craftsman Garden
Craftsman 19.5 42 lawntractor, steering started clicking, then would nto turn wheel. Bar underneath unattached hitting ground. Do not know where it goes. How can I fix.
not a expert just trying to help,,sounds like you have two or mor problems,, first the bar will only go to one side of the front wheels,if it does not snap into place,you will have to replace the joint.,, the clicking sound maybe the steering unit sliping,,look down from steering wheel follow the shaft down to the steering gears,, they might be worn out.. hope this help you
Feb 15, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Garden Logo
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
