Remote does not work new batteries still nothing. Received a new remote still nothing.
    Top Expert:
  • Televison & ... Master
  • 75,404 Answers
You have to set the new remote control; with the set-up code said to your TV brand. (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Search the site by type in the brand name to your device, in the "Search this Blog" window, and press Enter.
Posted on Nov 16, 2014
  • 27 Answers
SOURCE: remote will not work
if the light is staying on this means that a button is stuck down on your remote. It might be defective I would contact the company about warranty.
Posted on Nov 05, 2007
  • 374 Answers
SOURCE: new dish network remote not working
The 6.3 remote has a blue number two key tab on it when it is shipped from the warehouse. If you remove the battery lid you will be able to remove the tab by pulling it out.You will need the other keys that should have come with the remote and use the black colored uhf key and insert it into the remote and put battery cover back on. Ensure the UHF antenna on the back of the receiver is tight and in the upright position. Now turn the TV on and using the buttons on the receiver press menu twice. This should bring you to the system info screen. There will be a remote address toward the bottom of the screen and usually this number is 1. Now take the new remote and press and hold the clear SAT button on top until all the lights across the top illuminate. Now release and key in 01 and press the pound key. The SAT button should flash three times. Press the record button and noe try to navigate the highlight to the done or cancel option using the left and right key. You should now have control of the receiver if not the antenna port which receives the commands could be faulty. If you were successful with the remote remember you will also need to program it to the TV itself to enable you to turn the TV on and off and control the volume with the remote. The FINAL issue that may be causing your issue is that the part number you gave does not match a 6.3 remote. A 6.0 WILL NOT WORK WITH THE 510 EVEN IF YOU DO ALL OF THE ABOVE as I tried it the other night to verify the accuracy of information that is put out internally. I hope this resolves your issue and if you need help programming the remote to the TV itself please let me know. Thanks for using Fix Ya.
Posted on Jan 07, 2009
  • 8457 Answers
SOURCE: I replaced the batteries but the remote does not
Ur Lithium battery fully take in the charges,u recharges?Let the rmote sit without battery about couples hours.Put battery back in again,should work.
Posted on Apr 22, 2010
  • 8457 Answers
SOURCE: I ordered and received a
The old and new remote look alike?Not than it have diffrent radio frequencies.The remote will not work,with the Bose radio you have.Call bose custumer service,ask the remote the match ur Bose radio make and model.Return the remote u have,get a replacement matches ur Bose radio model or look alike to ur old remote.
Posted on Sep 04, 2010
  • 374 Answers
SOURCE: The remote to the secondary tv keeps requiring new
There is an internal component that has failed on the remote. Replace the remote and your issue will be solved.
Thanks for using Fix Ya.com.
Posted on Oct 19, 2010
My remote control can't control mysystem
First check the batteries. Also make sure nothing is blocking the path from the remote to your system where the remote system is received.
Remotes are relatively cheap or you can buy a off brand universal one that will at least see if it will work with another one.
Apr 07, 2014 | JVC THG31 Theater System
My DTC 6200 converter/decoder was working fine. A few weeks ago I have disconnected it, pull the power cord out of the AC outlet, put the decoder in a safe place. Then when I finish painting, I hook...
Hello
Check out these with your Motorola converter
[1] Verify that the AC power cord is connected to the DCT*
and an AC outlet.
[2] If the DCT* is connected to a switched outlet on another
unit, verify that that unit is powered on.
[3] Press the POWER button on the DCT* front panel instead
of the remote control. The batteries in the remote control
may be depleted
[4] The DCT* may have received a software update and
may not power on while the new software is being
installed. Try again in a few minutes.
OK.
Oct 21, 2011 | Arris DCT6200 DTV Receiver
I ordered and received a new remote for my Bose radio. Mine is the old type purchased in 1997. My problem is the new remote does not work, and yes it did come with a battery. Is there something you can...
Sep 04, 2010 | Bose Televison & Video
Logitech pure-fi Anywhere 2 Remote Control not working. Tried a new battery & still not working? any suggestions?
I received my anywhere one week ago, the remote didn't work, reracking several times didn't help, I replaced the battery with minus to plus vv. and then put it in again properly, working flawlessly since. Logitech won't advise this method but it's worth trying.
May 21, 2010 | Logitech 984-000057 Pure-Fi Anywhere 2...
Sony RM-Y180 remote control
Did you install the batteries correctly?
Some remotes (Universal) need to be re-programed when you install new batteries.
Go to remotefinder.rca.com/default.aspx?site=rca for proper codes.
Oct 30, 2008 | Sony RM-Y180 Remote Control
Just received new Rebel Xsi w/RC-1. After setting selftimer/remote from menu, remote will not work. Batteries have datestamp 87. Other than changing batteries, is there any other solution.
remove the battery and check voltage .... if the voltage is appropriate then there is no problem with the battery ...get the remote checked
Oct 14, 2008 | Canon Cameras
No response from remote
user manual
FINALLY no need to thank me
User Manual
Aug 31, 2008 | Televison & Video
Remote stopped working
already tried a new remote and new batteries. bose says the ir bulbs need replacement so i'm taking it in. shucks.
Dec 23, 2007 | Bose (321GS) System
Check whether the remote control is working properly or not by using remote checker. Even if it is the universal remote control you have to set the code for the particular model. Otherwise it will not work.
Sep 17, 2007 | Panasonic CT-32SF37 32" TV
Televison & Video Logo
35 people viewed this question
Top Televison & Video Experts
