Question about Suburban SW10DE Direct Spark and Electric Water Heater 10 Gallon Trail
If water heater is putting out some warm but not hot waater and and the "on" and "reset" buttons wont come on, what may be wrong.
  • 35 Answers
How old is the water heater?? button needs replacing not sending signal
Posted on Nov 10, 2014
Testimonial: "sorry, should have put year in. The RV is a 2013."
Brand new electric hot water heater doesn't get water hot
Call Rheem
Reset breaker fully off and then fully on.
Test for 240 Volt across top two screws on upper thermostat
Press reset button located on upper thermostat
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html#reset
Gene
Water Heater Timers Save Money
Jul 01, 2014 | Rheem Water Heaters
Turned down temp on Water Heater a little, and now we are not getting any hot water. Not even Warm. Whats wrong?
For electric tank: Push in the reset button located on upper thermostat.
http://waterheatertimer.org/How-to-troubleshoot-electric-water-heater.html
For gas tank, then more specific information might be needed for example if unit has power vent, when was the air intake cleaned, is the pilot lit, what brand and model number etc etc..
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html
For tankless, or solar, or hybrid electric, gas boiler, or indirect, or RV heater, etc then please include brand, and model that appears on label on side of unit.
Sep 05, 2012 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
Pilot light on hot water heater is out
you need to shut off the the red nob and turn the nob off in front take the cover off remove the heat shield turn the nob on top to pilot use a piece of paper to light put in next to pilot and hold button down for 20 to 50 secs pilot should stay lit turn nob on front then burner should kick on then you should be all good
Mar 21, 2012 | Water Heaters
Elec water heater 40gal water way to hot and blowing braker on the water tank Red reset button what wrong please help
One of the thermostats is bad or there is corrosion behind it...
Check out this tip..
How to replace the Thermostat and Element for
Electric Hot Water Heater
heatman101
Feb 14, 2011 | Water Heaters
It has cold water comign out no hot
Yes, the reset probably is tripped...push in the red button hard
Then turn it on and try it...
heatman101
Jan 18, 2011 | RELIANCE ELECTRIC WATER HEATER
My water heater wont heat up
You posted under Marathon electric heater.
If you have tankless or tank-type gas heater, information below does not apply.
Absence of hot water say upper element is not working.
1) This can be caused by tripped reset button located on upper thermostat. Open upper cover and push in reset button. Put ear against tank to hear bubbly fizzing sound. Put insulation and cover back over thermostat. Continue reading information below because reset button trips when thermostats are bad or element is shorted.
2) Upper thermostat is bad. Replace upper thermostat. I usually replace both upper and lower thermostats.
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
3) Electricity going to water heater from breaker box is interrupted.
http://waterheatertimer.org/Test-electricity-to-water-heater.html
4) Upper element is bad. Test element. Replace element if needed.
http://waterheatertimer.org/How-to-test-water-heater-element.html
http://waterheatertimer.org/How-to-replace-water-heater-element.html
5) Add a comment for more free help.
6) Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jan 17, 2011 | Rheem MR105245 Marathon Electric Water...
New water heater installed in Jan.2010, first no hot water at all, replaced top element have hot water now but reset button trips and have to reset it when all hot water is used. Any ideas what is wrong?
The reset switch works like a thermostatic breaker and although unusual, it is possible the reset switch is bad or weak. You can replace the reset but some are hard to find. It may be easier to replace the upper thermostat with reset. I would also suggest that you check with the vender you purchased it from, and relay your story to them as they may be willing to help you with the parts. I hope this helps.
May 22, 2010 | RELIANCE ELECTRIC WATER HEATER
Hot water wont get hot
1-First check for power to water heater and remove acces panels on heater to check power at thermostats. Thermostats have a reset button on them that trip and can be pressed to reset.
2- If none of the above have changed any thing and you have power you may have elements gone bad.
If an element is gone at top you will get scalding hot water then go to cold.
If an element on the bottom is gone you will get luke warm water then will get cold.
May 17, 2010 | Water Heaters
HELLO, MY WATERHEATER KEEPS TRIPPING THE RESET BUTTON ABOUT TWO TIMES A MONTH. WHAT COULD BE THE PROBLEM?
could be faulty thermostat/reset button, or shorted element. Breaker to water heater off,
Check elements for continuity to ground. should be no continuity to ground. If elements OK replace reset button. If you have noticed very hot water and elements checked OK then replace both thermostats along with reset button
Feb 17, 2010 | Reliance & 50gal Electric Water Heater
I have a reliance 501 electric hot water heater and i cant find the reset button. Where is it located?
it is located on the thermostat. Take the cover off the side and you will see a little red button in the side of the themostat.
Jan 10, 2010 | RELIANCE ELECTRIC WATER HEATER
Suburban SW10DE Direct Spark and Electric Water Heater 10 Gallon Trail Logo
123 people viewed this question
Top Suburban Water Heaters Experts
Gene Haynes
Jay Plesset
Are you a Suburban Water Heater Expert? Answer questions, earn points and help others
