My Technics CD Player SL -PG460A will not play CDs. It loads them fine but nothing else happens. It's the same even when using the remote rather than the buttons on the machine itself. Can you help pl
It loads CDs fine but nothing else happens afterwards ie won't play, skip forward etc. It's the same even when using the remote rather than the buttons on the machine itself. Can you help please?
    Champion:
    Habit-Forming:
  • 239 Answers
Nothing will function unless it reads the info on the disc first.
You may have a dirty lens or a faulty laser.
Posted on Nov 11, 2014
SOURCE: numark cdn95 left player skip even with new cds
CDN95 uses the same CD transport as a CDX, aka....junk. Its mostly likely defective, replace left CD drive.
Posted on Oct 17, 2008
SOURCE: Technics Sl-DZ1200s skipping on one deck
Change the motor disc spindle they are all the problem
Posted on Jul 03, 2009
SOURCE: My Technics SL-DZ1200 will not play certain MP3
I believe it can only read certain bitrates. I noticed that if I run the track error files through audacity and re-save as an mp3 with 192 kbps encoding it plays fine. Give it a try - re-encoding.
Posted on Nov 12, 2009
SOURCE: Technics SL PJ27
First I think you should turn your player on and wait 5 - 40 minutes before before you start liste3ning music.
because electrolytic capasitors may be little broken and those can repair themselves but it takes a while.
Good rule of thumb is that If you don't use every day an old device
then you should give to it every time a soft start . like I mentioned earlier
turn power on and wait.
Second try to play music cd which don't have any scratches and without any copyprotections
Third Disconnect power cable
Then open device and try to clean all dust.
Look for hairs and other difficult to see objects uselly
you find at least one hair inside old cd player.
If hair is around disk spindle it maybe difficult to
remove.
Check that cd-disk makes good contact so remove even tiniest dust and hairs
between cd-player and copact-disk. It may be called spindle or what ever but
still try to clean it with Isopropyl alcohol and remove dust and filth.
Check laserlens and is there some dryed liquid stains if there is try to remove those
with Isopropyl alcohol and swabs. Don't use any force and you can tear a top of swab little longer
(about one inch) and you get swabs which are much easier to use these kind of delicate cleanings.
Lubricate every moving part with lithiumgreese don't make any mess.
This last fix is for most desperate ones.
Connect the power cable and push eject and be carefull because
you can get fatal electric shock.
Disconect power cable. You can use extension cord which have on/off powerswitch.
You can see six tiny trim pots.
First take photo of those pots so you can undo all changes.
Change only one pot and only about 1/8 of turn. Turn power on and test if you make it worst or better.
If you think you fixed the problem that is not the case ... yet.
Then you have to make finall test and play a lot of music cd:s and after that you have fixed the problem.
Make notes which cd:s and what track your player don't play properly and use those
cd:s to testing those trimpot changes.
Posted on Dec 30, 2009
  • 3 Answers
SOURCE: I have a technics 5 changer CD player, model#
You ever get a solution to this, mate?
I have the same freaki'n issue with mine all of a sudden. Suspect the power supply's not delivering enough power to rotate the spindle-motor anymore, cause if I take this motor out and connect it to a 1.5V battery, it runs...
let me know if you've found the solution please on: tobie dot steyn at gmail dot com.
Posted on Mar 25, 2010
Technics sl mc410
The Optical Pickup(laser) has worn out. When you place a disc in the drawer, it has to load and read the TOC(table of contacts) if if can't read that, it assumes there is no CD in the drawer and stops or ejects.
Aug 28, 2014 | Technics Audio Players & Recorders
I have a Technics CD changer SL-PD867 it will not play re writable disc's all other disc ok
You should realize that this player is about 20 years old.
It was not designed to read CD-R or CD-RW media.
The signal from these media types is different from audio CDs you buy.
May 11, 2014 | Technics SL-DZ1200 CD Player
I have a Technics CD changer SL-PD867 it will not play re writable disc's any other disc ok
Not all CD players can or will play CD's burned in a PC. Sometimes the CD player is to old, so not compatible with these CDs. Sometimes the player just does not play these CD's, because of rights protection.
A CD burned in a PC is less reflective than an normal music CD. Normal CD's do have a metal coating and are highly reflective. Burned CD's have a dye, and where the laser burned the dye, it only changed colour. Making it less reflective.
All modern CD playes should be capable of playing CD r's. But the player that is really compatible, is labelled CDr and CDrw compatible.
I have a Technics SL-PG480A CD player. It won't play CDs down loaded from i tunes. These CDs will play on another newer Sony. The Technics plays other commercial Cds without problem both before and after...
This player will not play either MP3 or MP4 encoded CdRs. It is a good 18 years old now and such things were unforeseen back in the day. The newer sony may well be MP3 compatible. You could convert MP4 to standard audio types on your pc via any number of software applications.
Dec 23, 2010 | Technics SL-PG480A CD Player
My technics sl-p770 doesn?t recognize the loaded CD.A cd is alway spin but not any track in audio cd.
Try cleaning the lens with a cd/dvd lens cleaner disc. Another thing of note....some cd players simply will not recognize homemade cds, or dics that are not audio discs, or if they were made on a computer.
Apr 15, 2010 | Technics SL-PS770D CD Player
Cant get Technics SL-PC503 to play cds
Clean the LENS with a DISC CLEANER.
Jan 13, 2010 | Audio Players & Recorders
Technics dv290 system
i once had a panasonic dvd player which displayed the same code H02 and used the same drive mechanism as your player. this turned out to be a worn spindle motor and once replaced, all worked fine. you may well have the same fault. hope this helps?
Sep 06, 2009 | Technics SC-DV290 System
When Making A CD To Play On My technics SL-PD8 It
If thhis happens quite often , and does not depend on the media, then it is usually a dirty lens problem. The lens is dirty or scratched and sometimes cannot read CD TOC (table of content).
If this happens only on reocrded CDs , try changing the media used. For example if you used +R, try with -R.
If this happens on all media, then try cleaning the lens with a lens cleaner CD or blowing some canned air on the lens.
See: CD and DVD Lens Cleaner...
May 02, 2009 | Technics SL-PD8 5-Disc CD Changer
How do I play full random mode
the feature you are looking for is titled shuffle. it should come up in the menu
Nov 19, 2008 | Technics SL-MC4 61-Disc CD Changer
110 people viewed this question
 Grubhead
Grubhead
