Question about Dryers
Dryer Won't Start
This morning, the dryer turned on with no problem and I left it to do its thing. I returned about 15 minutes later and the dryer had stopped after about ten minutes. I tried to restart it, but no luck. When I push the 'Start' button, I hear a momentary shifting sound from behind the front panel, but nothing else. After work, I'll check the circuit box to see if the breaker popped, but, with hearing that sound, I'm thinking the dryer is getting power - unless that's just some sort of mechanical action caused by pushing the 'Start' button. Any ideas?
  • Cam Kirmser
    Cam Kirmser Nov 10, 2014
    The dryer is a Kenmore Limited Edition, about 10 years old. I had added the name to the form when I filled out the question, but it doesn't seem to have made it to the forum.
  • 932 Answers
Cam,
One thing you can check on if the circuit breaker is okay is to see if the drum turns freely. If the belt is still intact, you should have some resistance to turning the drum by hand. Many dryers have a safety in them that if the belt breaks the dryer will stop and not restart until the belt has been replaced. Hope this helps!
Posted on Nov 10, 2014
  • 9 Answers
SOURCE: dryer heats up but won't turn
Perhaps you have a broken drum belt
Posted on Jun 24, 2008
huuum
  • 750 Answers
SOURCE: dryer shut off towels were
Hello mdonettaYou said,
Dryer shut off towels were not yet dry, turned dial to restart dryer acts as if it isn't getting power I closed door and pushed start button. Nothing! Checked breakers and power cord at outlet all checked okay. Any ideas.
yes, try unplugging the power cord or turning off the breaker for 5 minutes. Either will due. Some times the system needs to be reset!
If this does not work there are internal fuses that can be replaced!
Let me know how it goes!
Huuum
Posted on Sep 19, 2008
aborcass
  • 2651 Answers
SOURCE: Kenmore Dryer Model 66801692
at leas 15 yrs old??? think it's done its time, its a great machine andwould reccomend replacing with a whirlpool/kenmore unit again.no tworth servicing in my opinion, average call here in new york 150-225, anbd those are for simple issues. id rather put money into new unit! bit be sure to check your venting id say 85% of dryers taking too long to dry are vent related issues
Posted on Nov 13, 2008
barkencoa
  • 3463 Answers
Depending on the make of dryer,there are several possibile reasons for this.
First and foremost, could be a faulty motor- faulty start capacitor, Faulty start relay.
Without more information I cannot be more specific.
Hope this helps.
Please leave feedback.
Thanks.
Posted on Nov 30, 2008
SOURCE: Whirlpool dryer model LEQ8800JQ won't start when push start butto
I posted today (Jan 2, 2009) that I had same problem. Handyman tested for blown thermal fuse, etc and everything was fine. He said I have to replace the timer switch .. well guess what - I fidgeted with the start button (on/off) hard a few times while simultaneously pressing & releasing door switch and it did the trick. In my case the problem was most likely with the start button. Dryer is working fine now!
Posted on Jan 03, 2009
I have a bran new Admiral dyer that won't work
The dryer may have been wired incorrectly, e.g., 115v rather than 230v.
May 23, 2017 | Admiral Dryer. 6.5 cu. ft. Electric Dryer...
Why does my dryer keep turning itself off before end of cycle?
If the dryer makes a motor growling noise at start up and shut off a short time later then it is probably a bad motor bushing and that will nessesitate a motor replacement. Bruce
Sep 27, 2012 | Dryers
I have a LGR5636EQ3 Maytag dryer that will not heat up and the timer is not keeping correct time. Dryer will run but longer than preset time and no heat. No click noise when started. I had dryer set at 60...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Oct 13, 2010 | Kenmore 73952 Gas Dryer
Dryer stooped working suddenly.
Replace the fan belt that turns the dryer drum. Use only the genuine replacement spare part for your dryer.
Jun 07, 2010 | Frigidaire GLER331A Electric Dryer
Whirlpool estate electric dryer model teds680eq1 starts spins heats up then quits 15 minutes later
The operating thermostat has probably failed. When the dryer haets up, it gets too hot and the high limit thermostat turns the machine off. After it cools down, it will start, again.
Apr 15, 2010 | Whirlpool Dryers
Whirlpool gas dryer heat goes on then off then on again
should have electronic igniter that light gas after turned on.
Jan 03, 2009 | Kenmore 73952 Gas Dryer
Dryers Logo
55 people viewed this question
Top Dryers Experts
