Question about Mercedes C-class C230 C240 C350 C55 Exterior Stainless Steel Chrome Pillar Posts Trim Set 2005 2006 2007
My Mercedes Benz C240 indicates " Break Assist System Visit Workshop. I have since replace the steering angle sensor and the switch beneath the break. The indication disappeared for but re-appeared ne
My Mercedes Benz C240 indicates " Break Assist System Visit Workshop. I have since replace the steering angle sensor and the switch beneath the break. The indication disappeared for but re-appeared next day. Car drive well though. What should I look out for?
  • 15 Answers
If you want this cheap and easy, I recommend you take it to your local dealer, make them pull out the codes for you, and then you can easily find out what the code means by using google. then you attain and replace the part mentioned for the code
Posted on Nov 10, 2014
2 Suggested Answers
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
small6363
  • 18413 Answers
SOURCE: Changing The Power Steering Filter & Fluid On A mercedes-benz
go here for help > http://www.benzworld.org/forums/w124-e-ce-d-td-class/1657821-how-change-power-steering-fluid-filter.html
Posted on Oct 01, 2012
My car is mercedec benz 2001 c240 avangarde have a problem ESP How can fixe my car
In your car Electronic Stability Program system included many different sensors (yaw-rate sensor, steering angel sensor, body acceleration sensor, some more) if ESP visit Workshop message appear on your instrument display It's very hard to say witch sensor could be the fault without right diagnose most common faults are either steering angel sensor or yaw-rate sensor might be some other sensors if you replace yaw-rate sensor it's need to be calibrate by diagnose computer, if replace steering angle sensor it's need to do right way otherwise when you tern steering wheel fully left or right it will brake at first time then you have to be replace another one so like to advise you to get right diagnose and repair buy Mercedes specialist if do some thing wrong it's be more cost to you if you get right place to do it only you have to pay once.
Jun 15, 2011 | 2001 Mercedes-Benz C-Class
ESP warning light is indicating. Please advise what could be the problem
Dec 15, 2010 | 2007 Mercedes-Benz E350 4Matic Wagon
Hi i have 2003 Mercedes Benz S 500 i have
Nov 16, 2010 | 2003 Mercedes-Benz S-Class
2006 c280avantgarde, ESP light is on, any idea of fault and what it would cost to repair?
In your car Electronic Stability Program system included many different sensors (yaw-rate sensor, steering angel sensor, body acceleration sensor, some more) if ESP visit Workshop message appear on your instrument display It's very hard to say witch sensor could be the fault without right diagnose most common faults are either steering angel sensor or yaw-rate sensor might be some other sensors if you replace yaw-rate sensor it's need to be calibrate by diagnose computer, if replace steering angle sensor it's need to do right way otherwise when you tern steering wheel fully left or right it will brake at first time then you have to be replace another one so I would like to advise you to get right diagnose and repair buy Mercedes specialist if do some thing wrong it's be more cost to you if you get right place to do it only you have to pay once.
Nov 10, 2010 | 2006 Mercedes-Benz C-Class
What is the ESP malfunction and how do I fix it
In your car faulty Electronic Stability Program system, it's included many different sensors (yaw-rate sensor, steering angel sensor, body acceleration sensor,wheel speed sensors and some more) if ESP visit Workshop message appear on your instrument display It's very hard to say witch sensor could be the fault without right diagnose most common faults are either steering angel sensor or yaw-rate sensor might be some other sensors if you replace yaw-rate sensor it's need to be calibrate by diagnose computer, if replace steering angle sensor it's need to do right way otherwise when you tern steering wheel fully left or right it will brake at first time then you have to be replace another one so like to advise you to get right diagnose and repair buy Mercedes specialist if do some thing wrong it's be more cost to you if you get right place to do it only you have to pay once.
Oct 19, 2010 | 2006 Mercedes-Benz E-Class
My c200 kompressor has a problem with the ESP,how can i fix it?
Sep 03, 2010 | 2002 Mercedes-Benz C-Class
My 2002 c240 stalls when going up mountain road or if it is really hot outside with a/c on.
when your car stall check how the coolant temp by using multifunction switch on steering wheel you can see on instrument cluster display rang should be between 80 dig to 95dig if it's withing the range check crank angle sensor, normally crank angle sensor play when it's too hot if it's play need to be replace it's bit hard to do in 112 engine in c class.
Aug 25, 2010 | 2002 Mercedes-Benz C-Class
My mercedes E320 write in the display that i shall visit workshop because of break lining wear, is it dangerous to drive the car now? and what is exactly break lining wear?
Your car has a sensor on the brake components which detects when there is low brake life. Assuming your brake system is functioning normally; there will be no initial safety hazard/danger. You should have a professional inspect brakes ASAP because if you wait too long there may be additional damage that could have been avoided with a more expedited inspection.
Apr 15, 2010 | 1998 Mercedes-Benz E-Class
Bas esp light on the 2002ml
it's the brake switch, located behind the brake bedale , just replace it and every thing will come to normal.
Jan 03, 2010 | 2002 Mercedes-Benz M-Class
Mercedes Benz C180 Fault Message Brake Assist.Visit Workshop BAS
Hi there
BAS is the Brake Assist System and if there is a malfunction it would only come into play in an Emergency stop while applying full pressure. BAS applies full braking force because people tend to lighten up their pressure on the pedal in these situations. I would suggest that the best thing to do is go to a Workshop or Service Center and have it checked out. Please remember to put a good rating on my profile.
Kind regards
Dustin Ellse
Jun 03, 2008 | 2001 Mercedes-Benz C-Class
Mercedes C-class C230 C240 C350 C55 Exterior Stainless Steel Chrome Pillar Posts Trim Set 2005 2006 2007 Logo
66 people viewed this question
Top Mercedes-Benz Vehicle Parts & Accessories Experts
Timllfixit
xxxxxx xxx
Are you a Mercedes-Benz Vehicle Part and Accessory Expert? Answer questions, earn points and help others
