Question about Visual Land Prestige 7 ME-107-8GB 7" 8 GB Tablet Computer - Wi-Fi ARM
How do I reboot my tablet after battery dies?
My tablet said low battery so I plugged it to charge it. The following day when I unplugged it the tablet would not turn on.I changed and plugged it on another outlet and no change.the tablet is one month old.thank you .
  • Visual Land Master
  • 2,072 Answers
On most tablets a hard reboot simply requires pressing and holding the power button for about 20 seconds. On some tablets there may be a pin sized hole on the back, try the power button first if not consult your manual before start trying holes.
Posted on Nov 28, 2014
My tablet won't even charge or turn on
it's a factory thing, all You need to do, is open your tab, remove the battery cable for about 10 mins and plug it back again, unplug the screen from the motherboard, and charge it for about, two hours, then plug back the screen connector, and turn it on, if you see it works, turn off the tablet again, and plug in the power cord again, you'll see the charging animation starts, leave it charging for the time you think it's necessary to reach 100%, unplug the cable and turn it on, your tablet is alive, the only problem I've found about this, is that you'll need to turn the tablet completely off whenever you want to charge it, and finally this, VERY IMPORTANT! When your tablet is below 15 or 10% battery, charge it, because if you let the battery die, probably you'll have to do all the steps again.
You need more help give me a call at 1800-204-4427...
Sep 13, 2017 | Tablets & eReaders
RCA 11.5. Why has it stopped working?
will it works plugged in. if so I have to think the battery is junk .
Oct 06, 2015 | Tablets & eReaders
Tablet not charging while plugged in
Turned off the tablet, unplugged the charger and kept the tablet off for about 30 minute to one hour, plugged in back the charger, then turn on the tablet. After that I you might see the tablet started charging. Good Luck.
Jul 10, 2015 | ASUS MeMO Pad HD 7
Someone please help me reboot my mid m9100 android tablet
If the unit is frozen, it might be easiest to let the battery completely die. Most low end tablets can only be hard reset by taking them apart and unplugging the battery. Once the battery dies you can plug it in and charge it and reboot.
Apr 27, 2015 | Tablets & eReaders
Why did it charge only 13% all day plugged into an electrical outlet?
The cords go bad, check a different cord and plugin.
Mar 11, 2015 | Tablets & eReaders
I turn my tablet on then it switches it self off
Sounds like it does not have enough battery power to stay on. If you have not tried to charge it, you should try that first. If you have, it sounds like it is not getting charged or not holding a charge. Could be bad AC power source, bad charger, bad charger connection or bad battery. Take steps to confirm that each of these are good. If all of these are good, sometimes the tablet can become so discharged that it will not allow itself to charge. When they are in that state, sometimes you can trick them into charging again by repeatedly disconnecting and reconnecting the charger as follows: With charger plugged in to AC power source, connect the charger to the tablet. Pay attention to the screen or LED or whatever indicator your tablet has to let you know it is charging. You may see it momentarily indicate charging, or maybe not at all. Then unplug the charger from the tablet then immediately plug it back in and pay attention for the charge indication again. You may have to do this a bunch of times (like 20) until you see the indication that it is charging. When you do get the indication, stop unplugging and re-plugging and let the tablet charge for 24 hours (to a full charge). This trick doesn't always work. Sometimes the battery or charging circuit or an internal connection is bad and no amount of unplugging/re-plugging will fix a hardware problem.
Nov 17, 2014 | Tablets & eReaders
Micro Cruz Tablet Wont hold charge
Well, I think you should change the battery of your tablet PC. You must have charged the tablet for more than enough time several times. so the battery is damaged. or, the battery must be used for a long time!!!!!!
Jun 27, 2012 | Micro Innovations Velocity T103 Tablet PC
Visual Land Prestige 7 ME-107-8GB 7" 8 GB Tablet Computer - Wi-Fi ARM Logo
192 people viewed this question
Top Visual Land Tablets & eReaders Experts
Steve Mason
alex metro
alex metro
Lawrence Oravetz
Are you a Visual Land Tablet and eReader Expert? Answer questions, earn points and help others
