Question about Baby Gear
Why does internal fuse on stafford 501 controller keep blowing
Controller for pottery kiln
    Scholar:
  • 68 Answers
Http://www.staffordinstruments.co.uk/files/install501.pdf
From the manual
This indicates an electrical fault in the control
circuit. The kiln has been on zero power for 15
minutes but the temperature has not fallen by at
least 1°C. Control contacts may have failed closed (e.g. welded). TURN OFF THE KILN [Error 4 should be present]
Posted on Nov 10, 2014
I need an owners manual for modet lt-3k kiln
Do you mean the Dawson LT-3K kiln sitter, a control and monitor for the ceramic kiln? The manual for this is on the product page: http://www.paragonweb.com/ManualInfo.cfm?CID=42 . The direct link to the manual is http://www.paragonweb.com/files/manuals/ACF1B.pdf .
If you need information about the kiln, then please check that model number and add a comment with that information. If your kiln is from Paragon, then try http://www.paragonweb.com/Instruction_Manuals.cfm for a manual. Paragon makes the Dawson LT-3K.
I hope this helps.
Mar 26, 2017 | Cars & Trucks
Tip
Getting Started with Pottery
Other than just being famous for the scene in the movie Ghost, pottery is a wonderful craft that can be incredibly relaxing and creative.
It is not easy to get started with pottery at home without some basic knowledge and tools, so you might want to begin with a short course in pottery at a local center.
But once you get started, here are some tips for you:
    1. Low-fire clays are good for bright colors and detailed patterns. But they need a good glaze to help seal them against water damage.
    2. High-fire clays are much more waterproof, just not as good with bright colors.
    3. Pottery by hand this is the simplest method when you do not have a potters wheel and are keeping your projects small. You take a small amount of clay and work it with your hand. Once you have shaped it, you can use a damp sponge to smooth the surfaces.
    4. A potters wheel is not something most people have at home but if you do get access to one, it is great for round, symmetrical objects. If you use a potters wheel you will need a kiln at the end for finishing.
    5. Once you have put your pottery in the kiln (get advice about how many hours your particular piece needs), you can now paint and glaze your piece.
    Pottery is a complicated art form that has many stages but it is really worth it when you get to produce a piece that you have made yourself from start to finish.
    Good Luck
on Dec 09, 2013 | Crafts & Hobbies
2006 Buick Rendezvous 10 Amp ABS fuse keeps blowing. What could be the problem?
There is a shot to ground in the ABS system ! If familiar with electrical trouble shoot , find a wiring diagram an test the B+ power circuit ! That fuse supply's power to the electronic brake control module , if no short on wire from fuse box to brake control module , the module has an internal problem .
Jul 26, 2016 | 2006 Buick Rendezvous
Whats the problem of my onkyo m-501 it has no power
unplugged with nO power cord connected,,after checking for any internal blown fuses, inspect circuit board for burnt resistors or blown caps, the resistors will appear to be laying on there sides and have multi colored bands around them look for burnt or discolored ones, blown capacitors will look like tiny barrels with lids a flat top indicates a good capacitor as any humped or bulged or rounded top would indicate blown cap , if not more than a couple you may be able to replace these with success, be careful always Unplug from power before servicing electronic componants.
May 17, 2014 | Onkyo M-501 Amplifier
What`s the problem of no power of onkyo amplifier m-501
EITHER blown caps or burnt internal fuses, look around on the circuit board for capacitors with rounded or humped ends, find and check internal fuses and test them
1993 Goodman gas furnace keeps blowing fuse when first turned on
You can take each thermostat wire off the control board and use a ohm meter and test to ground, should not have any resistance. Another way is turn off power take each wire off the board, then place one wire at back on the control board terminals ome at a time, untill the one you get to the one that blows the fuse. If the wires check out good sometimes the thermostat itself can have a internal short and cause the fuse to blow.
Nov 27, 2012 | Heating & Cooling
Hello........ looking for a schematic for Bose 501 series 3 speakers. I need to replace the fuse in line with the tweeters.... its blown & does not have a value on it (unmarked, quick blow, twin lead,...
Did you find a solution? Dunno if it's much help, but I just today picked up some 501s - Series I I think - ugly heavy brown material grilles - but with a manual! No fuses in these, but booklet recommends installing your own in-line fuse holders (!?). Specifies a BUSS AGC-3 fuse for amps under 50wpc; or a MDL-2 fuse for amps over 50 wpc. Can be placed is series with either or the two signal wires. Very strange.... Robin
May 14, 2011 | Bose 501V Speaker
Fuse keeps blowing
If fuse keeps blowing that means that there is a shortage on AC wiring or switch controlling the air conditioner.
Also an abnormal power draw from AC caused by an internal fault on AC can cause the fuse to blow.
Test wiring and switch with a voltmeter, the most common is that there is a short to ground between wiring and car body somewere.
Apr 29, 2009 | 2000 Chevrolet Malibu
Baby Gear Logo
Top Baby Gear Experts
Dorel UK
Dorel UK
Jennifer Rock
Jennifer Rock
Are you a Baby Gear Expert? Answer questions, earn points and help others
