Question about Camping, Backpacking & Hiking
All of a sudden high sound on my black and Decker 2000 W Hepa Filter
    Scholar:
  • 68 Answers
Do you have a model number? I found some sound level maximums on many devices of B and D found here plug in your model and look for a db level,
black and Decker 2000 W Hepa Filter http://www.blackanddecker.com/Product-FAQs.aspx
If this is a vacuum then changing the filter and a complete interior cleaning might help it may well be a noise from some debris stuck and oscillating or it could be a bearing, a bearing journal or a bearing housing that is worn, the bearing may be spinning in the housing, or on the shaft, we need more information such as model and other info, to narrow down what rotational parts are involved Try this turn unit on, when sound is present turn power off, does the noise disappear with the removal of power?
Or does the sound start to lower in gradual amounts when the power is removed, if this is the case it is some sort of rotating device like a bearing, pulley, etc need to confirm just exactly what device you have to be specific
Posted on Nov 10, 2014
My 2000W hepa Black and Decker Vacuum cleaner
the power head might be binding or possibly the belt slipping
Sep 17, 2013 | Black & Decker Vacuums
I have been looking to buy an air purifier and people keep telling me to get a HEPA. What does this mean?
HEPA is a type of air purifier. It stands for high-efficiency particulate air. To qualify as a HEPA filter by government standards the filter must remove 99.7% of all particles larger than 0.3 micrometers from the air. The following site lists the top 10 HEPA purifiers available online - http://www.air-purifiers-america.com/AP101_top10.asp.
Jul 12, 2012 | 3M "Replacement Filter, 11 7/8 x 18 3/4"
Will not turn on. will not charge . when you plug in charger, the battery lights on the side all flash, and you have a loud clicking sound.
In March, 2006, Black & Decker purchased Vector Products, Inc. Since the acquisition, Black & Decker has assumed the manufacturing of all Vector products. For customer service and warranty information for Vector products, please contact Black & Decker Customer Service. www.blackanddecker.com/CustomerCenter/Default.aspx
Jul 06, 2010 | Vector Power On Board High Intensity...
Hepa filter stopped on Hoover Windtunnel 2 Model #U8361-900
This has a simple solution IF you have a air compressor with a high pressure nozzle. Outside the house, first remove the Dust bin completely and lay the unit down with the dust bin area up. now start blowing the nozzle at the hepa filter, Alot of dust will come out. Now start to rotate the filter while blowing the dust out. The filter will move one way easier, When there is no more dust reinstall the dustbin and check the suction and the rotation of the filter.
Tony
Nov 17, 2009 | Vacuums
Black & decker parquet 1800w hepa h13 need
I'm not sure what bag your referring to. The only bag for this is the carrying bag. So I have to assume you mean one of the filters.
There are three filters for this vacuum.
  • Primary Filter.
  • Exhaust Filter.
  • Secondary Filter Element.
I have included a link to a site that carries the replacement parts and a diagram of the vacuum.
Hope this helps.
On another note If it doesn't help I really don't feel to bad because I'm in Detroit Michigan. And I'd rather have a dozen useless vacuums hanging out in New Zealand any day. :)
Find me a job there and I'll buy you a new vacuum. :)
http://www.ereplacementparts.com/black-and-decker-hv6000-type-opp-corded-hand-vacuum-parts-c-4167_8887_10329.html
Oct 17, 2009 | Black & Decker HV6000 Bagged Handheld...
Vector 2000 Max inverter VEC054D turns on, LED
sounds like my inverter im going to change the mofset or.triod it has 3 prongs.
Jul 23, 2009 | Black & Decker Electronics - Others
WindTunnel HEPA Filter won't spin
I just fixed my HEPA filter not rotating!!
It involves taking apart the vacuum HEPA area. All screws are the same size. There are a LOT of 'em. Really straightforward putting it back together too.
ok, once you take the HEPA canister area off the vacuum, careful with the wires! Unplug them from the controller board. You open up the HEPA chamber by removing more screws until you see where the motor that turns the filter is mounted on the side. Remove motor from the green chamber. Note where the washer goes. Once the motor is off, you'll see that the center hub that drives the HEPA filter is rounded out. What I did was jam little bits of aluminum from a pop can into the space between the circle and the square to force the walls back to square. I started by folding a little piece of aluminum over and over so it was about three layers thick. Jammed that in. That wasn't quite enough thickness so I shoved another piece with it. If you can find something that is about 4 times the thickness of a pop can aluminum, that'd probably work too. Slight wedge shape on the tip would help. Any sort of tiny shim.
To test your work, just put a couple of holder screws into the HEPA cannister housing, plug in the cover/switch, plug in the HEPA moter. Turn it on for a few seconds to make sure the filter turns. Then you can add more thickness to the hub or put things back together.
Sep 02, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Vacuum Cleaner Bags
REQUIRE REPLACEMENT OF DUST BAG BRAND BLACK AND DECKER MODEL VB 1800 XE HEPA 13.PLEASE SOLV THIS PROBLEM OR COMPATIBLE DUST BAG
Aug 27, 2008 | Black & Decker HV6000 Bagged Handheld...
Weedwacker wont turn off
We have a Black and Decker CST 1000 and other than the convenience of no cord, it constantly has problems. Won't hold a charge, spool holder cap broke and we can't find the part, handle cracked and finally broke. We have a black and decker blower and it won't turn off either. Fortunately it's corded so we can just unplug it. No more Black and Decker for us.
Jun 05, 2007 | Black & Decker String Trimmer Cordless 12"...
Camping, Backpacking & Hiking Logo
61 people viewed this question
Top Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Are you a Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
