Digital Connectionz UPS continious Beeping when my UPS switched on. ( No Load In UPS ) It is happen when Chargin..i replace the battery bt same thing Happening.. All LED are Flashing..What to Do.? Please Help
    Scholar:
    New Friend:
  • 69 Answers
How old is it? Have you contacted the manufacturer? The user manual will often help you define the beeps.
Personally I bet more then just the surge circuit was damaged.
Posted on Nov 27, 2014
4 Suggested Answers
  • 192 Answers
SOURCE: My Liebert PSA itON 600 UPS keeps beeping when i turned it on
To figure out what's wrong with the UPS, first you have to do a few things.
When calculating the rating a UPS can handle, it's voltage x amperage. If it's Watts multiply the number by 1.67 to give the rating of the device.
Add up all the devices (use the power supply rating in the computer) as well as any other device, and add them up.
If this rating was exceeded, then you have overloaded the UPS. If it was too long that you did this, then you wore out the battery.
When a UPS beeps even when not connected, that means the battery is very weak.
If the battery is more than 3 years old, it will need to be changed. If the online tests of the unit were done and the battery doesn't need replacing, then other parts of the UPS need fixing.
Check the battery.
Posted on Jul 27, 2009
tech240
  • 169 Answers
SOURCE: Bypass alarm flashing on a Powerware 9125 UPS
it is possible the bypass alarm is flashing because the i/p and o/p are not within range to switch without a break.
they need to be nearly equal in volts and freq so when the ups switches the ups o/p is continuous.
you should be able to check this with your ups software.
Posted on Sep 16, 2009
  • 68 Answers
SOURCE: Overload LED lit, constant warning tone, no load
you may have to many things plugged into the ups, it is not good to plug a power bar into one of the outlets of one of these as you are OVERLOADING the device with more power than it can produce
Posted on Oct 24, 2009
Sukam 800VA inverter continuously beeping with 3 lights blinking. What could be wrong?
check batry voltage or 2nd problem in realay and capicitors or
3rd ic before that disconnect output line
May 05, 2014 | Computers & Internet
We had a power outage for about 45 minutes a few days ago. Ever since then the Powerware 3110 has been beeping. I turned it off and left it plugged in overnight and when I turned it back on the beeping...
This could be several things, fortunately the device should actually be helping you to diagnose the issue. There are different beeps for different issues. They are as follows:
1 Beep Every 5 Seconds = Power Outage\Loose Plug Connection\Tripped Circuit Breaker\Power Cord Damage or Failure
2 Beeps Every 5 Seconds = Low Battery Alarm
3 Beeps Every 5 Seconds = Battery Needs Charging\Service\Replacement
3 Beeps Every 5 Minutes = The Battery is discharged and battery power is unavailable (If this continues battery replacement may be necessary)
1 Beep Ever 1/2 Second = Power Requirements exceed the UPS Capacity (remove some equipment to lighten the load on the unit)
Continuous Beep = Short Circuit / Input Voltage out of Range / UPS Fault (Likely replacement of entire unit)
That should help diagnose the actual issue. If it turns out the battery needs to be replaced they can be found online for around $20. A simple google search for Powerware 3110 Battery should return what you're after. Good luck!
May 05, 2011 | Powerware 3110 UPS System
After i switch on the ups there are continuous beeps with red light instead of the normal green. if i continue to use the beeping stops after sometime but the red light persists. But then again the beeping...
ups with 300 watts can only back up 1 computer, though it can handle 2 computers but not too long. your ups battery life span are good only for 2 to 3 years. for battery replacement you can visit the nearest service center and ask for battery replacement. it will not cost you much.
Feb 10, 2011 | APC BE500U ES 500 USB BACK-UPS 500VA/300W...
Ups starts beeping
Is there any indicator lights ON showing the fault condition?
This could indicate that the battery has a low charge. Even if you switch off the mains supply and it switches over to the battery, the UPS may shut down after a short time as the battery power (charge) runs out.
If the battery is more than 3 years old then it may be due for replacement.
May 10, 2010 | Powercom BNT-1000AP (dspcmbnt1000ap) UPS...
I have an APC XS1300. One year old. Very few
Mines, two or three years old and doing the exact same thing, you ever figure out what happen or how to fix it? I took the battery out and it reads 16 volts. I put a 2 amp load (fan) on it and it pulls fine, so I'm reluctant to buy a new battery pack for it now.
Feb 01, 2010 | APC BACK-UPS XS 1300VA LCD 120V...
Check the battery.
Jul 27, 2009 | Liebert PowerSure ProActive PSA700 UPS...
Unit keeps beeping even when unpluged. over load
UPSs will beep when unplugged to tell you that the mains is off! Overload should reset if you disconnect both the load and the power.
Jun 30, 2009 | APC Back-UPS CS 500 UPS System
Keeps making a beeping noise
Hi, if the unit is fairly new, you may want to claim warranty check or replacement. If it has been used for some time, it may be that: 1) the battery is dying, 2) not getting enough charge or 3) too much load. For 1, battery replacement might be required. Care should be taken since this requires opening the enclosure, removing the old battery (might have acid leaks) and replacing with a new one. For 2), any competent techncian could diagnose and repair. For 3) try removing all other loads to the UPS and just run the PC with the monitor and see if the problem still exist. Hope this works for you and please let me know how things trun up. Regards.
Apr 09, 2007 | Powerware PowerRite Plus UPS System
Computers & Internet Logo
83 people viewed this question
David Payne
David Payne
