Can a hp pavilion dv5-1127cl power port work in a
Can a hp pavilion dv5-1127cl power port work in a hp pavilion dv-8000 (8113cl)? As I have not wanted to purchase yet another power cord
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 884 Answers
Hi there
I think in this particular case it might not be wise. The power blocks for these two appear to be different wattages (65 & 90 respectively) and also the connector to the laptop does not look to be the same, in which case damage to the power inlet socket of one or the other laptop could occur if you tried to fit it too energetically. I did find this eBay seller who gave quite a list of compatible laptop models for the power supply he was selling, but although the DV7 series is there, the DV8 series isn't.
AC Adapter Charger for HP Pavilion DV5 1127CL DV5 1128CA Power Supply
I think you would be better to get a power supply that exactly matches to prevent potential future problems.
Perhaps not the advice you were hoping for, but I would get a new one for whichever machine you need it for, and make sure that compatibility with your machine is specifically stated.
Cheers
Posted on Nov 10, 2014
  • David Warner
    David Warner Nov 10, 2014
    Well thank you very much for the informative answer about the power cords I really appreciate it. Now I just need to see if the video card or if any of components in the dv8113cl will work inside my dv5-1127cl?
2 Suggested Answers
melnavz
  • 1226 Answers
SOURCE: hp pavilion dv 1000 sound driver for vista
hello!
im affraid to answer your question because in most cases you will rate me " thanks for trying" it hurt me but it's ok because i want to help you.
HP Pavilion dv1000 CTO Notebook PC driver here:
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=500515&lc=en&cc=us&dlc=en&submit.y=4&submit.x=7&lang=en&cc=us
If this "HP Pavilion dv1000 Notebook PC " im sorry no driver for vista, verify this http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=435618&lc=en&cc=us&dlc=en&submit.y=4&submit.x=7&lang=en&cc=us#
but anyway, try the driver of " HP Pavilion dv1000 CTO Notebook PC " above.
melnavz
Posted on Mar 07, 2008
Does HP Pavillion DV 9000 laptop has a HDMI port for linking up with a HDTC? - Sanjay
Sorry the HP Pavillion DV 9000 doesn't have an HDMI port.
Regards.
Jan 12, 2011 | HP Pavilion dv9000z Notebook
My HP Pavilion Entertainment PC will not turn on. If I hold the power button, the 3 lcd's blink but nothing else happens. I have tried a different charger and that didn't work either.
You most likely have a motherboard issue. Try this, remove the battery, hold the power button in for 30 seconds, and try to power up. If that doesn't work, you need to bring it to your local repair shop
Jan 03, 2011 | HP Pavilion DV7-1020US Laptop
My HP 9730US will not power up. When I plug the power supply in, the light goes off. The power cord works and is on another computer right now.
try without battery. if not work check the some burning smell near battery connector on laptop back.
the thing is all the dv xxxx models have AC power controller chip burning problem .have a possible to repair that, if not need to repleace the main board.
Dec 05, 2010 | HP Pavilion dv9730us Notebook
Bought new power cord for pavillon dv 1000 and
If the laptop runs on batter but cannot run on the AC adapter, you have a broken DC Jack. If you laptop cannot power up with the battery or flash low battery indicator, you laptop is dead.
Oct 30, 2009 | HP Pavilion dv1000 Notebook
Hp pavilion dv4000 usb port can't use
This error occures when a USB device draws more power than the USB port can supply.
To fix this problem, purchase a powered USB hub. Power up the hub and connect it to the laptop's USB port and then plug the USB device into the powered USB hub.
May 05, 2009 | HP Pavilion dv4000 Notebook
Wish to activate webcam for a newly purchase HP dv-7 Pavilion PC
Normal 0 Probably has corrupt driver.
Try disconnecting the Camera from the USB port and reinstall the CD software program. When the program asks you to connect the camera to the USB port, do so and it should work.
Hope this helps. Bud
Jan 04, 2009 | ASUS F3Jc-AP141C Notebook
USB Ports are not working
A USB device, such as a camera, scanner, or printer, loses its connection and stops working unexpectedly. The device may appear to work fine when Windows first starts up but later stops working. Use the steps in this document to resolve this issue. Disable power management on the USB hub To preserve power, Microsoft Window XP tries to disable USB when a device is not used. Under certain circumstances this function does not work and may cause USB devices to fail to respond when called. To resolve this issue, disable power management on the USB hub by doing the following:
  1. Click Start , and right-click My Computer .
  2. Click Properties , then click Hardware .
  3. Click Device Manager .
  4. Double-click the Universal Serial Bus Controllers branch to expand it.
  5. Right-click USB Root Hub , and then click Properties .
  6. Click Power Management .
  7. Deselect Allow the computer to turn off this device to save power .
  8. Repeat Steps 5 through 7 for each USB Root Hub.
  9. Click OK , and close Device Manager .
If this doesn't help download everesthome. Run the program click on the chipsets and google the northbridge for updates.
May 01, 2008 | HP Pavilion dv1000 Notebook
Supplying power to the monitor to get it to work
I think what you need is a "D" shell connector.. see if the one that fits your PC Power Supply will fit into the Monitor.. if so then purchase another the same. It's called a "D Shell" Power Cord.
Aug 20, 2007 | HP Pavilion F50 17" Flat Panel LCD Monitor
Sony HC40 - Burn DVD w/o Sony PC
Don't worry about the manual. You just need to get a firewire cable (since you have a laptop, you probably need a 4 pin to 4 pin cable, but check the port in your laptop to make sure it is a 4 pin. If the port size is the same as it is in your camcorder, you need a 4pin to 4pin cable). For transferring video to your laptop and burning DVD, use the software which came with your DVD burner. If you do not have one, try Dazzle software, it works well.
Sep 14, 2005 | Sony Handycam DCR-HC40 Mini DV Digital...
Computers & Internet Logo
52 people viewed this question
David Payne
David Payne
