Question about Motorola Mobility RAZR V3
Bluetooth Pairing I am trying to pair my Bluetooth headset to my Motorola V3,I go through all the steps the Phone picks up headset but when it asks to bond with the headset I select yes. it then asks for the Bluetooth pass key I type in 0000 keeps coming back with Invalid pin. I have also tried puting in the last four digits of the phone number.
  • bug76 Aug 16, 2008
    i cant pair with other phone for blutooth to send music to other phone
I have up loaded blue tooth from a cd bu i can not get a connection what is the problem it was working on my last pc
Posted on Nov 07, 2008
Cant conect to Bluetooth
Posted on Jan 20, 2008
  • 117 Answers
The pin code reuired is the one set up by your bluetooth headset manufacturer. Check your user manual for the headset for the correct code to use.
Posted on Jan 19, 2008
Need pairing mode for H12 .to sync to a new device What is K1 etc.?
The easiest way to find this information out would be to go on the Motorola interactive bluetooth pairing simulator: Motorola pairing simulator
This will ask what headset you have, and I've noticed the H12 is in a section titled "existing products", it's just a fraction down from the top of the webpage when it opens.
You will then be asked which phone make and model you have.
This will then take you to a very helpful interactive page which will walk you through the pairing process step by step.
I hope this helps.
Warm regards and a Merry christmas.
Dec 23, 2010 | Motorola Mobility Motopure H12 Bluetooth...
How do i place a h555 motorola bluetooyh in pairing mode
Power on headset by sliding the Call button
towards the microphone to initiate easy
pairing. After a few moments, the indicator
light will be steadily lit in blue to indicate
headset is in pairing mode.
On your Motorola phone, press (Menu) >
Settings > Connection > Bluetooth Link >
Handsfree > Look for Devices.
The phone lists Bluetooth devices it finds.
Select Motorola H555.
Select OK or Yes to pair your headset with
your phone.
Enter the passkey: 0000
Select OK.
When your headset successfully pairs and
connects with your phone, the indicator light
changes from steadily lit to flashing blue.
Troubleshooting: Make sure that any devices previously pairedwith the headset are turned off. If the indicator
light is not steadily lit in blue, turn off both the
other device and headset, wait 10 seconds,
then turn headset back on. Wait for the indicator
light to become steadily lit in blue, indicating
the headset is now in pairing mode.
User Manual
Aug 22, 2009 | Motorola Mobility Bluetooth Hands Free...
How to connect motorola bluetooth hs850 to motorola V3 chandrabose
How to pair a Motorola HS850 bluetooth headset How to place a Motorola HS 850 bluetooth headset into paring mode:
  1. Close the boom to turn the unit off.
  2. Hold down the call button until the blue light comes on.
  3. While holding down the call button, swing the boom open.
The headset is now in pairing mode, and you can search for it using your phone. When it asks for a PIN, use 0000.
Apr 10, 2009 | Motorola Mobility S9 Headphones
follow the steps below:
• Setting the headset into pairing mode
1) Ensure the headset is fully charged
2) The headset must be switch off
3) Press and hold the on button for +- 8 seconds until the light flashes red-blue
4) The headset is now in pairing mode
• Searching for the headset on the phone
1) Go to “settings” or “connections”
2) Select Bluetooth, then options
3) Select Devices and click add
4) The phone should search for any available Bluetooth devices and display what was found
5) Select the Motorola device and click add
6) You will be required to enter in a pass code which is standard ‘0000’
7) If successful then the headset will start flashing BLUE every few seconds.
• The headset is now paired with the phone
Hope this helps
Season's Greetings from Fixya!
Chris (ziraffa)
Dec 21, 2008 | Motorola Mobility HS850 Consumer Headset
How do I connect my h350 motorola bluetooth with my nokia 6275cel
Try video instructions on connecting Bluetooth headset to Nokia phones on under Electronics category (Motorola H710 headset). It should be pretty much the same for all headsets. Watch chapter on Pairing phone to headset (Nokia example) It shows you the steps and what the phone screen will look like on your phone as you go through the steps (activating Bluetooth option on the phone, then searching for devices (headset) and finally pairing the headset with your phone.
Dec 17, 2008 | T-Mobile 81339TMIN T?•MOBILE BLUETOOTH...
Motorola Bluetooth® Headset H555
This will vary depending on the model of your phone. First off, you need to ensure that you are using a bluetooth enabled phone.
On your bluetooth headset, hold down the power button down until the power light stays lit. This may take 5 seconds or more. Now your bluetooth is in pairing mode.
You will need to enter the settings and tools menu. From within that menu, you need to find either "connections" or "bluetooth" and select. Make sure bluetooth is enabled. There will be an option to add a new device.
Back to the phone, you want to hit "add new device". On certain models of phone you additionally have to select "search for devices". Your phone will recognize any headsets in pairing mode. When it is finished scanning, allow the phone to add your headset. It will ask you for the device pin code. This pin code will be 0000.
Jan 14, 2008 | Motorola Mobility Bluetooth Hands Free...
Motorola H350 User Manual
On your bluetooth headset, hold down the power button until the light stays on steady. (it will blink when you initially power it on, but continue to hold for another few seconds for the steady light!) Your headset is now in pairing mode.
On your RAZR, press Menu > Settings and Tools > Connections > Bluetooth > Handsfree > Look for devices. Your phone will then scan for any bluetooth devices that are in pairing mode. When your headset pops up on the list, highlight it and press ok to connect.
If the device asks permission to bond with the phone, select yes. It will then prompt you for a pin code. The pin will be 0000 .
Jan 08, 2008 | Motorola Mobility Bluetooth Hands Free...
Bluetooth pairing
1.Explore blue tooth devices from your motorola phone. will sure find your blue tooth headset.
3. Make sure your blue tooth headset is on pairing function select your blue tooth headset
Dec 22, 2007 | Motorola Mobility Bluetooth Hands Free...
Motorola v3
Not being cheeky buddy but I have the same pairing are you tapping in "0000". Also go into settings and headphone or carsettings and set to auto answer. Hope this helps M8
Sep 26, 2007 | Motorola Mobility H350 Wireless Headset
Motorola Mobility RAZR V3 Logo
284 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
