Question about Tecnik TKC8525 Double Oven
Grill on my tecnik tkc8525 tripping out my house electric. Any ideas ?
After a few mins grill trips out my circuit breaker
Probably heating element goes to ground when heating up. Suggest changing element.
Posted on Nov 10, 2014
Testimonial: "Spot on I have already taken out the element and found a split in it . New 1 arrived today from e4elements. Thank you ."
5 Suggested Answers
barkencoa
  • 3463 Answers
SOURCE: tecnik tkc8525/2 SMOKES OUT EVERYTIME IT IS TURNED ON.
It sounds to me that you have a build up of fat and grease,, and that is what the smoke is, the fat burning off the element(s).. If the oven is working o/k otherwise, then just let it burn all the fat and grease off.
Plz rate this solution.
thanks.
Posted on Dec 18, 2008
barkencoa
  • 3463 Answers
SOURCE: Bottom oven not working Tecnik 8525/2
To be certain the element is o/k , you need to test it with a meter.
The fact that it looks o/k proves nothing. If you know how to use a meter, then remove element from oven, and with the meter set on the continuity range, test across the terminals of the heater, if you get fsd, ( full scale deflectoin) then the element should be o/k.
If no deflection , then element is no good.
If in doubt, remove the wires from the element , and try the oven, if it does not trip, then it proves element faulty.
Plz rate my solution.
Thanks.
Posted on Jan 05, 2009
blackmar
  • 235 Answers
SOURCE: main oven trips electric when switched on top oven
If the fuse or circuit breaker is tripping it is most likely a short circuit in the oven element.
Posted on Feb 10, 2011
SOURCE: Have moved into flat with a Tecnik (built under) double oven TKC8525 which has no manual and all the temperature settings etc have been 'cleaned off'.
hi i Don't know how to work the grill can u please explain to me how ?many thanks
Posted on Jan 10, 2012
Neff u1421 double oven , both ovens work fine but the grill trips the circuit breaker after 5 minutes of getting hot
you need to check size of breaker the oven is wired too if this is to small it will trip also cable size
Sep 18, 2013 | Neff U1421 Double circotherm Electric Oven
Tripping rcd when oven gets warm aprox after 10 mins\
Hi this is a pretty serious and dangerous fault, please do NOT use it remove it from the Power, pull the breaker or fuse, and please call a professional electrician. You may have a Phase to Frame contact? In any event, it needs to be serviced.
Oct 12, 2011 | Tecnik TKC8525 Double Oven
Main oven causes trip switch to trip out when `I turn the dial to switch on. Top oven is fine.
Likely the element is shorted in the main oven. The Calrod elements short usually at the bends and if the breaker doesn't trip they burn a hole in them and arc. You can USUALLY see a different discoloration at teh failure point. Check both upper and lower elements as preheat probably uses both. Use a dental mirror if necessary to see under and over. Use bright light.
May 04, 2011 | Tecnik TKC8525 Double Oven
Main oven trips electric when switched on top oven works fine also grill . did notice that fan was making a noise
Feb 09, 2011 | Tecnik TKC8082 Electric Double Oven
When I turn on the electric grill it starts to warm up and then trips out the circuit. It is a new oven we have had in storage for a few years
I would suggest that there is a problem with the grill element, if it only trips out when using the grill, then it will probably need a new element fitting.
If the rest of the oven is working o/k, then that should cure it.
Dec 14, 2009 | Ovens
Grill broken only part working
You need to replace the complete element
Dec 24, 2008 | Tecnik TKC8525 Double Oven
Fan working grill working just no heat in siemens oven
hello the first thing that we need to look at is the electrical box thats is outside and see if there are any more braekers tripped. the clue is that everything work except the heat. thats 208/230 volt and the rest of the oven is 115 volt. e sure to take the breakers and push them all the way to off then back to the on position. if thats is the problem now you are going to have to call a service man to check out what is shorting and causing the breaker to trip.
Dec 23, 2008 | Ovens
Tecnik TKC8525 Double Oven Logo
Top Tecnik Ovens Experts
ashburton
Timllfixit
Are you a Tecnik Oven Expert? Answer questions, earn points and help others
