How do I fix the sprocket wheel in my la sardina lomography camera?
I got my La Sardina for Christmas 2011 (?) and before I got to use it, I dropped it. The viewfinder cracked a little but I saw no other damage. I finally used it a few days after that and it seemed to take pictures fine, but when I developed the film I was disappointed because only a few came out. It seemed to be at random. I know I was using it correctly because I triple check things. So, I took it in to this guy and he just looked at it and said the viewfinder was cracked, but he never saw that camera before he said... so obviously he wouldn't know much.
Just a little while ago I decided to pull it out of its hiding spot and take a look at it. Upon further inspection as I was trying to load the film I noticed that the sprocket wheel isn't turning as I turn the knob to load it.
So I am wondering how to fix that, and preferably try to fix it myself if I can. How do I fix it? Is there any way I can get step by step instructions to take it apart?
La Polaroid ha una batteria interna saldata sulla scheda madre (Altre marche e modelli usano una batteria tipo monetina, la Kodak ha una batteria saldata). Questa si ricarica usando le batterie principali. La batteria interna ha una autonomia di diverse ore. Il suo ruolo e' preservare le impostazioni.
Se il problema sussiste anche quando le pile nello slot sono cariche, vuol dire che la mini batteria saldata dentro la camera e' diffettosa, e non mantiene la carica. Una camera da 5 Mp oggi vale meno di 50 euro. Se la camera funziona non vale la pena ripararla.
Error de lente sinifica que hay un problema en la extension or retraccion de la lente. La placa base detecta que la lente no se puede mover y hay tienes el eror de lente.
Lo unico que se puede hacer es intentar ayudar suavemente el movimiento de la lente mientras que se encende o apaga la camera. Si esto no sirve, llama Kodak al numero que se encuentra en el manual de uso.
Aqui ay un artculo que trata el problema (en Ingles). Los codego son los de una camera Sanyo, la situacion es la misma que se encuentra en Kodac con error 102.
When this problem occur you need to set the memory card unlock or not
protected.
Remove the memory card from camera and you can see a small button in
the memory card, so you need to slide that to set the memory card unlock
or not
protected.
la camara no enciende y mantiene la luz roja del temporizador prendida, cuando quiero cargar la bateria no prende la luz verde y si la conecto a la computadora no se enciende ni reconoce la camara, en el manual no hay solucion al problema ni lo menciona
