Question about Dayton Wire Wheels Dayton Oil Fired Heater, 75 K BtuH 120 V - 3VE49
Fix a broken Oil-fired heater
My Dayton oil-fired heater wont the stay running? It seems like it isn't get enough fuel or enoughost air it starts and will run for a short time
My Dayton heater will not fire up and tries to fire and then shuts down tries to fire and shuts down blows smoke out the end
Check noggle for dirt, check fuel filter for dirt. Check al rubber hoses for leaks, Set air pressure All these will cause it not fire.
Dec 28, 2014 | Dayton Heating & Cooling
Will heater run on diesel?Heater will not start soon as power turned on and will not stay running.Red light starts blinking.
It MIGHT run on diesel but it will be a smokey affair. They are made to run on filtered kerosene which is a lot cleaner. Using diesel fuel will also hog it up very quickly.
May 07, 2011 | Dayton (3VE50) Oil Filled Liquid Fuel...
I HAVE A DAYTON 3VE49 TURN IT ON FAN RUNS GETS SPARK BUT IT SEEMS TO NOT BE GETTING FUEL I HAVE TO BLOW AIR THRU THE FAN PUMP HOSE TO FORCE THE FUEL TO THE SPARK I CHECKED THE LINES CLEAR THE PROP INSIDE...
Check the fuel lines and the nozzle. Make sure there are no leaks from the air/fuel lines at the nozzle fittings or air pump. The air pressure from the pump is no where near what you forced to the nozzle with an air compressor. You can push fuel past a plugged nozzle to get it to fire with your compressor, but the air pump can not even if it's new. Check the lines for leaks with soapy water. take off the nozzle and clean it to be sure it isn't plugged. Dont loose the spring inside to nozzle. Check the pressure at the pump testing port. You can buy a gage as descibed below at an ATV dealer. use a valve stem with 1/4 threaded end and a shrader valve at the other to adapt this for testing. Extra low pressure pencil-type gauge registers 1-20 psi in 1/2 lb. units. Do not use a standard tire gage, They are not accurate at low pressures.
Good Luck
Dec 23, 2010 | Dayton E48 Oil Filled Utility Heater
I have a 2E511C heater that wont fire up but the spark plug is firing
You probably already know this . The 2E511C was manufactured by DESA for Grainger, so you must follow these Reddy Heater troubleshooting tips.
It sounds like the heater is not getting fuel or the fuel is not hitting the spark and you must troubleshoot and find out why.
Contact me for a Dayton to DESA parts cross reference chart.
Oct 27, 2010 | Dayton E51 Oil Filled Utility Heater
I have a dayton 3VE50A oil filled heater runs on multi fuel I am running kerosene. Runs great all day long untill I close the lid on it then it quits. Pressure is at 5 psi on back gauge adjusted it up and...
make sure hoses and fittings are air tight, take some soapy water and spray on fittings and hoses and look for bubbles to appear if there is a leak, any small leak will keep heater from working
May 20, 2010 | Dayton E50 Heater
My3e219c heater was working fine.turned it off then tried to turn back on and all it does is fan runs while it is sparking and sucking fuel but will not fire.
Hi, Try checking the fuel supply to this unit, sounds as though something has been picked up by the pump and it is not getting enough fuel to fire. If you have spark, and fan is running, the fuel is the problem. Check this out and let me know. You and I can go from there.
Shastalaker7
Dec 22, 2009 | Dayton E51 Oil Filled Utility Heater
Heater wont ignite. Has fuel coming out front of
if the spark plug is sparking it is hot enough to lite the fuel.is ther dirt in fuel tank???is there water in the fuel???? what is the air pressure set at????is the nozzle clean and spraying correctly?????any of these will cause the heater not to fire.not the spark plug.
Feb 20, 2009 | Dayton E51 Oil Filled Utility Heater
Wat the hell is wrong with my dayton heater?170,000 btu oil fired...wont stay runnin?on shut down puffs like a mutha....
Most use a spark plug to ignite fuel it could need cleaning. You also could have water in fuel or dirt
check and clean ignitor/spark plug clean fuel line and nozzle, drain and clean tank Check for water in fuel by tilting unit to have a low corner siphon fuel from that corner after 1 hr inspect for water.
Jan 23, 2009 | Dayton E51 Oil Filled Utility Heater
Dayton Wire Wheels Dayton Oil Fired Heater, 75 K BtuH 120 V - 3VE49 Logo
462 people viewed this question
Top Dayton Wire Wheels Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Dayton Wire Wheels Kitchen Range Expert? Answer questions, earn points and help others
