Good day, i have a WA75B7PT washing machine, but need parts for it, from where can i order
Needs the top front plastic waterproof control panel, power switch and one or two small parts
    Top Expert:
  • Washing Mach... Master
  • 22,132 Answers
  • 3 Answers
SOURCE: error code 43 on F& P washing machine
Carefully remove control console, then control board. Take note of which connector came from which terminal! Balance sensor is located under control board. Remove with care. Check that little button (size of pen top or pencil lead) is moving in & out freely. It is spring loaded. If it sticks, replace it. Hope this helps.
Posted on Jun 17, 2008
  • 1170 Answers
SOURCE: My Kenmore top loading washing machine is leaking
This symptom usually indicates that you have a failed inlet solenoid water valve assembly. Completely unplug the washer from the electrical supply and see if the water stops filling. If it does, then you likely have a control board failure. This is rare but possible. If the water continues to fill with the washer unplugged from electricity, I recommend shutting off the hot and cold water supply faucets behind the washer. It is likely that the water will stop filling the washer. This would indicate that you have a failed water valve assembly.
Posted on Jul 11, 2009
TheMobilian
  • 8220 Answers
SOURCE: sumsung J845 front load washing machine cannot open the door
What you need is a Samsung service repair manual
Posted on Mar 03, 2010
Testimonial: "Thank you for the manual, it helps me take off the top cover, but I am still in the same problem. But thank you all the same"
beltronic205
  • 1461 Answers
SOURCE: simpson esprit 550 washing machine stops mid-cycle
Could be timer fault although good chance its stopping as it gets to rinse indicating faulty Solonoid valve..Good luck
Posted on Mar 31, 2010
Testimonial: "thanks for the tip"
marka19
  • 1430 Answers
SOURCE: Replace "lid switch" on kenmore washer 110-20702-991
Go to www.appliancehelponline.com/servicemanual.html this will walk you thru the lid switch replacement.
Posted on May 12, 2010
Lg direct drive start button is not work" what's problem in machine
Take off the control panel. There is a little plastic arm behind the start button that may be worn down on the end and may not be making contact with the electronic button underneath.
To access the control panel on the WD14700RD:
  1. Disconnect the unit from power and water
  2. Remove the top: take off two screws at the back, push it backwards one inch and lift it off
  3. Take out the soap tray and remove two screws on the soap tray compartment.
  4. Remove the control panel: push down on the two arms on top of it so that it can pop out, and pull it out at the top and then lift it off the bottom hooks. Pull it out a little from the machine, about an inch.
  5. Remove the front plate from the control panel: there are 7 screws behind it. Rotate the control panel up or down in order to access the screws behind
  6. Now that the front plate of the control panel is loose, identify the arm of the button that has stopped working. Wrap a small amount (2-3 times around) of electrical or plumbers tape on the very end of the plastic arm. Or if there is a nib instead of an arm, a small dab of epoxy resin allowed to harden does the trick.
  7. Refit the control panel and test the button now works.
  8. Reassemble the control panel, top, and turn on water and power.
  9. Test once again.
And that's it! All you need is a screwdriver and some tape. Too easy. Hope the information helps out.
Sep 17, 2016 | LG Washing Machines
I have a Logik L712WM12 washing machine and the control buttons have gone inside
putty knife along the top edges till it unclips then you can see what needs done.
Apr 03, 2016 | Washing Machines
I can not open control console in order to fix lid switch for Kenmore Elite Washer 110.15962401
First unplug the power cord. On the top corners of the back of the control panel there are two screws, one each side. Remove these first. At the front corners where the control panel mounts to the case top there are spring steel clips, which compress and snap into a slot in the top of the case. A putty knife pushed in between the panel and the case will compress these springs and release the front of the panel. this link will take you to Sears parts and an exploded view of the machine top.
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-elite-Parts/All-Products-Parts/Model-11015962401/0583/0153200/K0407007/00002?blt=06&prst=&shdMod=
Dec 25, 2011 | Washing Machines
The plastic panel where you turn washer on , I pushed too hard and it broke but I don't know what its called to replace it? After it cracked machine won't turn on. Need your help please.
Plastic control panel. It could also be electrical panel. You can order part from the Internet. Just use "appliance parts" Then pick one of many appliance part vendors. They will have sub-catorgies; such as, washer, dryer, stoves, etc.etc.
Well, Flower Lady check your local dealership for pricing. This will give a good estimation to buy parts from the vendor on the internet. I have saved money buy from internet but you need know your prices on parts. So, check the prices before buying and find the vendor that will ship free. GB...stewbison
Aug 21, 2011 | GE Profile WPRE6100G Top Load Washer
How to I remove the drum from a Hotpoint WM64 washing machine? I need to change the bearings.
Remove top cover and rear panel.
Remove belt and drum drive pulley.Remove clamp that secures door seal
Remove top control console panel.
Remove door lock.
Remove screws top and bottom holding front panel, remove front panel.
Remove spring clips holding plastic drum front, lift to one side plastic drum front cover.
Tap drum shaft to remove drum from container, remove bearings.
Please rate my solution.
Thanks.
Sep 04, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
There is a black tape that seems to be unraveling from my maytag atlantis. This tape is under the top rim of the basket. Any Ideas of what this is and if it needs to be replaced. My machine is 8 years old
Looks like this is the white plastic shield gasket:
You need to remove the front panel, loosen the top panel to be able to remove the plastic shield (it's just clipped on).
Once you have the shield removed, put gasket back in place so you are back in washing business.
Good Luck!
Aug 17, 2009 | Maytag Washing Machines
5 yr old top load washer needs new lid switch; bought the part -- now what?
Check the rear of side plastic panels, they have a screw that holds it in place. (remove them).
Pull control panel towards you and fold it backwards carefully so you don't brake the plastic hinges.
Remove the metal brackets that keep the top panel secured on cabinet and slide top panel off about an inch so you can lift and exposed lid switch - remove old lid switch and assemple everything you removed the way it was.
GOOD LUCK!!
Aug 17, 2009 | Washing Machines
I need to replace the pump on my Admiral AAV70000AWW washing machine but need a repair guide manual or instructions
Electrically Isolate the machine
To access the pump the front panel needs to be removed, first the machine top needs to be opened,
at the joint between the machine front panel and top insert a flat blade 4" from each side to release the lid catches, tilt back the top to access the internal screws on the front panel and remove the front by lifting off it the bottom brackets.
Ensure the machine is empty of water, to do this lower the waste drain pipe to floor level and clooect any water in a suitable container.
Tilt the machine back 45 degrees and remove the drive belt and bolts for the pump, remove the hoses from the pump, refit in reverse order.
Jun 08, 2009 | Maytag Admiral AAV7000A
GE WBVH6240FWW control dial broken-how to remove?
The control knob simply pulls off. I just looked at the other side of one..The knob connects to the main control board. To gain access you must remove the top of the washer. There will be screws at the rear of the machine to remove the top. Once removed, the control panel will be exposed for easy removal. Good Luck, Eric
Feb 14, 2009 | GE WBVH6240F Front Load Washer
Kenmore front loader he2t power button stuck
First of all, the power button is not a separate part. It's integrated into that whole interface and cannot be fiddled with. You need to take off top to get to console; you should see what else you need to take off to get the console off. There are some screws as well as plastic catches formed into the console that need to be depressed to disengage it. Thanks, please leave feedback or contact me again for more info if you need it.
Nov 29, 2008 | Kenmore 43142 Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
