Question about Xerox Phaser Office Equipment & Supplies
Where's the paper jam sensor for a Xerox phaser 3500?
    Scholar:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • Xerox Expert
  • 142 Answers
If memory serves, go into the service panet and check out the sensors. As you open the panels each sensor logs each activation.
Good luck.
Posted on Apr 02, 2015
SOURCE: Xerox Phaser 6250N Jam at Registration Roller
I use to have the same problem, but downloaded a fuser patch at the Xerox site:
http://office.support.xerox.com/SRVS/cgi-bin/webcgi.cgi?new,kb=Phaser_6250,company=%7B5AC8CA72-62D5-4658-8D6F-D2F393C98A63%7D,ts=xo,ques=ref%28security_level%29:1,ques=ref%28Country%29:45,/,case=R1001052703
if that link doesn't work, go to the Xerox site and look in the area:
Home > Support & Drivers > Phaser 6250 > Knowledge Base
ID: R1001052703Phaser 6250 Support Knowledge Base Jam at Registration Roller (code Jam RR)
Follow the instructions and hopefully your printer problem will be resolved.
Posted on Oct 07, 2008
  • 37 Answers
SOURCE: xerox phaser 8560 DN is
There is mostlikey a scrap of paper that you can not see still in the machine. You can gently walk a thicker piece of paper through the paper path and see if it pushes out the obstruction. Be very careful not to scratch the drum when you try this.
Hope this helps
Posted on Dec 04, 2008
  • 526 Answers
SOURCE: Phaser 8560 error code
Most likely you are using generic ink or ink not made for that specific machine. The black ink is the one causing the problem. the printer will then need to be reset.
Posted on Apr 15, 2009
  • 17 Answers
SOURCE: repeated paper jams
These errors are usually caused by a cracked DM Camshaft (Drum Maintenance). This was a very common problem for Xerox, they usually broke while under warranty, but there a heck of a lot out there that are just now going bad after a year.
You may or may not need to replace the "Motor Process Drive Gears" as well as the DM camshaft.
You might be able to talk Xerox into doing this as a warranty repair, if you ***** real loud.
Posted on Aug 21, 2009
SOURCE: xerox phaser 6120 laser printer paper jam fuser
Fix, well i am a dentist in Marysville washington and just got this printer from a family member and same thing was going on.
I looks like paper stuck in the middle roller. I just got a small mirror and pair of dental tweezers and removed a lot of jammed paper. it works fine now but you need do go to the dental section in drug store, so you can see where the jam is at.
Posted on Oct 26, 2009
Xerox phaser 8560 says "paper jam - open front
try cleaning the microswitches. it may also have a sensor and if the little plastic piece that crosses between them has broken off it will throw codes. mine is ok so i cant say for sure but you can try to glue a suitable piece in there to trick the printer if thats the case or bypass the sensor. just a few suggestions from my experience with electronics
sensor is kind of this: gap is where the plastic part is supposed to go in between.
Oct 12, 2011 | Xerox Phaser 8560MFP Laser Printer
I have a Xerox Phaser 6180 MFP, and it keeps saying paper jam and there is no jam, what can I do?
Check the fuser for paper stuck in it.
Check that the 'paper out' sensor arm (in the fuser) is not broken. If it IS broken, you'll need a new fuser.
Sep 03, 2010 | Xerox Phaser 6110 Laser Printer
FUSER GETTING OVER HEATED IN XEROX PHASER 7400.SOMETIMES A4 PAPER GETTING JAMMED IN FUSER ,WITH A3 PAPER THERE IS NO PAPER JAMMING PROBLEM.
try to clean paper feeding rollers and chek fuser paper sensor, maybe paper comming too late...chek this just to be sure all its OK whit paper path and fuser.
...or replace fuser module!
Aug 23, 2010 | Xerox Phaser 7400DN Laser Printer
XEROX PHASER 6180 SAYS PAPER JAM, I CLEARED PAPER JAM, PUT IN NEW CARTRIDGE, AND IT STILL SAYS PAPER JAM
Mar 16, 2010 | Xerox Phaser 6180N Laser Printer
Xerox Phaser 7700DN jam at fuser
Those rollers are necessary to feed paper from the fuser. Order PN 116-1759-00 which is the 15 inch long shaft w/ 4 rollers
Whit
Item, Inc.
Nov 10, 2009 | Xerox Phaser 7700DN Laser Printer
Phaser 860 screen says "paper jam - open front cover to clear"
I posted a problem with the phaser 860 paper jam. I found 2 broken sensor flags and am ordering the parts.
Mar 19, 2009 | Xerox Phaser 8400 Laser Printer
Phaser 8400 paper Jam
The preheat entry assembly has paper detectio arms/sensors that will get brittle and break off, leading the machine to think there is a paper jam. This problem usually will require a trained technician to diagnose & repair.
Sep 12, 2008 | Xerox Phaser 8400 Laser Printer
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
