Ms1943al keeps turning on by itself. Occasionally the cancel button doesnt stop it
    Top Expert:
  • Office Equip... Master
  • 21,460 Answers
That will be self check/cleaning.
Posted on Nov 10, 2014
Tappan tgf357ccsf cancel button not working
Their a couple possible things causing the cancel button to not work.
1) the shaft for the button that is in between the little button ya push and the clock is broken so when ya push the cancel button the shaft doesnt engage the button on the clock. To check that pull off the button for the cancel button that ya push and see if the shaft under it is broken or bent
2) the shaft mentioned above is good but the button ya push that actuates the shaft is broken and it can be pulled of and inspected
3) the clock itself is bad and even though the button and the shaft are good when pushed the clock does not respond to being pushed. If ya find that both the shaft and the button seem to be in good order then it will be the clock itself
The part numbers for the parts are;
SHAFT 316080600
BUTTON 316015103
CLOCK 306080102R
Good luck in determining what exactly the problem is..i hope i have been able to help ya figure it out,
GENE
Sep 28, 2011 | Kitchen Ranges
I put a load in and then canceleed it during the
try turning off completely and waiting a few mins it may reset itself if it has a dial see if it has a off position turn it to off. Failing that try the mains where its plugged in switch off. If that doesnt help you will need to ring them up.
Mar 30, 2010 | Maytag Neptune MAH5500B Front Load Washer
Oven W279U Serial No. 790191BD keeps beeping.
I turned off the power to the oven at the breaker box and left it off for several days. I restored the power this afternoon and there have been no more beeps. Spells and incantations may have played a part as well.
Aug 20, 2009 | Jenn-Air Ovens
Hhp deskjet 5550 - orange and green light keep
1) Close the print head cover, and turn off the printer. While pressing the Resume/Cancel button, press the Power button. (Do not release the buttons. The LED lights in green to indicate that a function is selectable.) 2) While holding the Power button, release the Resume/Cancel button. (Do not release the Power button.) 3) While holding the Power button, press the Resume/Cancel button 3 times, and then release the Power and Resume/Cancel buttons. 4) When the LED stops blinking and lights in green, press the Resume/Cancel button 4 times. Finally press the Power button.
Jun 09, 2009 | HP DeskJet 5550 InkJet Printer
My Canon MP160 will not print. I put in new ink, but the light keep flashing and the numbers keep reading E...4...2 over and over. I tried turning it off and on but nothing works. What is the problem and...
Jun 08, 2009 | Canon PIXMA MP160 All-In-One Printer
The light on the buttons that say cancel and normal are flashing and the dishwasher won't turn on.
first thing to try is to disconnect power for 15 minutes and then try again if goes into default again take off bottom panel and behind the black trim will be a tech sheet see if it gives yousome diagonostics sounds like it may be the computer if the power off and on doesnt make it work,.
May 31, 2009 | KitchenAid 24 in. KUDI02IRBS Stainless...
Old door dinted want to fit new door ms1943al model
You can order parts from Encompass here or you can call them toll-free at 866-779-5835.
May 18, 2009 | LG Over-the-Range Microwave
Cancel Job
The only other way you can stop it is to stop the print job from the computer. Press the start button. Press the control panel. Select printers. pick the icon of the printer and double click it. Highlight the print job and press the delete button.
That will canel it.
Aug 25, 2008 | Zebra 105Se Thermal Printer
Whirlpool Duet model number GHW9100LW2-control lock button stuck on red, cant do anything else. Tried pushing the pause cancel button nothing......An ideas? Thanks!
Press the "End of Cycle Signal" button, the last button on the bottom right, for 5-10 seconds. That should resolve the problem.
Uppi
Sep 07, 2007 | LG WM2077CW Laundry XL Front Load...
IPAQ turns itself on
Go to the ActiveSync options of your pocket pc and to go to Mobile Schedule and choose "Manually". I think it's set to sync automatically in a few minutes that's why it turns itself on.
Sep 11, 2005 | HP iPAQ HX2100 Pocket PC
k24674
