Question about LG Washing Machines
When I Fill my washing machine (Top loader Lg Wf-T7015tp), it Makes a Funny Noise and die when I start the program.Is it the Capasitor or is it the v-belt tension?
Top Loader WF-T7015TP
  • 5 Answers
If the noise is only when this function of filling, and if you are only using one of the two fill valves, may be due to the magnets of the inlet valves of the water, which are activated in filling and are disabled when you start the program. that noise is normal unless it is very strong and is the preamble to the damage of the two valves.
Posted on Nov 26, 2014
SOURCE: LG WD-1021-WF Front Loader Washing Mashing
Not a hard task if you coat rims with liquid detergent before trying to install new seal.
Using thumb go slowly around rim working seal all the way back.
Replacing main spring can be done by working bottom to top and then hold left side of spring in place while you pull right side in with long nose pliers.A couple of minutes difficult work and your 90% done.
Care is required so as not to puncture seal,
Main point is to ensure seal is fully seated before applying spring.
Having machine laid on its back makes the job so much easier.
This job took an hour and 30 minutes, the hour spent checking the internet first.
Good luck
Kevin
Posted on Nov 23, 2008
  • 6 Answers
SOURCE: I have a Brand LG
You probably have the drain hose too far down the standpipe and it is siphoning out. Check that first. If that doesn't work, look up Catriver, sounds like that cat knows his stuff. Tenbears.
Posted on Dec 20, 2008
  • 4 Answers
SOURCE: lg wf-s6607tc
This is probably a lid cover open protection. Check to see if there is a magnet on the cover, positioned almost to centre (slightly to the right) at edge of the cover. There is some sort of plastic catch to house the magnet. If it is not there, place a magnet at the corresponding area on the washer where the plastic catch will touch when the lid cover close.
Posted on Sep 09, 2009
SOURCE: Clean LG WF-T652a Top Loader Washing Machine
I have this problem too and I solved it easily !!!!
I hypothesised that something was blocked by dried up lint/silt. So I filled the machine with very hot water and also poured hot water down the lint filter outlets. I left it for 5 minutes and then started a wash cycle - and the water now comes out of the lint filter ducts. ! :-)
Posted on Jun 19, 2010
  • 330 Answers
SOURCE: my machine lg top loader
this means door error there is a magnet in the lid that falls of and this is how the computer knows the lid is shut lg dont sell the magnet you have to replace the whole lid sorry.
Posted on Jan 11, 2011
Iv'e got a LG Top loader.WF-T755A. When it spins the drum shakes violently and move the washing machine around . It also makes a loud noise while doing it. What is wrong please?
The load is off balance. Instead of being evenly spread out along the drum, your laundry is bunched up on one side. Try smaller loads to allow the clothes to move more freely in the water.
Feb 11, 2017 | LG Washing Machines
Why won't my LG WF-T852A top loader washing machine fill with water ready to begin wash
Possibly the water inlet valve has burnt out .or the controller has failed . only a tech that has hands on capacity can tell for sure .
Jan 01, 2017 | LG Washing Machines
How do I fix my LG WF-T1391TP top loader washing machine, as water does not flush out after a wash cycle, sometimes after a rinse cycle?
sounds like the drain pump could be clogged up might wanna lay it on its backside and take the motor out and inspect it for any buildup inside of its self as this can/will damage the drain pump however if there is nothing there inside the drain pump then the pump needs replacing
Aug 24, 2016 | LG Washing Machines
I have an LG model WF-T7015TP Turbodrum top-loader automatic washing machine. Having problem in that the drum does not agitate to and fro during the washing cucle. It's draining fine and even spin-drying...
check the agitator module unit and the start capacitor both in the back of the control panel One controls the agitation and the other starts the motor. If the start capacitor is failed simply replace it with a new one The agitator module will cost more . Have an appliance electrician check it out.
Aug 16, 2013 | LG WFT1071TP Top Load Washer
Where can you find the presure switch lg wf- t1233TP
where can I find a display board for my lg wf-t1233tp top loader washing machine
Jul 04, 2012 | LG WFT1071TP Top Load Washer
I have a LG top loader Fuzzy logic 6.5kg model WF-T655th spin cylce not working, the light is flashing. I have a load in the machine, how do I emppty the water out of it. Have misplace the manual.
I have a LG washing machine WTF655TH, it has stopped working, its full of water, but when you push the one button, it trips, how do i get it working again
Jan 16, 2012 | LG Washing Machines
I have lg top loader washing machine model wf583spc if i start any program after 30sec the De error blinking please give the guide line also drain clear & door ok but always show same problem
I HAVE LG WF-583 FULLY AUTO W/M AND MAIN CONTROL PCB IS DEAD IN THIS M/C. WHERE SHOULD I GET REPAIRED/ REPLACED THIS PCB AND WHAT WILL BE EXPECTED COST?
Aug 17, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
LG WF-T753A Top Loader washer hot water inlet valve
Just found this whilst looking for known issues with my machine as the cold water won't stop when filling.
http://safemanuals.com/user-guide-instructions-owner-manual/LG/WF-T753A-_E
Aug 25, 2008 | LG WFT1071TP Top Load Washer
Washing Machines Logo
95 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
