Question about Dryers
Paragon symphony fire goes off after a while.
The gas fire comes on and then goes off by itself after a few minutes. What do I need to do to rectify? Thanks
    Top Expert:
  • 22,110 Answers
Have it serviced by a competent gas safe engineer for safety.
Posted on Nov 10, 2014
2 Suggested Answers
  • 380 Answers
SOURCE: gas dryer ignites but wont stay lite
Try shorting out the Hi-limit sensor(Lg calls it that, don't know for whirlpool). See if that does anything. If it fixes that, don't leave it like that. replace it and the other fuse by it as well.
Posted on Dec 05, 2009
Why does gas fire place fire goes out and comes back on after a few minutes ,until i turn it up higher.
Your thermostat has gone and is not telling the unit to switch back on when the temperature drops below the threshold. You are doing the job manually.
Dec 30, 2016 | Home
Weller Pyropen WPA2 extinguishes itself after a few minutes.
Gas (condensation really) may be freezing and constricting flow. Try warming the tip a bit with a hair dryer see if it goes longer.
Jan 11, 2014 | Weller WPA2 Pyropen Professional Self...
I have installed 3 paragon timers and this is the first to give me trouble. When the defrost cycle started it did cut off but the timer was stuck on defrost. Many techs have done strange things to the...
You need someone to come in and trace the wiring if you cannot figure it out. You said you had the Paragon wiring diagram already, if not the link below can be used.
http://www.uni-line.com/images/docs/refrigeration-8140series-wiring.jpg
This defrost time can be used for both hot gas and electric heater defrosting so check to see which defrost type is being used.
Feb 05, 2010 | Paragon 8145-20 Defrost Timer
Rheem powervent ignites then goes out, electronic ignition.
Sounds like a bad thermocouple. This part sends a millivolt signal to keep the gas valve open but shuts it off when it cools - or if something goes wrong with the ignighter - to prevent fires. It's easy to replace and not super expensive. See your local Rheem dealer.
Aug 13, 2009 | Water Heaters
Runs a few minutes and quits
hi this could be 3 problems ? no spark so vapour not igniting so excess vapour coming out as smoke, if it ignites stays on for a while goes out the flame probe is faulty, fuel filter is blocked needs new one , the fuel pipe going into tank has a non return vavle in it ( its a plastic ball in line with pipe ) if this is missing or stuck it allows fuel to drain back into tank and causes a air lock in heater causing vapour into chamber result in smoke coming out of end, as a quick fix for that you can fill pipe with fuel bend it so its traps in fuel like fire place pipe in tank when stopping fire stick mole gripps on pipe so next time fuel is there ready
Jan 22, 2009 | Reddy Heater 60,000 BTU Kerosene...
How do i install a thermal coupler for forced air heater gas
Thermo coupler is held in place with a clamp bracket at the pilot end and a small brass line nut on the other end going into the gas valve.The pilot flame must surround the sensing bu or wrap itself around it Press the pilot button for a few seconds and fire up the pilot flame. Wait a few more minutes and turn the gas vale on for the main burners. If it fires, your set.Good Luck,Ned
Jan 15, 2009 | Reddy Heater RLP100 Portable Forced Air...
Paragon 2000r gas fire - not coming on. pilot light is coming on with remote control but then goes out without activating or lighting the fire.
I have the same problem occasionally with a Paragon 2000R. It seems to be related to the thermocouple. The pilot flame does not heat the thermocouple enough. Usually re-arranging the the artificial coal to reflect some of the heat back to the thermocouple will just make the difference. Maybe it is time for a new thermocouple.
RB
Nov 08, 2008 | Heating & Cooling
Fire goes out
your fail safe has gone you can get a local appliance second hand shop should help you as they all have there own gas men to fix all gas stuff give it a try
Jan 05, 2008 | Maytag MER6772 Gemini Electric Kitchen...
Dryers Logo
135 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
