Putting filters back in
I took out the filters to clean them, I was able to put one back in, but forgotten where to put the other one.
    Top Expert:
  • 22,734 Answers
Make and model please.
Posted on Nov 10, 2014
Horible smell comingfromthe drum, took the filter out to clean it, now it is leaking, what can I do? ps smell still there, have tried 1 95o wash with no joy
For the pump try taking filter back out and putting back again for smell clean out the rubber door seal with soapy water after the door seal is clean clean the despencer draw fully by taking it out. When you washed the seal and draw get washing machine clean for local super market and do a 95oc wash it should smell nice now if not could be drains hope this helps.
Jul 29, 2011 | Hotpoint Aquarius WF220 Front Load Washer
What are the steps to replacing a radiator in my 6 cylinder with a/c
Not really that difficult..... Unfasten the screws that hold the shrouds for both fans. Remove the electric fan and just push the other one back out of the way. Remove the air filter box (bolts visible in the bottom under the filter) That will give you better access to the trans cooler lines and lower hose.
Remove the cross brace above the radiator and the trans cooling lines. (one line is a plastic squeeze clip...careful not to break it but do clean it well so it grabs correctly when putting it back on).
Remove the lower and upper hoses and lift the radiator up carefully. Make note of any smaller brackets and what-not I may have forgotten. Anything still holding it in will be obvious.
Re-assembly is the reverse but be very careful not to damage the core. Also, before putting it back in, make sure there are no leaves or other obstructions trapped between the radiator and a/c condenser.
Nov 21, 2010 | 1995 Jeep Grand Cherokee
How do I clean the filter on my Hotpoint First Edition FEW12? Do I have to take off the whole big black pipe at the back, under the drum? There is no filter at the fron
Yes, remove lower rear cover.
Remove large black hose from bottom of drum.
Clean the filter inside the hose.
Please rate my solution.
Thanks.
Nov 14, 2009 | Hotpoint First Edition FEW12 Front Load...
Lens needs putting back together
could you please let me no haw to work the ray cop we have no instrutions thankyou sonia holt
Sep 03, 2009 | Kowa Optics
Having trouble in putting filter back after omega
Try inserting it into the back first, then the front. One side is spring loaded and the filter has to be inserted against the spring first, and depressing it, while the other end is pushed up into the filter frame and released to secure it in the frame.
Jul 31, 2009 | Kitchen Ranges
Tetra filter Leaking after cleaning
Tetra tech support can help you or email you a new owners manual. Call their toll free number 800-526-0650
Jun 23, 2009 | Tetra Garden
Drain pump on my LG wm1832cw seems to be "clogged" I've cleaned drain filter check discharge hose and have made sure house drain is clear.
i took the pump out . then took the pump apart , water got past the o ring , where shaft goes into the center. i cleaned out the sludge & put grease on the o rings before putting it back together. it's worked since,
Jul 08, 2008 | LG WM-1832C Front Load Washer
Brookstone pure ion filters
You need to reset it, unplug the unit and take out both filters. Then, plug it back and and simultaneously and firmly slam both filters into the back of it at the same time. Before putting both filters back inside the until, also vacuum out the insides in case there is hair/dust inside of it that has accumulated.
Also, make sure your filters are 100% dry before every putting them back inside the unit.
Mar 02, 2008 | Brookstone Pure-Ion UV Air Purifier
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
