Question about Microwave Ovens
<!-- from fixya rte -->What is the reason of noizey micewave? - Microwave Ovens
    Top Expert:
  • Microwave Ovens Master
  • 26,681 Answers
Fan noise and turntable noise is normal. Any crackling is caused by arcing from food debris the wave guide cover may need cleaning.
Posted on Nov 10, 2014
What is the reason for high voltage fuse to blow outon microwave.
The only reason for any fuse to "blow" open is a direct short. The most common reason, in a microwave oven, is the Magnetron. This is the device that generates the microwaves. If this is the case, repair is not very economical.
If you have a volt meter or a device that can check for resistance, check for anything that is shorted or "0" Ohms to ground.
I hope that his helps answer your question.
If you have any further questions please feel free to ask.
Mar 01, 2015 | Microwave Ovens
MICROWAVE TAKES LONGER TO COOK EVEN ON HIGH AND OCCASIONALLY SPARKS FOR NO REASON
inside your micro... walls are made of metal but protected with paint, if this paint is gone and the metal shows thats what happend you have to repaint the unprotected areas again, and the reason your micro... is not working so good anymore is due to the magnetron
Jan 31, 2014 | Sharp R-930AK Convection/Microwave Oven
The microwave unit in my Thermodore CMT231 has abruptly stopped working. I suspect a fuse may have blown. Is this self-serviceable? I am pretty much a novice.
When you say it stopped working , you mean no lights or display etc. Then that can be a fuse but fuses blow for a reason. Find the reason if the fuse blew.
Oct 14, 2013 | LG LMV1650ST Microwave Oven
Microwave will not heat
Some common reasons:
If turntable does not move at all--a safety switch where the door opens may cause this.
Other primary reasons are:
Bad Diode most units use or the large Filter cap some use.
Bad inverter which powers the Magnetron that does the heating and connect to each other.
A bad magnetron in the unit.
12_17_2012_7_57_42_pm.jpgTypical diode used
12_17_2012_7_58_24_pm.jpgTypical Magnetron
Dec 17, 2012 | Whirlpool Microwave Ovens
My microwave beeps for no reason even when not in
There is a reason. Try to reprogram the unit. Start w/menu: date, time simple stuff. This should take care of it.
Nov 05, 2009 | Microwave Ovens
Microwave does not heat up
The reason for not heating can be due to two reasons.
It can be either the magnetron or the diode.
Sep 01, 2009 | GE JVM1630 Microwave Oven
Microwave will not cook..all the buttons work except for the 0 and the start button
hi..the reason to this problem may be due to one of these
reasons.check it out from the following link.
http://applianceparts.wordpress.com/2008/10/29/microwave-doesnt-heatcook-food-what-is-wrong/
try this out..
thank you..
kindly rate my response..
Jul 19, 2009 | Frigidaire 1.6 Cu. Ft. Over-the-Range...
Daewoo over the range microwave model KOT-21OUB just stopped working for no apparent reason. Lights and fans still work. Not heating food. Worked for one dish then the next nothing.
how old is the machine, microwave ovens have a tendancy to do the ridiculous for no possible reason. a check of the main power fuse within the unit might help. it is a large fuse 10A> that supplies the transformers
Feb 17, 2009 | Daewoo KOR-630A Microwave Oven
During heating, my microwave stop for unknown reason
Contacts to the door switch, are the most common reason for this problem.
The diode and capacitors can also be tested. The capacitor must be allowed discharge before testing, or you risk to get electrocuted, even if power is off. Capacitors can get discharged by shorting their two contacts.
Replace the magnetron if the checks and all of the high voltage component tests are good, but the unit still does not heat.
All locations, and description of this parts can be located using the diagram here: Counter top.
Parts must be tested to find out what is wrong.
Remember that microwaves are potentially dangerous devices if not repaired properly, the job must be done by a competent person.
A microwave energy leakage test must always be performed when the oven is serviced for any reason.
Regarding parts, contact the seller here to purchase parts. (here in UK).
Nov 12, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
