Question about Echo Garden
Echo 500t blower will not start and when it tries to fire it snatches the [pull cord out of my hand
    Sergeant:
  • 406 Answers
Sounds like you have a timing issue..need a professional look at it..
Posted on Nov 10, 2014
roadtech7
  • 297 Answers
SOURCE: can't find serial # on Echo PB-500T Blower
The number is on the side of the recoil starter, its on a white or silver tag mounted on the underside.
Hope this helps, Matt
Posted on Dec 11, 2010
  • 85 Answers
SOURCE: have echo backpack leaf blower.
check to see if plug is getting good fire if not replace the plug
Posted on Jan 27, 2011
  • 122 Answers
SOURCE: what is gas:oil mixture for Echo PB-500t blower?
50:1 ratio, 2.6oz of 2 cycle oil to 1 gallon gas
Posted on Feb 26, 2011
SOURCE: I have an Echo PB-500T blower that won't
Remove the in tank fuel filter and take it apart, the felt Echo uses on the filter clogs quickly. There is still a mesh screen filter in the assembly so make sure you put it all back together and reinstall the fuel filter into the tank.
Posted on Nov 15, 2011
  • 430 Answers
SOURCE: Hello I have an echo pb-500T, my cord won't pull.
Remove the impeller and check for loose motor mount screws. With the impeller off and the spark plug removed and the pull start functioning properly; if it still wont pull then its likely internal and due to be replaced.
Posted on Oct 25, 2012
Why does my blower floor out to kiwk
adjust need and seat or make sure needld a seat or seated right soundes like not should be no need to adjust needel sounds like put in wrong flip it over metal side go on needle
Aug 06, 2014 | Echo Power Blower PB-500T
Like the motor is locked up
pull muffler off look at piston if all scard up its bad by a new one and add more oil to your gas you ran to hot only fix but new one
Aug 05, 2014 | Echo PB-500T GAS-POWERED BACKPACK LAWN...
Throttle handle trigger is stuck
see if the linkage on the carburetor is stuck
Nov 18, 2013 | Echo Backpack Blower PB-500T
Oct 24, 2012 | Garden
I have an Echo PB-500T blower that won't throttle up. I bought this blower new about 3 months ago. Before this blower I had an exact same blower that gave me the same problem. I returned that blower...
Oct 02, 2011 | ECHO, Inc. PB-251C Handheld Blower
ECHO PB-500T - Stopped running and added gas fuel mix. Quit running again with full tank and now flywheel is stuck and I can't pull to start it. What is the problem?
My $350 Echo PB-500T seized up. I almost cried.
The solution was to drain the fuel tank.
  • Refill fuel tank with an 2-cycle Oli/gas mixture.
  • 40:1 =3.2 oz to one-gallon gas, do not use Alcohol base gas.
  • Remove the spark plug.
  • Pour approximate 1/8 oz 2-cycle Oli into the spark plug hole.
  • Remove the pull cord assembly (4-bolts)
  • This reviled the crank shaft-Pull cord bracket
  • I use a large monkey wrench to turn the shaft (CW) Clock-wise.
  • Complete approximate 20 revolutions.
  • Reassemble, but don't install the spark plug yet.
  • Complete approximate 20 more revolutions
    by pulling the pull cord.
  • Use q-tips to swab the top of the piston, as much as possible.
  • Install the spark-plug and crank, it will smoke for amount 7-10 minutes
Jul 30, 2011 | Echo Gas Blower 162 MPH 450 CFM Blower...
Can't find serial # on Echo PB-500T Blower
Dec 10, 2010 | Echo Garden
Open Questions:
Garden Logo
Top Echo Garden Experts
Jim Parker
Jim Parker
Jim London
Jim London
colesmowers
Are you an Echo Garden Expert? Answer questions, earn points and help others
