Question about 2005 Chevrolet Optra Alternator, 05
What would be a possible problem,if my car doe not idle at the time of starting-everytime
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 78 Answers
Idler motor needs cleaned or replace
Posted on Nov 13, 2014
Why does my 2000 gt 4.6L MUSTANG DIE AFTER 2 HOURS OF DRIVING, BUT STARTS BACK UP EVERYTIME?
This issue can be related to a variety of problems. If the check engine light is on I would have the codes scanned for problamatic sensors etc. If no check engine light on, have a look at the throttle plate and bore by removing the air hose from the filter box to the throttle plate and inspecting for gumming up. ( Black/dirty) If so, use a carb cleaner spray and old tooth brush to remove any deposits that may cause base idle to be affected. Another problem could be the IAC ( idle air control ) motor not working properly
Apr 25, 2015 | 2000 Ford Mustang
2004 mitsubishi lancer es idle rpm going up and down and the car stalls everytime it do that
have IAC valve removed and cleaned. After cleaning, start and let engine idle without increasing rpm three times for computer memory to store idle setting.
Jun 12, 2014 | Cars & Trucks
Idle drops, and stalls
Catalytic converter possibly
Feb 11, 2018 | 1999 Dodge Intrepid
1988 Pontiac Lemans Runs Rough
i can recommend to RUN scanner/computer for easy diagnostics and fix . God bless you
any components can be faulty32cbf899-f6e4-4700-9849-2f8e8911acec.jpgd28e17fa-ceac-4b84-b842-b66ec79f6c63.jpg
Jul 11, 2013 | Pontiac LeMans Cars & Trucks
Please help!!! My Saturn suddenly started stalling yesterday, and dies when I come to a complete stop! Anyone know whats going on here?
it could be one of 2 things the first one is the CPS that is located behind the starter the other one is an intake gasket but it sounds more likely to be the CPS
Jul 15, 2012 | 1992 Saturn SC
1994 chevy c 1500 shuts off everytime i stop
Possible TPS (Throttle Position Sensor) issue. The TPS controls idling speeds under all conditions. Although the truck may idle fine when cold, once warm, if you are encountering sputtering or stalling, the TPS could be the culprit. Other possibilities could be fouled spark plugs,bad wires, or a bad distributor cap.
Mar 04, 2012 | 1994 Chevrolet C1500
I have a 2001 mazda 626 and at certain times when i come to a stop it will idle eratic or stall. I will then have to start my car. This is not everytime. My check engine light came on with the code of a...
check connection to cam sensor. sometimes corrosion will cause a poor electrical connection. clean as needed. otherwise you may have to replace the sensor.
Sep 18, 2010 | 2001 Mazda 626
Everytime i stop for a long or short time the car will cut off i replace the spark plugs and wires and the roader cap and ball
Possible vacuum leak. Use a can of carb cleaner spray to check for vacuum leaks. Remove air cleaner housing assembly and plug the vacuum line. Start car. While idling in park, spray cleaner around base of carb, intake manifold to head area and around all vacuum lines. If the idle increases or smooths while spraying an area, that is where the vacuum leak is.
Feb 21, 2010 | 1983 Oldsmobile Delta 88
2001 Saturn SL2 won't start
have it scan it could be many things crank shaft sensor ignition coils and module. idle speed control. egr valve could be stuck open.
Apr 03, 2009 | Saturn SL2 Cars & Trucks
2005 Chevrolet Optra Alternator, 05 Logo
60 people viewed this question
Top Replacement Vehicle Parts & Accessories Experts
David Ellis Rhea
baire
Paula Hamilton
Are you a Replacement Vehicle Part and Accessory Expert? Answer questions, earn points and help others
