Question about AT&T 958 Speakerphone with Caller ID and Call Waiting
Why did I lose the dial tone after a long squeal sound in my hand set?
Tones are emitted on depression of all base buttons but there is no from the handset when lifted from the base.
3 Suggested Answers
silly girl
  • 513 Answers
SOURCE: "searching" message even when handset on the base
Found the following in AT&Ts FAQs for your phone, I'll leave only what might be relevant: # Charge the handset for 12 hours. After the first charge, the battery will quick charge in only 8 hours. Re-cradle the handset nightly for recharging. The battery will not overcharge. # Connect telephone line from base to unit to modular telephone jack. If cord is already plugged in, unplug and reconnect at both ends. Also, you may want to try another cord from a working telephone. See the owner's manual under "Connecting to Phone Line." (you can get the manual here on the product page in case you lost it) # Try a working phone at the jack. If another phone has the same problem in that jack, the phone jack is defective. Good luck, hope you work it out
Posted on Jun 05, 2006
SOURCE: My 2 year old base has power but no dial tone. It
This might sound silly, but have you tried plugging another phone into the wall jack to make sure it works?
Posted on Mar 10, 2009
Instead of tones, I am getting clicks when I try to dial. Not recognized by the phone line.
You need to set your phone to emit tone sounds when dialing instead of the clicks. It is a setting in your phone's personal settings.
Mar 07, 2016 | Lands Phones
A am not getting any sound when faxing or when faxes are coming through and my volume is on loud why is that.. I disconnected plugged it back in changed some settings and i still get nothing
Your HP all-in-one provides three levels for adjusting the ring and speaker volume. The ring volume is the volume of the phone rings. The speaker volume is the level of everything else, such as the dial tones, fax tones, and button press beeps. The default setting is Soft.
1 Press Setup.
2 Press 4, and then press 8.
This displays the Basic Fax Setup menu and then selects Ring and Beep Volume.
3 Press to select one of the options: Soft, Loud, or Off.
Note If you select Off, you will not hear a dial tone, fax tones, or incoming ring
tones.
4 Press OK.
Sep 15, 2010 | HP OfficeJet 7310 All-In-One InkJet...
The phone doesn't ring, there is no speaker phone, and no tones when you dial or text.
Try using the side keys to adjust the volume. It sounds like the phone is on silent. Go into the audio settings and play around the ring tone, text, dial tone sounds and settings until you feel that it is appropriate for you.
If the phone is still not responding with sounds or tones after you have set the audio settings, the phone might be defective and you may need to have the phone company look at it.
- Neal
Apr 27, 2009 | AT&T LG CU515 Cell Phone - Black
Can not get my plantronics calisto phone to par with the headset or the base
We have two of the Calistro Pros and they will lose contact all the time for no apparent reason. Most of the time when I walk to far away from the handset they will beep and there will be the "OUT OF RANGE" will display. I have found that while sitting next to the phone press the ear piece switch straight in. You will hear a series of tones either getting louder or going from high to low. Wait a few seconds after pressing the ear piece switch and then look at the hand set. the No Headset circle should dissaper. If not depress the earpiece switch and listing for the tones again. Wait again and they will find each other. If this does not help you then I think you have a phone issue. I use my for 8 hours a day and have to do this several times a day. I hope this helps.
Apr 09, 2009 | Plantronics Calisto Pro Series Cordless...
Help when i try to fax using my brothers 560, the number dials, the machine sounds like it's faxing, but the disply says telphone. how can i correctthis
Do you pick up the hand set when you are dialing, If you do the display will read telephone. When you want to send a fax put the paper in the document feeder. Dial the # press the start key or put the documents in the document feeder press the hook button to here the dial tone, dial the number what for the tones pres the start key. hope this helps
C.W.H.
Jan 29, 2009 | Brother IntelliFAX 560 Plain Paper Fax
No programming tone
On page 11 of the manual:
Disabling the timer reminder tones:
To disable the reminder tones, press and
hold the Timer Set pad for 5 seconds. To
enable the tones, follow the same step.
To shut off all (audible) signals except for error tones and the hidden function signal:
Press and hold the Stop Time pad for5 seconds. A short tone will sound to tell you the signals have been changed. Repeat the above step to turn the signals back on.
If that doesn't work, the next thing I would suggest is a hard reset. Unplug the unit for a minute or so.
Then plug it back in, set the clock and try again.
Dec 03, 2008 | Whirlpool RMC275PD Microwave Oven
Keypad tones - D900i
Change the dialing font style to Normal and then set off keypad tones on setting menu.
Oct 07, 2007 | Samsung SGH-D900 Cellular Phone
General problems
do not disturb feature has to be disabled
Sep 21, 2006 | Uniden Cordless Phone
AT&T 958 Speakerphone with Caller ID and Call Waiting Logo
27 people viewed this question
Top AT&T Lands Phones Experts
Paul C.
Are you an AT&T Lands Phone Expert? Answer questions, earn points and help others
