Question about Spectre 2001 Ford Econoline - E150, 4.2L V6 - Air Filter
How to find small air leak - Spectre 2001 Ford Econoline - E150, 4.2L V6 - Air Filter
    Master:
  • 876 Answers
Get some starting fluid and CAREFULLY spray a tiny bit in various areas around the manifold, air intake area - when you hit the leak, the engine speed will increase.
Posted on Nov 10, 2014
Add freon to my 2002 suzuki vitara
not for diy as it is measured by the gas pressures
too much will stop the system from working and too little will do the same if you need gas have you fixed the leak first as systems do not need gas unless there is a leak
Jul 09, 2016 | Spectre 2002 Suzuki Vitara - 2.0L 4-cyl....
Leak at steering column and rack junction
my sim no is 899660128001788718 pls tell my pin form sim
email-jamilakhtar098@gmail.com
Dec 17, 2013 | Spectre 2003 Chevy Impala - 3.4L V6 - Air...
What can be done to repair a leak from a tiny hole on the bottom of PUR water filter?
I am having the same issue. I've just replaced the filter and it started leaking out of this hole, where it never had before.
I am thinking that maybe the filter isn't seated properly, and that's causing the leak. But I have attached a picture of the hole in question. Any advice would be helpful. Thanks!
Feb 03, 2013 | PUR (FM-9500) Air Purifier
Still getting dust build up after installing an IQ air system
You will need to run an actualy HEPA filtered air filter as well. The air purifier will oxidize pollutants and will attract and trap some small dust, but most small units also require additional filtering to trap inert neutral charged dust.
Feb 03, 2012 | IQAir Air Purifiers
Our carrier reverse cycle airconditioner is leaking inside the house after a hour of use. how can we fix this? we have cleaned the filters in the inside unit and it still leaks,it works fine as a heater...
Did you blow out the drain? If so pull the front off of the air handler unit. Ckean out drain pan. This drain pan had small holes on either side that run from the sode drain clean those out. Also if your coil is dirty it will pull water back and cause it to leak. Try cleaning coil and dain pan plus blow out drain. Rus
Dec 13, 2009 | Air Purifiers
The fuse keeps blowing in my biozone 1500 induct unit.
get yourself a cheap multimetre, check for a short circut or open circut. this should be your first step. refere to google for info on short/open circuts. check the capasitors (small cylender things) for leakes or if the top is popped up on them. if so replace with the SAME. hope i was of some help
Aug 17, 2009 | Biozone InDuct 1500 Air Purifier
Change Filter LIght
take somthing with a small tip, above the light there is a small hole stick it in lol. good luck!!!!!!!!!!!!
Nov 11, 2008 | Honeywell HHT-081 Air Purifier
Have HAP422BRC-u Need explantation on the small red window above the name HOLMES does it light up or just a design?
That small red window located ont he fron of the unit is for the infrared remote control that came with your Holes HAP422BRC-U
Sep 18, 2008 | Holmes Products HAP220 Air Purifier
Spectre 2001 Ford Econoline - E150, 4.2L V6 - Air Filter Logo
57 people viewed this question
Top Spectre Air Purifiers Experts
Lawrence Oravetz
Jesse Walters
Jesse Walters
Are you a Spectre Air Purifier Expert? Answer questions, earn points and help others
