Question about Car Audio & Video
How to i set clock in deh-2390ub - Car Audio & Video
How to switch off pioneer car stereo deh 2390ub
hold in the source button for a couple seconds see if that does it
Mar 25, 2012 | Car Audio & Video
How do i adjust the clock on a deh 1900 mp audio
ive had a search for you and found the manual to download for your pioneer,
hope it helps you set the clock
http://www.retrevo.com/support/Pioneer-DEH-1900mp-Car-Receivers-manual/id/23227bh432/t/2/
Apr 03, 2010 | Pioneer DEH-1900MP CD Player
How to set clock in pioneer deh4000ub
here is the link for your manual:
http://www.pioneer.co.uk/uk/support/manuals/DEH-4000UB/index.html
Setting the clock
This function is available only for DEH-4000UB.
Use these instructions to set the clock.
1 Use MULTI-CONTROL to select
CLOCK SET.
2 Press MULTI-CONTROL to display the
setting mode.
# Press BACK to return to the previous display.
3 Press MULTI-CONTROL to select the segment
of the clock display you wish to set.
Each time you press MULTI-CONTROL, one
segment of the clock display is selected.
Hour—Minute
As you select segments of the clock display,
the selected segment blinks.
4 Turn MULTI-CONTROL to put a clock
right.
# You can also perform the same operations by
pushing MULTI-CONTROL up or down.
Turning the off clock
display on or off
If the off clock display is turned on, the clock
appears on the display when the sources are
off.
OFF CLOCK.
2 Press MULTI-CONTROL to turn the off
clock display on.
# To turn the off clock display
Cheers!
Feb 07, 2010 | Pioneer DEH-P4000UB CD Player
How do i set the clock on my DEH-1700?
Toddakins05
To set the clock on the DEH-1700
1. Press SOURCE and hold unitl the unit turns off.
2. Press AUDIO and hold until clock appears in the display.
3. Press <- or -> to select the segment of the clock display you wish to set.
4. Press + or - to set the clock.
Note to cancel clock settings press BAND
Hope this helps
Issken
Nov 12, 2009 | Pioneer DEH-1700 CD Player
How do I set the clock on a Pioneer DEH 1700
1. Press SOURCE and hold until the unit turns off.
3. Press the arrows to select the segment of the clock display you wish to set.
5. To cancel clock settings, press BAND. You can also cancel clock settings by holding down AUDIO until the unit turns off.
Nov 07, 2009 | Pioneer DEH-1700 CD Player
Setting clock-Pioneer DEH P3800MP
here is the link to your manuals:
http://www.pioneerelectronics.com/PUSA/Support/CarAudioVideo/In-Dash/CD-Players/ci.DEH-P3800MP.Support
1 Use Function to select Clock. Clock appears in the display.
2 Push left or right to select the segment of the clock display you
wish to set. Pushing left or right will select one segment of the clock display: Hour—Minute As you select segments of the clock display the segment selected will blink.
3 Push up or down to set the clock. Pushing up will increase the selected hour or minute. Pushing down will decrease the selected hour or minute.
Cheers!
Oct 17, 2009 | Pioneer DEH-P3800MP CD Player
Clock
To set the clock on the Panasonic DEH-1600 car stereo, follow these instructions:
  1. Turn the radio off by pressing and holding the SRC button (under the label OFF).
  2. Press and hold the Audio button in the upper right corner of the radio. After holding the button for about 3 seconds, the clock will begin to blink (the hours).
  3. Use the up and down arrows to increase or decrease the time hours or minutes. Use the left and right buttons to toggle between setting the hours and/or minutes.
  4. When done, push and hold the Audio button again fir about 3 seconds until the clock stops blinking (hours or minutes).
Sep 02, 2008 | Pioneer DEH-1600 CD Player
Having trouble settimg clock on cd car stereo
how to set clock for a pioneer deh-27mp
Mar 24, 2008 | Car Audio & Video
I NEED TO KNOW HOW SET THE CLOCK ON A DEH-1500 PIONEER
Hi Elimo
Two pics as the manual had the paragraph separated. This is for DEH 2500 only. Let me know if you want the 1500 as well.
Nov 24, 2007 | Pioneer DEH-P2500 CD Player
Car Audio & Video Logo
83 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
