Question about PrintE-Z.com 13127G, Laser Letter of Transmittal - Parchment
How to write a letter of transmittal - PrintE-Z.com 13127G, Laser Letter of Transmittal - Parchment
    New Friend:
A transmittal or cover letter accompanies a larger item, usually a document. The transmittal letter provides the recipient with a specific context in which to place the larger document and simultaneously gives the sender a permanent record of having sent the material.
Transmittal letters are usually brief. The first paragraph describes what is being sent and the purpose for sending it. A longer transmittal letter may summarize key elements of the proposal in one or two sentences and provide the recipient with other useful information.
End transmittal letters with a one-sentence paragraph that establishes goodwill by thanking or complimenting the recipient.
Ancient history essay writing tips Yahoo Answers
Posted on Nov 10, 2014
I am having trouble programming a key less entry remote for a 2002 grand am
How are you doing it ?
Transmitter Programming
Important: All transmitters that are to be recognized by the remote control door lock receiver (RCDLR) must be programmed in a single programming sequence. If the system is placed in program mode, all previously programmed transmitters will be erased upon receipt of the programming signal from the first transmitter.
Up to 4 transmitters can be programmed. Do not operate or program the transmitters in the vicinity of other vehicles that are in the keyless entry program mode. This prevents the programming of the transmitters to the incorrect vehicle. The order in which the transmitters are programmed is important. The first transmitter programmed will be transmitter #1, and the second transmitter programmed will be transmitter #2. Use care to program the transmitters correctly.
The scan tool must stay connected until all of the transmitters are programmed.
Install a scan tool.
Turn ON the ignition with the engine OFF.
With the scan tool, select Body, go to Remote Function Actuation.
Select Special Functions.
Select Program Key Fobs.
Select the number of key fobs to be programmed.
Press and hold the LOCK and the UNLOCK buttons simultaneously on the first transmitter for approximately 15 seconds. The power locks should cycle to confirm programming of the first fob is complete.
If you are programming more than one transmitter, repeat the previous step to program up to 4 transmitters.
Remove the scan tool.
Exit the vehicle. Attempt to lock/unlock the doors to verify the programming.
Operate the transmitter functions in order to verify correct system operation.
DEALER !
Apr 19, 2018 | 2002 Pontiac Grand Am
Bought a new key fob for a 2003 Chevy avalanche. After going through cycling the truck now won't start. I tried to turn over and dies.Is there anyway to clear the fob or what is going on?
Does it lock an unlock the doors ? How did you program the transmitter ? Like this ?
Important: Do not operate or program the transmitters in the vicinity of other vehicles that are in the keyless entry program mode. This prevents the programming of the transmitters to the incorrect vehicle.
There are 3 methods for programming transmitters, which are listed below as methods 1-3. Up to 4 transmitters may be programmed to the passenger door module (PDM). Each programmed transmitter is given a position of #1-#4 in the PDM memory.
Method 1 - No Tools Required, Program All Transmitters
Important: All transmitters which are to be recognized by the PDM must be programmed in a single programming sequence. When using this program method, all previously programmed transmitters will be erased upon the receipt of the programming signal from the first transmitter.
The order in which the transmitters are programmed will determine its numbering position within the PDM memory. The first transmitter programmed will be transmitter #1, and the second transmitter programmed will be transmitter #2. The number stamped on the transmitter case is for reference only; #2 can be programmed as #1, or vice versa. Additional unnumbered transmitters are also available.
Close all the vehicle doors.
Insert the ignition key into the ignition lock cylinder.
Press and hold the door unlock switch.
While holding the door lock switch in the unlock position, cycle the ignition ON, OFF, ON, OFF.
Release the door unlock switch. The doors will lock and unlock to confirm the program mode.
Press and hold the LOCK button and the UNLOCK button simultaneously on one transmitter. After a delay of approximately 15 seconds, the doors will lock and unlock to confirm the programming of that transmitter.
Repeat the previous step to program up to 4 transmitters.
Turn the ignition switch to the RUN position in order to exit the keyless entry transmitter programming mode.
Jan 10, 2018 | Cars & Trucks
How do you reprogram a new key for a 2000 Buick park avenue?
Important: All transmitters which are to be recognized by the remote control door lock receiver (RCDLR) must be programmed in a single programming sequence. If the system is placed in program mode, all previously programmed transmitters will be erased upon the receipt of the programming signal from the first transmitter. Up to four transmitters may be programmed. Do not operate or program the transmitters in the vicinity of other vehicles that are in the keyless entry program mode. This prevents the programming of the transmitters to the incorrect vehicle. The order in which the transmitters are programmed is important. The first transmitter programmed will be transmitter #1, and the second transmitter programmed will be transmitter #2. The number on the transmitters are for reference only: #2 can be programmed as #1, or vice versa. Additional unnumbered transmitters are also available. Use care to program the transmitters correctly.
  1. Install a scan tool.
  2. Turn ON the ignition, with the engine OFF.
  3. Use the scan tool Remote Function Actuation Special Function: Program Key Fobs in order to place the remote control door lock receiver into Program Mode. The doors will lock and then unlock in order to confirm program mode.
  4. Important: The scan tool must stay connected until all of the transmitters are programmed.
  5. Press and hold the LOCK button and the UNLOCK button simultaneously on one transmitter. After a delay of 15 seconds, the doors will lock and unlock in order to confirm the programming of that transmitter.
  6. Repeat the previous step in order to program up to 4 transmitters.
  7. Remove the scan tool.
  8. Operate the transmitter functions in order to verify correct system operation.
Apr 12, 2016 | Buick Cars & Trucks
How can I program my remote?
Remote for ? door unlock / lock , remote start , garage door opener .
If the door lock / unlock , panic alarm ,remote start . You can't dealer only . Need a factory scan tool .
Important: Up to 4 transmitters can be programmed. Do not operate or program the transmitters in the vicinity of other vehicles that are in the keyless entry program mode. This prevents the programming of the transmitters to the incorrect vehicle. The order in which the transmitters are programmed is important. The first transmitter programmed will be transmitter #1, and the second transmitter programmed will be transmitter #2. Use care to program the transmitters correctly.
Invalidate All
This procedure will erase all keyless entry transmitters from memory.
With the scan tool, select Body.
Select Remote Control Door Lock Receiver (RCDLR).
Select Module Setup.
Select Invalidate All Fobs.
Follow the scan tool on screen instructions.
Transmitter Slot Programming
Transmitter slot programming allows a single transmitter to be programmed into a specific slot without affecting any of the other programmed transmitters. By using slot programming, the transmitter originally programmed to a specific slot is erased and the new transmitter learned in its placed.
Select the key fob desired to be programmed.
Exit the vehicle. Operate all functions on transmitters to verify correct system operation.
Jun 05, 2015 | 2007 Buick LaCrosse CXL Sedan
Esky trainer does not sync with transmitter! It worked for a few weeks, changed the transmitter 9V battery and charged the collar fully (until green). It stopped working. I read the manual again and...
It may be silly, but is the new battery giving 9 volts?
Sometimes a new one lost it's voltage along the way.
Leds will work just fine, so can give you the wrong message.
I hope it is as simple as this.
Feb 24, 2014 | Hisgadget Inc. Esky 100LV Rechargeable...
I have a 2000 ford mustang. Suddenly my keyless entry remote stopped working. I replaced the battery and turned the off and on 8 times and the locks cycled. after which i pushed the unlock but nothing...
The keyless entry system is controlled by the (GEM) - generic electronic module .
Keyless Entry The electronic door lock system has two main components:
  • generic electronic module (GEM)(14B204)
  • keyless entry remote transmitter (15K601)
  • NOTE: Battery power and ground must be remove before disconnecting the GEM connectors to avoid setting false codes.
    Power Locks Operation The power locks feature allows the customer to lock and unlock the doors via momentary switches located on the driver and passenger door. When the GEM detects a momentary press of the driver or passenger lock button, the GEM will supply power to the driver or passenger lock actuators for approximately 250 ms from relays internal to the GEM. When the GEM detects a momentary press of the driver or passenger unlock button, the GEM will supply power to the driver or passenger unlock actuators for approximately 250 ms from relays internal to the GEM.
    Remote Keyless Entry Door Locks Operation The remote entry feature allows the customer to unlock the driver door, unlock all doors, and lock all doors using a valid remote transmitter as long as the ignition switch is not in RUN or START. The driver door is unlocked whenever the GEM detects a valid remote transmitter unlock transmission. All the doors are unlocked when the GEM detects a second valid remote transmitter unlock transmission within three seconds of the first transmission. All the doors are locked when the GEM detects a valid remote transmitter lock transmission. If the GEM detects a second valid remote transmitter lock transmission within three seconds of the first transmission, the doors will lock again, the horn will sound for 20 ms and the parking lamps will flash for 200 ms to indicate the doors are locked. If the GEM detects the driver or passenger door is ajar during the second lock transmission, the doors are locked again and the horn is sounded twice. If the GEM detects a valid remote transmitter lock transmission within three seconds of detecting a valid remote transmitter unlock transmission, the GEM will lock all the doors
    • The doors do not lock/unlock using the remote transmitter
    • Ignition switch.
    • GEM.
    • Remote transmitter.
    • Remote transmitter batteries.
    • GO to Pinpoint Test C .
    You followed the program instructions to the letter ? Programming -Keyless Entry Remote Transmitter NOTE: All keyless entry remote transmitters (15K601) must be programmed at the same time.
    NOTE: All previous transmitter identification codes (TIC's) will be erased when programming mode is entered.
    NOTE: To program (or reprogram) the keyless entry remote transmitters into the generic electronic module (GEM)(14B204), perform the following steps.
    1. Turn the ignition from OFF to RUN eight times within 10 seconds, ending in RUN. If the GEM has successfully entered program mode, it will lock and unlock all the doors.
    1. NOTE: The first TIC must be entered within 7.5 seconds of entering the program mode and additional TICs must be entered within 7.5 seconds of the first TIC. The programming mode is exited whenever the timing constraints are not met.
      Press any button on a keyless entry remote transmitter, and the doors will lock and then unlock to confirm that each keyless entry remote transmitter has been programmed.
    1. If the door locks do not respond for any keyless entry remote transmitter, wait for several seconds and press the button again.
    1. Turn the ignition switch to the OFF position, or wait up to five minutes after step 1, to exit program mode. If a keyless entry remote transmitter has been programmed (or reprogrammed), the GEM will lock and unlock all the doors one last time.
    1. Take an have the vehicle checked for DTC'S
B1396 Power Door Lock Circuit Short to Battery GEM GO to Pinpoint Test B . B1397 Power Door Unlock Circuit Short to Battery GEM
Apr 12, 2017 | Ford Mustang Cars & Trucks
There are 3 wires on the itrip and i need to repair the car socket which one's goes to which soder points
if these are your letters on the board
this is with the car socket to your right
A Green
S Yellow
LR Brown or Orange
LG Blue
G Black
V Red
My problem is the other side need white blue and purple
Aug 17, 2011 | Griffin Technology - iTrip Auto Dock...
I just bought a remote and I need to program it in an 06 chevy equinox. How do I do it?
  2. Turn ON the ignition with the engine OFF.
  3. Select Body Control Module.
  4. Select Special Functions.
  5. Select Program Key Fobs.
  6. If you are adding a transmitter to the system, or are replacing a transmitter, choose the Add/Replace Key Fobs option. This allows new transmitters to be added without deleting those currently programmed to the module. If you are replacing all transmitters or none of the transmitters are working, choose the Clear memory and Program All Fobs option. This prevents lost or stolen transmitters from being used to access the vehicle.
  7. Follow the scan tool on-screen directions.
  8. After programming the last transmitter, remove the scan tool.
  9. Exit the vehicle. Attempt to lock/unlock the doors to verify the programming.
  10. Operate the transmitter functions in order to verify correct system operation.
  11. if you don't have a scan tool then you can go to a lock smith they can do it cheaper than the dealer sometime.
May 25, 2010 | 2006 Chevrolet Equinox
I have a 2001 Accord and if I hit the unlock button and do not open any door within a certain amount of time (2-5 minutes) it automatically re-locks it. Is there a setting I can change to prevent this...
Hope the following procedures helps.
TRANSMITTER TEST
NOTE:
If the doors unlock or lock with the transmitter, but the LED on the transmitter does not come on, the LED is faulty; replace the transmitter.
If any door is open, you cannot lock or unlock the door with the transmitter.
If you unlocked the doors with the transmitter, but do not open any of the doors within 30 seconds, the doors relock automatically. ?
The doors do not lock or unlock with the transmitter if the ignition key is inserted in the ignition switch.
1. Press the lock or unlock button 5 or 6 times to reset the transmitter.
If the locks work, the transmitter is OK.
If the locks don't work, go to step 2.
2. Open the transmitter and check for water damage.
If you find any water damage, replace the transmitter.
If there is no water damage, go to step 3.
3. Replace the transmitter battery (A) with a new one, and try to lock and unlock the doors with the transmitter by pressing the lock or unlock button 5 or 6 times.
If the doors lock and unlock, the transmitter is OK.
If the doors don't lock and unlock, go to step 4.
NOTE: The transmitters for LX models and EX models are different and are not interchangeable.
4. Reprogram the transmitter, then try to lock and unlock the doors (see Transmitter Programming ).
If the doors don't lock and unlock, replace the transmitter.
TRANSMITTER PROGRAMMING
Storing transmitter codes:
The codes of up to three transmitters can be read into the keyless receiver unit memory. (If a fourth code is stored, the code which was input first will be erased.)
NOTE: It is important to maintain the time limits between the steps.
1. Turn the ignition switch ON (II).
2. Within 1 to 4 sec., push the transmitter lock or unlock button with the transmitter aimed at the keyless receiver unit behind the glove box.
3. Within 1 to 4 sec., turn the ignition switch OFF.
4. Within 1 to 4 sec., turn the ignition switch ON (II).
5. Within 1 to 4 sec., push the transmitter lock or unlock button with the transmitter aimed at the keyless receiver unit behind the glove box.
6. Within 1 to 4 sec., turn the ignition switch OFF.
7. Within 4 sec., turn the ignition switch ON (II).
8. Within 1 to 4 sec., push the transmitter lock or unlock button with the transmitter aimed at the keyless receiver unit behind the glove box.
9. Within 1 to 4 sec., turn the ignition switch OFF.
10. Within 4 sec., turn the ignition switch ON (II).
11. Within 1 to 4 sec., push the transmitter lock or unlock button with the transmitter aimed at the keyless receiver unit behind the glove box.
12. Confirm you can hear the sound of the door lock actuators. Within 1 to 4 sec., push the transmitter lock or unlock button again.
13. Within 15 sec., aim the remaining transmitters at the keyless receiver unit (up to two additional ones) whose codes you want to store at the receiver, and press the transmitter lock or unlock buttons. Confirm that you can hear the sound of the door lock actuators after each transmitter code is stored.
14. Turn the ignition switch OFF, and pull out the key.
15. Confirm proper operation of the transmitters.
Cheers!
Ryan
Jun 11, 2009 | 1998 Honda Accord
How do I program my new Suzuki keyless entry remote to work with our new SUV?
I bought a remote the other day and got these instructions with it. They worked!
1. Make sure vehicle is in Park
2. Press Vehicle Information button (has the icon of a car and an 'i')until 'PRESS *check mark* TO RELEARN REMOTE KEY' displays.
3. Press set/reset button. The message 'REMOTE KEY LEARNING ACTIVE' will display.
4. Press and hold the lock and unlock buttons on the transmitter at the same time for about 15 seconds. A beep will sound indicating that the transmitter is matched.
5. To match additional transmitters at this time, repeat Step 3. Each vehicle can have a maximum of four transmitters matched to it.
6. To exit the program mode, you must cycle the key to LOCK.
Jul 20, 2008 | 2007 Suzuki XL-7
PrintE-Z.com 13127G, Laser Letter of Transmittal - Parchment Logo
156 people viewed this question
Top PrintE-Z.com Home Experts
john h
Tom Chichester
Are you a PrintE-Z.com Home Expert? Answer questions, earn points and help others
