Question about EcoGecko Eco Friendly 360 Degree Rotating Magic Mop and Spin Dry
Repair of Eco 360 degree Rotating magic mop.
When i press Foot presser spin drive wont rotate when i release it Rotates, How to Repair it
My acer screen is sideways. how do i fix it?
Computer users occasionally have a need to rotate, or "flip," a monitor display to be better able to read long documents or to view pictures. Because rotating a computer screen is such a basic function, modern operating systems (Windows XP and up) include hot keys and display options that enable the user to rotate the computer screen by 90, 180 and 270 degrees. Rotating the computer screen allows for more display options. For instance, when rotated 90 degrees, a 1680x1050 monitor becomes a 1050x1680 monitor, which provides more vertical pixels than a standard display.
Windows XP/Vista Monitor Orientation
Minimize any windows or programs to the taskbar. Click the desktop. Press "CTRL" + "ALT" at the same time. Press one of the arrow keys to flip the monitor orientation by 90, 180 or 270 degrees. The left arrow rotates the computer screen 90 degrees; the down arrow rotates the computer screen 180 degrees; the right arrow rotates the computer screen 270 degrees; the up arrow resets the monitor orientation. Rotate the computer screen in Windows Vista by opening the Control Panel, searching for "Tablet PC" and changing the "Orientation" drop box to the desired rotation. b> Windows 7 Monitor Orientation b> Click the Start menu at the lower-left hand part of the screen, and open the Control Panel. Select "Display," then click "Change display settings" from the left column. When using multiple monitors, select the monitor that you would like to rotate. Click the drop box next to the "Orientation:" option. Select the desired rotation and click "Apply." Click "Keep Changes" or "Revert," depending on preference. Click "Apply" in the Display Settings window. Click "OK" to finish.
Apr 11, 2013 | Acer Computers & Internet
Rotate screen back to normal
Feb 23, 2013 | Gateway Computers & Internet
My screen does not flip 180 degrees when i turn the screen around
Jan 28, 2013 | Panasonic Toughbook 19 Rugged Notebook -...
My son has rotated the screen on my fujitsu lifebook s series so now it is upside down! How do i rotate it back? Please help!
Minimize any windows or programs to the taskbar. Click the desktop. Press "CTRL" + "ALT" at the same time. Press one of the arrow keys to flip the monitor orientation by 90, 180 or 270 degrees. The left arrow rotates the computer screen 90 degrees; the down arrow rotates the computer screen 180 degrees; the right arrow rotates the computer screen 270 degrees; the up arrow resets the monitor orientation. Rotate the computer screen in Windows Vista by opening the Control Panel, searching for "Tablet PC" and changing the "Orientation" drop box to the desired rotation. b> Windows 7 Monitor Orientation b> Click the Start menu at the lower-left hand part of the screen, and open the Control Panel. Select "Display," then click "Change display settings" from the left column. When using multiple monitors, select the monitor that you would like to rotate. Click the drop box next to the "Orientation:" option. Select the desired rotation and click "Apply." Click "Keep Changes" or "Revert," depending on preference. Click "Apply" in the Display Settings window. Click "OK" to finish. Hope this helps
Jan 21, 2013 | Intel S6240 Notebook
Acer tablet troubleshooting
b>
Jan 14, 2013 | Computers & Internet
Change screen orientation
b>
Dec 14, 2012 | Dell Computers & Internet
The slide advance on my Kodak Carousel 750 starts as soon as the machine is turned on with viewing lasting about 1/3 of a second. You can no longer manually or by remote, advance or reverse the slides at...
There are 2 contacts in the slide change mechanism that control projector cycling. One rotates 360 degrees for every slide change, the other traps the rotating contact and holds it until the forward or reverse buttons are pushed again.
Given the age of the projector, my guess is that one of the 2 contacts are burned off, causing the projector to continuous cycle.
You may be able to gently(!) bend the "J"-shaped contact so that it once again stops the straight contact that rotates 360 degrees per cycle. This is a risky (and temporary) fix.
There are still dealers that are trained to make this repair. There is also a dealer online (www,micro-tools.com) that stocks many projector parts.
But it may be more cost-effective to shop for a gently used projector online (www.vinevalleyimaging.com is a good place to start).
Good Luck !!
May 24, 2011 | Kodak Office Equipment & Supplies
Karcher Dirtblaster jet does not rotate
Had the same problem and it turned out to be an obstruction in the nozzle and I mean a small obstruction, it looked like an ant leg. I pushed a 1mm drill bit through and now it works fine.
Apr 13, 2010 | Karcher K2.26 Electric Power Washer
Does the fan on back plate of the DVR-S150 spin continously
It should run all the time, before your DVR-S150
overheats. The fan is there to prevent overheating.
Sep 21, 2009 | Yamaha DVR-S150 DVD Player
My magic bullet stops rotating
The Magic Bullet power base is designed with HIGH TORQUE MOTORS and it is NOT TO BE USED FOR MORE THAN A MINUTE PER USE.Otherwise its gonna last a long time. You need to buy a new one or a refurbished one. Search google with keywords "amazon magic bullet power base".
Aug 13, 2009 | As Seen On TV Magic Bullet Food Processor
EcoGecko Eco Friendly 360 Degree Rotating Magic Mop and Spin Dry Logo
454 people viewed this question
Top EcoGecko Home Experts
Donni Steen
Tom Chichester
Are you an EcoGecko Home Expert? Answer questions, earn points and help others
