Question about Refrigerators
I have a Vitrifrigo C 130l 12/24Vcc frifge in my CARAVAN. I have noticed that the fridge FAN motor is runnung contunously. It trips out then trips straight back in again. It did not do this previously
I have a Vitrifrigo C 130l 12/24Vcc frifge in my CARAVAN. I have noticed that the fridge FAN motor is runnung contunously. It trips out then trips straight back in again. It did not do this previously. Can you advise please
    Champion:
  • 216 Answers
CLEAN COIL, CK DOOR SEAL, ADJUST REFRIGERENT.
Posted on Nov 10, 2014
5 Suggested Answers
  • 159 Answers
SOURCE: caravan fridge tripping when connected to electricity
on what voltage doe it work then i can tell you exactly how to wire it
Posted on Jun 01, 2009
aasc
  • 1606 Answers
SOURCE: PULLED FRIDGE OUT, REMOVED BACK PANEL, EVAPORATOR
Yes , motor is bad . May not start , next time cuts off . The fan in the back by the compressor , is called the condensor fan motor . I would suggest cleaning the coils in front at the bottom , of dust , lint , pet hair , etc , before replaceing the fan motor . Also , clean the fan blade before reinstalling the motor .
Posted on Sep 12, 2009
aasc
  • 1606 Answers
SOURCE: I have a GSS25KGMD fridge. I opened the Fridge
Your refrig light switch does control the freezer fan and the refrig light bulb . Replace the refrig light switch .
Open the refrig door , freezer fan goes off and the refrig light comes on .
Posted on Nov 03, 2009
MARWAT
  • 124 Answers
SOURCE: Why has my vitrifrigo 5060 3 way fridge got no lights coming on and is not working could this be the fuse
may be fuse or may b in pawer plug
Posted on May 12, 2014
We don't know how to hold down our vitrifrigo fridge in our motorhome. There were no instructions with the fridge.Its a C130 I.
talk with a caravan service center but you can remove the rubber feet and front adjuster bolts and use those points to bolt the fridge to the floor of the motor home
advice from people who install fridges to vans and motor homes would be a good place to start
May 06, 2017 | Refrigerators
Ther refrigerator side is cold and there is ice in the freezer side. I've raised the temperature on both sides but the units keeps runnung and never stops.
There is ice on the freezer fan motor. If it is not ruined, simply turning the fridge off for a day and leaving the doors open might clear out the blockage and the fan may start working again. If not, then you need a new fan assy. If you are not really handy on repairing these kinds of things, prepare to spend a few hundred to have it fixed by a qualified repairman. When you shut the fridge off, make sure you put your food in another fridge or cooler with some ice in it... just sayin's all.
Nov 24, 2014 | Refrigerators
Fridge troubleshooting
The motor should not be running continuously. If it is, then it is because the internal temps are not going down low enough for the thermostat to shut the compressor down. If the temp is not low enough, the temperature of the coolant returning to the compressor is higher than what it should be and that the cool refrigerant returning to the compressor cools that motor down. If it does not, the motor will over heat and often shut down for cooling.
Ice buildup on the evaporator coils will cause a warmer running fridge. If the unit has a self defroster then it is not working and responsible for the anomaly.
Nov 27, 2013 | Refrigerators
AC fan blows less air after extended use
Sounds to me the blower motor is on it's way out and should be replaced. Even though they sound like there working doesn't mean everything is ok with it there are different parts on it that could go wrong and they way to fix it is with another blower fan and not a bad idea to do the resistor at the same time located in the blower box with about 4 wires coming out of it with one or two screws holding it in place all is located under dash behind the glove box area.
Aug 03, 2012 | 2002 Dodge Grand Caravan
I have a GSS25KGMD fridge. I opened the Fridge compartment top part was very warm and the bottom was cooler. Upon investigating more I noticed that the fridge bulb was very hot. So I pushed the fridge...
Nov 03, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Kenmore fridge not cooling
try www.partselect.com
would help if you had a part number
Sep 30, 2009 | Kenmore 53642 / 53644 Side by Side...
Frigidaire Refrigerator not cooling
Is the fan on the bottom on? Do you hear the compressor kick off and on within a minute? No/ Is the evaporator fan running? Do you have frost on the evaporator? Frost is a sign that the defrost isnt working. If evap fan doesnt run it wont cool the refrigerator. If everything is running and no frost buildup in freezer then you have a sealed system problem and need of a tech.
Jul 25, 2009 | Kenmore 50522 / 50524 Side by Side...
Why is my air handler fan motor tripping the 20
sounds like fan motor is going bad - replace
Jun 15, 2009 | Heating & Cooling
RM4236 tripping site electrics
Paul;
Are you tripping the shore power pedestal? If so did you unplug the fridge and try it. The park pedestal breaker should be at least 30 amp and I can not believe the fridge would trip the site breaker before it tripped the breaker in your caravan. Are you sure it is the fridge? Your fridge is an old eletrolux dometic and I can not find the manual in my files. You may call Dometic and get a manual but That will not help you much. I will be more than glad to resolve your problem but I need more info.
The Dometic# is 800 366 3842. Prompt to tech dept.
Repost to us
Thank You for using Fixya
Jerry
Mar 26, 2009 | Electrolux Refrigerators
Refrigerators Logo
138 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
