Dura brand, my cassette player, one of the wheels doesn't turn?
  • 5,533 Answers
That's correct!
Posted on Nov 10, 2014
Dura brand,why is the tape coming out of the cassette when I pay it?
Hi there
This is an answer which is general to all tape cassette decks. I think it probably applies to yours but this may or may not be the case.
The tape is transported past the "read" head by a pinch wheel and spindle that come up into the cassette on either side of the tape. The spindle runs at a very constant speed and with the tape between this and the (rubber) pinch wheel sounds are transferred fro the read head to the electronics for amplification etc. We are not concerned with that here but with what physically happens to the tape after the pinch wheel. Under normal circumstances a belt is driven from the electric motor to the take-up reel of the cassette. This usually runs slightly faster than the spindle/ pinch wheel so that the tape winds cleanly onto the take-up reel. If this belt is loose, has come off entirely or is otherwise not working properly, then the spindle/pinch wheel will continue to feed the tape but it has nowhere to go because it is not being wound onto the take-up reel, except out of the cassette into the tape desk mechanism. In this case it often gets wrapped around the spindle/pinch wheel assembly and gets into a very nasty tangle, causing serious damage to the tape and possible damage to the deck.
Hope this explains your problem.
Cheers
Nov 10, 2014 | Audio Players & Recorders
Dura brand,one of the wheels doesn't turn on my cassette player
On cassette player only one wheel will turn! That's how it works!
My AWIA HS-TX426 can't play cassette tapes
John Check if the capstan is rotating This is a shaft that touch the rubber wheel in the cassette Does the motor run properly? You say it is new then it should be under warranty take it back to the supplier and they should repair or replace it. If it was standing for a very long time i.e. 20 or more years then the mechanism is bound and if you know what you do then lubricate with sewing machine oil on all levers and shafts the motor can also do with a single drop ( 1 millimeter wire dipped for 25 mm in the oil and the oil that drops off, is the size of a measured drop of oil) I did get some Revox machines that were standing for such a long time and I had to use a pump pliers to get those wheel to turn they were BOUND but after playing it for a while they became working again
Apr 24, 2013 | Audio Players & Recorders
Where is the rewind on this cassette player?
Cheap cassette players have no rewind feature. This allows the mechanism to be simpler and cheaper; they just 'pull' the tape forward constantly, without the pinch wheel for "fast" [sic] and with the pinch wheel for "play".
To work out if this is the problem with your cassette player, look inside with no cassette inserted. If one of the spindles is plain, without the "three-pronged" device to engage with the spool, then you have the cheap device with no rewind. Turn the tape over, and fast-forward.
Jan 19, 2011 | Audio Players & Recorders
When I play cassettes the tape comes out the bottom of the cassette and gets wrinkled
one of the drive wheels has siezed i expect if you can trick the close switch and press play do both wheels turn ?? if one doesnt give it a turn to free it up
Dec 26, 2009 | Sony CD Radio Cassette Boombox, CFD-E90...
Dura ace sti hangs on middle cogs on cassette.
change the cable ,because the have damage in the middle,
Oct 20, 2009 | Shimano Cycling
HELLO, I HAVE A DURA ACE 7900 MODEL CASSETTE AND WOULD LIKE TO PUT IT ON A KSYRIUM SL RIM, DO I HAVE TO PUT THE SPACER ON IT BEFORE THE WHOLE CASSETTE GOES ON? THE CASSETTE IS A 12-25 GEAR.
In my experience with Shimano cassettes on Mavic wheels, the answer is "yes" but i had a mountain wheel and cassette. The only way to know is to put it on and see if there is slop in the fitment. If there is, then you have your answer. i also had this problem with Mavic: i had to adjust the high and low settings on my rear derailleur because of the awkward spacing of the Mavic freehub. Just something you should be aware of in case you have difficulty with shifting after the install. By the way - although they are inferior cassettes, SRAM cassettes seem to fit Mavic freehubs better.
Regards,
matt
Sep 14, 2009 | Cannondale Cycling
The wheels on the tape cassette to not turn
open the unit, check the belt that drives the wheel.
Apr 03, 2009 | Panasonic Audio Players & Recorders
46 people viewed this question
 Grubhead
Grubhead
