Question about Bissell Cleanview Quickwash Carpet Cleaner
Quickwash - when I connect solution bottle to shampooer the fluid pores out without pressing trigger.
I have a hobart 135 handler that with machine plugged in and turned on the wire has constant juice and the gas cylonoid is flowing gas from the bottle without the trigger being pressed. my dealer said it...
Hi:
Have you disconnect the gun's power plug? If the wire and gas stop flowing by doing this action, then your problem is the gun's trigger. If the machine continues to feed gas and wire with the gun disconnected then yes, it is the pc board.
Good luck.
Aug 25, 2011 | Hobart Welding Tools
Been cleaning for 2 hours now with my Bissell Quicksteamer and on my next run i presses the water release trigger on the handle and water isnt being squirted on the carpet..why?
ran out of water? (if water) >
Is there some form of water filter?
Problem with the trigger?
Bad steam heating element or the power connection supplying the power to it?
Of could it just be tired and need a break? (grin)
Best Regards
Ck
Aug 16, 2011 | Vacuums
Vax Carpet shampooer V - 027CC. water not coming through when trigger pressed. Bottle is filled.
Check that the outlet bung at the bottom of the bottle is not jammed closed or that the operating rod from the trigger has not become dislodged. It is best to remove the bottle from the machine to do this.
Jan 16, 2011 | Vacuums
1999 ford explorer 2x4 4OHC AT transmission problem
Change fluid and trans filter check magnet in trans pan for metal clean pan with a rag refill with senthic fluid leave a court low let it idle till hot then add a bottle of trans x or lucas leave idlen work the trans from 1st to park letting the trans take gear an let it stay in gear for a little bit then back to park that help move the fluid threw the trans drive easy for a week ir you Lucas pore half qurt of trans fluid in use the rest of fluid to thin down Lucas its really thick repeat till the bottle of lacus is in I hope this helps
Dec 15, 2017 | 1999 Ford Explorer
I need to top up my Power Steering Fluid on my 2000 Kia Rio.
If you pore this in you will destroy the power steering seals and the rack in pinion .Please take it back and get the corrected power steering fluid:)
Sep 27, 2009 | 2003 Kia Rio
How do you change the fluid and filter in the transmission of a 02 tundra?
I don't know how to change the filter I've change mine's transmission fluid by removing the drain plug in the bottom of the transmission. This only remove about 4 quarts of fluid ( it's best to measure it by poring it back into quart bottles after draining ). You refill it by poring it down the dip stick hole. Pore back in the same amount you drained out.
Jun 30, 2009 | 2002 Toyota Tundra
Rainbow aqua mate II instructions
You have the vacuum and the basin, you put them together just like when you vacuum but don't put water in the basin. There is a large white container that comes with the shampooer. you fill that up with water and then you place the vacuum cleaner and the basin on top of that. Now you will need the water hose (not the one that has the gas pump hadle). Hook that in the same spot that you do for vacuuming. Then you take the shampooing handle( it will have a trigger and a little white bottle and some tubes hooked to it) the one end of it hooks to the water hose and the other end hooks to the wands. There are 2 wands that come with your shampooer. At the end of those the shampooer head will be attached. There are two separate tubes there is a thick tube ( there two tubes fused together) and a thin tube, they hook to the large white container that you fill with water. Just look and you will see where they go. Then there is a tube that hooks to the shampooer head at the bottom. The you take the little bottle and fill it with your shampoo. You should have gotten some clips to hool onto your hose so that you can keep the tubes attached to it so they aren't in the way. You should be set. I hope I helped.
Jan 27, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Carpet shampooer
I couldn't find the exact guide for your model but the two links below are the ones bissell told me to use. http://www.bissell.com/images/UserGuides/1694-8806_607.pdf http://www.bissell.com/images/UserGuides/1697_1205.pdf I hope this helps:)
Jul 15, 2007 | Bissell 1697-7 Powersteamer Pro Deluxe...
Bissell Cleanview Quickwash Carpet Cleaner Logo
65 people viewed this question
Top Bissell Home Experts
Lawrence Oravetz
ray gallant
Are you a Bissell Home Expert? Answer questions, earn points and help others
