Question about Fuji FinePix S9000 Zoom Digital Camera
It Isn't Working
No matter what I do, charge the batteries, get new ones, plug it in, anything I do and it wont turn on.
Fuji FinePix S9000
What do I do.
The problem started when I took the memory card out and put it back in and then it just wouldn't turn on.
Thank you for helping me.
Re: It Isn't Working
My camera only switches on when it is plugged in to charge. any suggestions
Posted on Mar 21, 2013
  • 3 Answers
I just today sent my camera to Fuji to have the same thing repaired. I've read that the on-off switch tends to fail on this camera.Mine is just a few months past warranty, of course!
this is my 3rd Fuji and 1st problem though.
Good Luck.
Posted on Jan 04, 2008
0 characters
3 Points
My finepix s9000 will not turn on, it clicks a few times and then there is no power on screens or other features
remove the batteries, let it sit for a week or so, then load fresh batteries and it will turn on. Apparantly the auto shut down feature prevent it from turn on until the internal memory is erased. This is a stupid problem that Fuji should fix
Jul 09, 2010 | Fuji FinePix S9000 Zoom Digital Camera
Fuji FinePix S9000 battery change clears date/time.
I started having a similar problem with my Fuji FinePix F10 after about 3 1/2 years of problem-free use. Another poster had some really helpful advice which I thought I'd pass on. It seems there is an internal battery or capacitor which basically fails after a while, meaning date/time settings etc are lost when the battery is removed. (Some people claim this is a motherboard/chip problem instead - seems to be contentious!) So the camera is faulty, but the problem can be worked around.
The advice I found, which worked for my camera, was this:
- Turn off camera and leave off for approx 15 seconds before opening battery door.
- Change battery quickly (within a few seconds).
- Close battery door and leave camera off for approx 15 secs before turning back on.
This retained all settings when I tested it multiple times. I imagine it might not work if changing over a totally dead battery though.
Hope it helps!
Sep 28, 2009 | Fuji FinePix S9000 Zoom Digital Camera
My Fuji Finepix S2pro wont turn on
try getting new batteries.. sometimes the rechargable ones just lose the charge.. instead of rechargables try using throw aways. you can try and contact fuji but like myself and others they will just give you 5 differant numbers to call and the problem will not be solved
May 30, 2009 | Fuji FinePix S2 Pro Digital Camera
Fuji finepix e510 won't turn on
If your Fuji e510 battery system is like the Finepix S3000 or the S3100 take a look at the following postings: Finepix S3100 (Camera power does not come on...) by banobo of Feb 07,2008 and check out solutions #2 & #4, (Mine is #4), Also see posting by "tomawamba for Fuji S3000" and my slightly differently worded solution.(Only one posted). May be best to get camera working before connecting with anything else. Good luck, be patient.
Jan 18, 2009 | Fuji FinePix E510 Digital Camera
Fuji F10 No power
You said that you changed the battery, did you put it in the right way around?.
I had exactly the same trouble, changed the battery (got it on ebay for £2.99) charged it and it worked.
Having said that, I closed the lense from external power. If the camera wont operate from external power then the camera is probably dead.
Sep 13, 2008 | Fuji FinePix F10 Digital Camera
Camera Won't Charge
my finepixz3 got wet. but after a few days it worked! but when the battery ran out it wont charge. is it the battery? it turned on a few sec when its in the cradle but it wont last after a few seconds it would turned off. is it the battery or the camera itself?
Sep 01, 2008 | Fuji FinePix Z3 Digital Camera
Initializing picture cards for Fuji FinePix S9000 digital camera
As you have downloaded all the pics to ur computer. Take the card in ur hand, wipe it's copper plates firmly with your thumb, Insert the card in your camera and format it. It should start working. Mine worked.Good Luck
Jul 15, 2008 | Fuji FinePix S7000 Digital Camera
Adding lenses to s9000
Yes. but only the conversion lens
Mar 05, 2008 | Fuji FinePix S9000 Zoom Digital Camera
Black screen
This is a CCD sensor ( see pic below from Canon camera with same pixalage and specs ) problem : outputting too much noise or nothing at all so the sensor must be replaced ( not a big job but ha sto be done by someone with experience and the right parts ). Fuji will repair free of charge , if I am not mistaken, so you need to contact your Fuji agent .b16210b.jpg
Nov 25, 2007 | Fuji FinePix Z1 Digital Camera
FinePix S9000
hi, This is actually a very good camera.Did you insert the batteries in reverse accidently?? this seems to be a problem with the switching circuit from battery and power adapter.. did you keep the camera with batteries for a long time with out use?? U can give it to the nearest service to get the circuit checked. all the best my friend.. sreejith
Jun 20, 2007 | Fuji FinePix S9000 Zoom Digital Camera
Fuji FinePix S9000 Zoom Digital Camera Logo
226 people viewed this question
Top Fuji Digital Cameras Experts
Richard Roberts
Are you a Fuji Digital Camera Expert? Answer questions, earn points and help others
