Question about Humidifiers
A cork will float on water because it is less dense than water. Why does the oil float on the vinegar in a bottle of salad dressing
  • 104 Answers
Because oil has non-polar molecules and vinegar has polar molecules, the two do not attract. This causes the separation of oil and vinegar. When you combine oil and vinegar, "oil will float on top of vinegar because it is less dense,"
Read more : http://www.ehow.com/facts_7473580_vinegar-oil-not-stay-mixed.html
Posted on Nov 10, 2014
My humidifier is spitting water plus steam. Kind of weird. Didnt do before. Level of water is ok, added 1 flat tablespoon of sea salt and 2 tabkespoons of vick oil. What's happening?
More than likely, mineral scale has built up inside the tank and the mist tubing.
To clean it, turn the unit OFF & unplug it. Empty any remaining solution that's in the tank and refill it with a 50/50 solution of White Vinegar and Bottled Distilled Water. Plug the unit in and turn it ON. Allow it to run for 5 minutes, then turn unit OFF and allow it to soak for 30 minutes to and hour.
Then turn the unit back ON. If the water spitting has stopped, run the unit unit is half empty. Turn it OFF, unplug it and empty any of the remaining solution. Refill with Bottled Distilled Water and run it until it's empty. Doing so, will flush out any of the remaining solution and scale.
In the future, it is best to use Bottled Distilled Water, rather than tap water. As the Distilled Water does not contain any harmful minerals or chemicals.
Hope this helped you and thanks for choosing FixYa.
Sep 15, 2011 | Vicks V150SG 1 Gallon Humidifier
Model V5100NS - Nebulizer has heavy deposits from water. Attempts at cleaaning (with vinegar) has caused black coating to be removed, revealing rougher, gray surface below.
mbethlinn, it sounds like you have more than water deposit issues. Not sure had you tried to clean the unit with vinegar, but if you didn't dilute it (50/50 White Distilled Vinegar and Bottled Distilled Water) and you used your tap water, that wasn't really going to solve the problem. As you tap water has a lot of minerals in it to start with.. I suspect, it's well water and there my be a problem with the water pipes in your home (i.e. Galvanized pipes) . Which over time deteriorate from the inside out and contaminate the water. That's why they haven't been allowed in almost 20 years in new home construction. Or there may be just a short section of Galvanized pipe, somewhere in your water piping system.
In any event, at this point the best solution is to use the mixture I mentioned above and allow it to soak overnight. Then flush it with Bottled Distilled Water. In the future, knowing what you already know about your water supply, you would be better served to always use Bottled Distilled Water in your humidifier, rather than tap water.
Hope this helps to solve your problem.
May 20, 2011 | Vicks Ultrasonic V5100 Humidifier
My vaporizer has stopped making steam. It's only a couple months old. Help!
It probably has a calcium and mineral deposit buildup, that has clogged the unit. Especially, if you're using well water to fill the tank.
To solve this problem, empty the tank of any water that may still be in it and mix a 50/50 solution of White Vinegar and Bottled Distilled Water. Fill the tank with the solution and let it sit for i hour. Then turn the unit ON and let it run, until it starts producing humidity. Once it does, wait 10 minutes and turn the unit OFF and empty any remaining solution from the tank. Refill the tank with Bottled Distilled Water and run the unit for 10 minutes. This will flush the system of the Vinegar and Water solution. It's best to empty the tank again and refill with Bottled Distilled Water and use the humidifier as you normally would. I would highly recommend using Bottled Distilled Water from now on. This will eliminate any future calcium and mineral buildup and having to flush the unit repeatedly.
Hope this helps you solve the problem. Please let me know.
Apr 09, 2011 | Vicks Humidifiers
Filled Watertank; water will not go open valve and go into mister area
It may be clogged with mineral scale. Empty the water that you now have in the tank and refill it with a 50/50 solution of White Vinegar and Bottled Distilled Water. Let it soak for several hours and then turn the unit ON. If it starts working as it should. let it run another 5 minutes, turn it OF and empty the tank. Refill the tank with Bottled Distilled Water and allow it to run at least 45 minutes to flush the system. After that, if you do not detect any vinegar odor, you can continue to use the remaining Distilled water.
If the unit didn't work as it should have after several hours of soaking. Turn the unit OFF and let it soak overnight. If this solved the problem, I would recommend that you continue to use Bottled Distilled Water for normal operation, rather than tap water.
Hope this helped solve the problem
Mar 22, 2011 | Vicks Warm Mist V745A 1 Gallon Humidifier
My water is black. is it now unsafe to use?
The question is why is it black? Is it mold or mildew? Has the unit every been cleaned and flushed regularly? If you answered NO, to the last question, that may be the problem. You can flush the system by using a 50/50 solution of White Vinegar and Bottled Distilled Water. After doing that, wash the interior of the water container with soap and water. Then run another flush cycle of Bottled Distilled Water. In the future, if this was the problem, use bottled distilled water only for humidifying purposes.
If the above was not the problem, there may possibly been some type of oil leak from the motor or one of the rubber gaskets is breaking down and polluting the water. Until you solve the problem, discontinue using the unit.
Mar 21, 2011 | Vicks Warm Steam Vaporizer 1.5 Gallon...
How do I clean it?
If you're asking how to clean the inner workings of the humidifier ... Run a 50/50 solution of White Vinegar and Water through it. Then flush it with Bottled Distilled Water. As a matter of fact, using Bottled Distilled Water all the time, will cut down on having to clean the unit as often. Distilled water has no minerals and will not produce scale, like tap water.
Mar 10, 2011 | Slant Fin Cool Mist GF-220 Humidifier
When i first got it, it was working grate after 3 days it dosent produce much steam as before u can even smell it
The humidifier may be partially clogged with mineral scale. Especially, if you're using well water. It can be cleaned by running the humidifier with with a 50/50 solution of Bottled Distilled Water and White Vinegar in it. Then flushing it with bottled distilled water through another complete cycle.
In the the future, you may want to use Bottled Distilled Water rather than tap water. It's inexpensive (about $1.00 per gallon) and can purchased at most super markets and pharmacies.
Hope this helps solve your problem.
Mar 02, 2011 | Vicks Warm Steam Vaporizer 1.5 Gallon...
Filter lasting only about one week--"needle" almost on Red model SCM3502 cool most humidifier
If your water is well water, more than likely that's the problem. To many minerals and iron. Try cleaning the humidifier with a 50/50 solution of white vinegar and either bottled spring water or distilled water. Fill the tank about half way and run the humidifier until the tank is almost empty. You may want to do this outside in garage if possible, because of the vinegar odor. Then run a full tank of bottled Spring Water or Distilled water through it, to flush out any vinegar residue.
I would highly recommend, that if in fact you're using well water, stop using the well water and switch to bottled spring water or distilled water.
Hope this solves your problem. Please let me know.
Rich
Feb 07, 2011 | Sunbeam Humidifiers
Mist coning out leavs white dust all over wood work, why?
More than likely the problem is minerals in the water. Impeller and ultrasonic designs send these minerals into the air. If the water in your area contains a lot of minerals, you will notice them as dust.
I would suggest that if you're using well water, switch to using bottled spring water or bottled distilled water. But you'll need to flush out your humidifier first. Use a 50/50 solution of White Vinegar and water. Fill the tank about half way and run the humidifier until the tank is almost empty. You may want to do this in a garage, if you have access to one, so that the vinegar odor won't remain in the house. Once this has been accomplished, dump out any of the remaining solution and flush the unit again with bottle spring water or distilled water. That should do the trick
Even if you aren't using well water, since your water supply has a high mineral content. I would strongly encourage you to use bottled spring water or distilled water in the future. By the way, a gallon of Distilled Water cost a lot less than bottled spring water. In my area I can get a gallon of distilled water from CVS Pharmacy or Food Lion for about $1.00.
Good luck. Please let me know if this solved your problem.
Rich
Feb 07, 2011 | Sunbeam Ultrasonic Humidifier
Having trouble finding Undiluted white vinegar for cleaning
Hi dolphinblu...
Amazon offers pretty large number of articles (Undiluted white vinegar), click here Amazon com Undiluted white vinegar and pick one (who fits your needs, price etc..)
I hope this was helpful. enjoy
Nov 20, 2008 | Honeywell QuietCare HCM-630 Humidifier
Humidifiers Logo
88 people viewed this question
Top Humidifiers Experts
Mack Baxter
Dennis
Are you a Humidifier Expert? Answer questions, earn points and help others
