Question about Husqvarna Riding Lawn Mower 42 Inch Cut Yth2042
Why won't the mower move forward or backward even though the engine is running and the blade will engage?
The engine will start, the blade will engage, but it will not go into gear either forward or backward. It has an automatic hydrostatic gear shifter that's variable speed forward or backward.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 181 Answers
First off, riding mowers do not "go into gear"; nor can they be shifted into or out of gear...nor, as a matter of fact are they "automatic" or do they have "automatic" transmissions. Instead, the so-called hydrostatic "transmission" is nothing more than the sense one gets--encouraged by mfr/seller misdirection (or product ignorance)--that a mower works just like a car...rather than being powered by nothing more than a belt that turns a wee little hydraulic motor, the speed and direction of which is controlled by the foot pedal controlling volume of fluid coursing though it to hydraulically drive the drive wheels.
If your rider will not move, that means one of two things (other than fatal failure mode)...or rather two of one thing, the latter being that hydraulic fluid it not flowing, is not pumping freely, through that motor.
Reason 1 (the more likely) is that the manual-mower-push switch on the motor has been engaged to permit the mower to be pushed without the vehicle (drive wheels) being blocked...because the engine is not running, so the fluid cannot flow with the turning of the drive wheels (unless the switch is engaged).
Think of it this way. When the mower is running and the clutched engine PTO is driving the belt or shaft that drives the hydraulic motor, the direction is chosen by reversing direction of fluid flow that the motor is circulating under pressure (also called pumping) to the drive wheels. Push toe and it flows and drives wheels in the mower-forward-drive direction; push heel and it flows the other way. Now, what about when neither is pushed? Then, essentially, all channels of flow are blocked--"neutral" (if you want to think of it that way) is not freewheeling (as with a car), it is drive wheel blocked by hydraulic lock at the motor. That is why a "hydo..." equipped mower does not coast as does a car. Alternatively, suppose that you could lift up and try to rotate the drive wheels in a particular direction. You would find that the wheels resist turning (unlike rotating RWD car drive wheels to remove a drive shaft, for example)...because they are essentially hydraulically locked by the motor that is not allowing compensatory fluid circulation in any direction!
Now, to disable the manual push mode that allows the drive wheels to rotate for manual pushing, look under the mower at the drive motor. It will be at the end of the belt loop or shaft being driven at the PTO beneath the engine. Now, find some kind of protruding lever big enough to grasp. If it seems "up" push it down; if "down" push it up...just make it go the other way to release. Now, start up and drive the mower normally. But wait! Before you mow, read the below.
Reason number 2 for unexpected drive wheel drive failure is absence of fluid to drive them....because you have not check fluid level and maintained it as the instructions directed you to do. So find the fluid plenum/level-check container and add some fluid if it is low. Just a little. Then start the engine and check lever with motor running. Fill carefully to indicated level but be very careful not to over fill. The mower should now run with valuable maintenance lesson learned. And remember that neglected fluid check can greatly shorten hydraulic motor life. Oh, make sure to check fluid level again when finished....after any air has been purged...add if/as necessary.
Posted on Nov 10, 2014
4 Suggested Answers
  • 6468 Answers
SOURCE: HYDROSTATIC TRANSMISSION NOT WORKING ON NEW MOWER
there is a rod on the rear of the mower that is pulled back and lock into place this is there to push the mower around when not running it just lift the lever up and it should pull in then your ready to go
Posted on Sep 05, 2012
  • 391 Answers
SOURCE: Mower blades willnot engage
make sure the battery is fully charged, check all electrical connections and clean them with vinegar and rinse well with demineralized water afterward.
Posted on May 27, 2010
  • 6468 Answers
SOURCE: MOWER WILL NOT ENGAGE
check the fuse then see if theres power to the clutch is there a bad safety switch does the mower shut off if you get off the seat when the blades are turned on(that will test one of the safety switches)
Posted on May 06, 2012
I drove my mower into my shed after the last use and now I cannot get it to move either forward or backward, even pushing it
Lift left hand foot pedal to full extent with top of foot may find that it is not engaging idle pulley, may be time for a new drive belt
May 30, 2015 | Craftsman YT 3000 42" Kohler 22 hp Gas...
Troy-bilt riding mower won't move in forward or reverse
I had a similar problem with my TroyBilt 50 inch zero turn mower. Was cutting grass when it stopped going either forward or backward even though it would start and the PTO would move the cutting blades. Turned out the tensioner spring for the belt that drives the motors near the rear wheels had gone missing. Searched the yard where I had cut and moved the machine but couldn't find it. A new one cost me about $7.50. Put the new one on and it worked fine.
Apr 19, 2013 | Troy Bilt 175HP Manual 42" Riding Mower
Can anyone help? My Cub Cadet LT1045 won't move (foward/backward).
Hi, check that the drive belt, pulleys and shafts are all ok and that they are actually driving the transmission, hopefully you will see the problem. If the transmission is driving ok and the fwd and reverse lever is functioning as you said, the transmission may have failed. Also check the hydro release lever is functioning. Regards Phil.
Jun 25, 2012 | Cub Cadet Garden
24 hp LA165 mower. While mowing the mower stopped moving. Engine runs, blades turning but won't move forward or backward (the side lock has been released and the pin at the back is pushed in) 11...
check the connecting rod to the tranny. follow the gear handle and you should find a rod connecting the handle to the axle make sure you're in neutral and adjust the rod until the handle starts to move
Jul 17, 2011 | John Deere 24HP VTwin Hydrostatic 48"...
I have a craftsman mower with the B&S 21hp Intek OHV motor, it starts fine but when you go to engage the blade or go forward or backward or release the parking brake it will die unless you disengage...
Check the switch on the seat, of all places. There's a safety switch on the seat that will kill the engine if it's not engaged when do anything other than start and run the engine.
If the switch checks out, get back with me.
Jul 06, 2011 | Briggs & Stratton Briggs Stratton Intek V...
Won,t move
Check the pump.Thanks for asking and I hope this helps out.Please leave me 4 thumbs up.
Jul 20, 2010 | Husqvarna Zero Turn Mower Z5426
Husqvarna Riding Lawn Mower 42 Inch Cut Yth2042 Logo
374 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
