Question about Saws
I have 2 DW715 miter saws given to me, with the blades off one sounds wicked, you can spin it forward by hand but stops/locks up trying to spin in reverse. Sounds like a belt or bearing. The other one with the blade attached, blade looks like it's bouncing, but with blade removed, sounds fine and works fine. No slop on either of their shafts. The arbor bushing that slides over the shafts seems to be sloppy. You can wiggle both or rock them on the shaft. Would that make the blade wobble?. I had 2 questions in here if you are understanding my thinking.
    Sergeant:
  • 206 Answers
The first one sounds like an armature bearing - pretty easy fix if you have access to a press or even a bearing / gear puller. Make sure the saw is unplugged, remove the end cap on the motor and the 2 carbon brushes. remove the 4 screws holding the motor housing to the saw and pull it off. Then, pull the armature straight out - replace the bad bearing, and reverse process.
The second one sounds like it is missing the arbor bushing #152636-00 or it has a bad blade bolt #145344-01.
Posted on Jan 05, 2015
3 Suggested Answers
rowdy45176
  • 2176 Answers
SOURCE: Delta 36-075 miter saw. Motor ok, but blade will not spin
It sounds as though one or both of the items are stripped. They mesh to drive the blade so I would not take a chance on just replacing just one. Also when you look at this you might also want to look at replacing the bearings and brushes. Make sure you clean out the gear housing or you will have immediate problems again. Also check where you buy these parts for their recommendation on the grease that needs to be used.
Posted on Mar 14, 2009
  • 30 Answers
SOURCE: Craftsman circular saw. The
Depending on your budget, I suggest replacing the item. It sounds like your bearings are bad, which means tearing apart the case and replacing them (which don't cost much). There are two bearing encasements so you would need to replace both. If you're up for the challenge, give it a try! The bearings can typically be found on the manufacturers website.
Posted on Aug 30, 2010
HOW DO i UNLOCK MY MITER SAW TO LIFT THE BLADE AND ARM
If all you are trying to do is get the blade arm up so you can use the saw in the first place: Press down a bit on the entire blade arm and that will allow you to pull the locking pin to the out position -- the pin is on the left side toward the rear, smallish, and shiny silver in color... you should be able to reach out to the pin with the left hand while pressing down with the right hand.
Aug 14, 2011 | Dewalt DW715 Heavy Duty 12" Single -...
Vibration when blade on no vibration when blade off
you have a bad blade or the flanges are worn causing a runout of the blade, if you can watch the blade as it slows down you can see the wobble,
Jul 29, 2011 | Dewalt DW715 Heavy Duty 12" Single -...
How do I remove 12" blade from from dw705 miter
loosen the guard screw, UNPLUG tool first, move the guard out of the way, there is a spindle lockon the backside of the gearcase push it and slowly turn the blade until it engages and then remove the bolt, it is a left hand thread. DO NOT disassemble the guard, just loosen bolt and move out away from blade also you need to have the head in the raised position.
Oct 28, 2010 | Dewalt DW715 Heavy Duty 12" Single -...
How do you replace a broken locking pin on dewalt dw708 miterbox? thx
You do not have to drill anything out, if you are talking about the hold-down locking pin that keeps the blade assy locked down when not in use. I have created a tutorial for replacing the locking pin, you can find it here, http://mgfic.com/dewalt708_lockingpin.htm
Oct 14, 2010 | Dewalt DW715 Heavy Duty 12" Single -...
I've been using dewalt miter saw dw715 for several years and it's been working great. I just moved and today I used the saw in the new place, on an uneven concrete tiled ground. After several cuts, I...
This is common IF the blade clamping nut becomes loose... the blade will free wheel on the arbor after the motor stops. It can tear up the arbor so investigate this possibility immediately.
Feb 19, 2010 | Dewalt DW715 Heavy Duty 12" Single -...
The saw do not stop when i off the trigger
the commutator might be dirty, try and turning the brushes 180 degrees and you might have to clean the commutator with a stone for that purpose to seat the brushes.
Jan 13, 2010 | Dewalt DW715 Heavy Duty 12" Single -...
Craftsman Miter Saw - can't remove the blade
It is left hand thread and if the lock won't hold what you can try is put a 2x4 on the table and pull the head down against the wood and with a good socket and ratchet loosen it that way.. remember to tighten to loosen
Jul 20, 2009 | Dewalt DW715 Heavy Duty 12" Single -...
Change blade
OK first raise the cutting head. Loosen the screw that holds the guard in place and move out of the way. Find the spindle lock on the right hand side of the gearcase and turn blade by hand (UNPLUG SAW FIRST) until it locks. With the wrench supplied with saw put it on the blade bolt and turn it clockwise to loosen, it has left hand threads, remove outer flange and blade. Let me know it you need any more help
Jan 24, 2009 | Black & Decker DW713 10 In. In. Comp Miter...
Dewalt miter saw .
Either the blade or the guard is out of alignment. You will have to check and find out which one is the culprit.
Aug 29, 2008 | Dewalt DW715 Heavy Duty 12" Single -...
Saws Logo
91 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
