<!-- from fixya rte -->Is the 95914 digital or analog? - Computers & Internet
    New Friend:
Analog
Posted on Nov 11, 2014
What power cord does a bunker hill weatherproof color security camera model #95914 use?
This camera uses a combined power signal cable that terminates in a phone plug. Please refer to the user manual found here: http://manuals.harborfreight.com/manuals/95000-95999/95914.pdf
Dec 09, 2014 | Computers & Internet
What's the required power source for model#95914
what is the deviice is it a Harbor Freight security camera being model number 95914 ?
if it is this device on Page 6 of the user manual it states to use the correct ac/dc adapter being 120 V~ / 60 Hz Input
9 VDC /200 mA Output
http://camera.manualsonline.com/manuals/mfg/harbor_freight_tools/95914.html?p=6
be careful on 120v or 240v with the power point depending on country.
If it is a different device can you please provide more information so we can match it to whatever we dig up for you ?
Hopefully you will find on the device a lable stating its DC voltage and DC current rating.
Nov 20, 2014 | Kitchen Appliances - Others
Video matrix switch uninitialized?
Use a Hyper terminal, Hercules SETUP utility is user friendly for this. Attach a Serial cable to the unit (straight through cable not null modem) or use a USB to serial cable.
Set the Baud rate to 115200
Data size 8
Parity none
Handshake OFF
Mode Free
do not check the box for Hex
For the 12x8 digital/ analog audio matrix switch cat5 enter the command [S,M,Q]
12x8 digital/ analog audio matrix switch [S,M,L]
8x8 component video digital/ analog audio matrix switch cat5 [S,M,C]
8x8 component video digital/ analog audio matrix switch [S,M,B8]
12x8 component video matrix switch [S,M,I]
12x8 component video matrix switch cat5 [S,M,H]
8x16 digital/ analog audio matrix switch [S,M,G]
8x16 digital/ analog audio matrix switch cat5 [S,M,E]
8x16 component video matrix switch [S,M,F]
8x16 component video matrix switch cat5 [S,M,D]
12x16 component video matrix switch [S,M,J]
12x16 component video matrix switch cat5 [S,M,O]
12x16 digital/ analog audio matrix switch [S,M,K]
12x16 digital/ analog audio matrix switch cat5 [S,M,R]
Oct 31, 2013 | HDTV Supply 12x8 stackable digital/analog...
Classifications of computer
types of Computer According to Operation.
There are three basic types of computer according to their operation:
1. Analog Computers.
2. Digital Computers.
3. Hybrid Computers.
1. Analog Computers:
"Those computers which are used for measuring of physical quantities are calledAnalog Computers". Analog means variable and physical quantity always changes.
"Those computers which measured analog type of data are called Analog Computers"
These computers accept input in analog form and provide an analog output of information. It represents physical quantities like distance, velocity, acceleration and temperature. It measures continues changes in physical quantities. e.g. speedometer of a care, temperature, needle's watch for measuring the time, volt meter for measuring voltage. Now a day analog computers are using for Engineering and Scientific works. In Oil Refinery measures flow and temperature of oil. They are also used in Paper making and Chemical Industry. Out put of the analog computer is generally in the form of readings. These computers are dial in situation where data can be measure directly from measuring instrument without having to convert into numbers or codes. Now a day Analog Computers are proceed to Digital Computers. For example: Analog watch to Digital Watch, Analog Balance to Digital Balance and Analog Thermometer to Digital Thermometer etc.
2. Digital Computers:
"Those Computers which accept digital input and provides information in digital form are called Digital Computers".
"Those Computers which measure in term of digital quantity are called Digital Computers".
These computers works on the base of binary digits i.e. (0 & 1).
The results of the Digital Computers are more accurate, precise and reliable then the result of Analog Computers. Digital Computers are faster then Analog Computers. Analog Computers lack memory while Digital Computers store information.
Accounting machine and Calculator are the common example of Digital Computer.
Now a day Analog Computers are proceed to Digital Computers. For example: Analog watch to Digital Watch, Analog Balance to Digital Balance and Analog Thermometer to Digital Thermometer.
3. Hybrid Computers:
"Those Computers which accept digital inputs and provides outputs in the form of analog and vice versa".
Hybrid Computers have the characteristics of both Analog & Digital Computers. It is the computer which measures both the analog and digital quantities. It combines the both features of analog and digital computer. Hybrid Computer has process with the speed of analog and accuracy of digital computer. They are used for special purpose. These are designed to perform special task. For example ECG machine. Hybrid Computers are also used in Air Defense System. Data Communication and Transmission and in different laboratory for medicines.
Basically computer has two types according to their function.
1. Special Purpose Computers:
2. General Purpose Computers:
1. Special purpose Computers:
"Types of computers which are manufactured for specific task are called Special purpose Computers".
These computers are also known as "Dedicated Computers" because these are designed for special jobs. In other words they are designed to handle specific problems. e.g. they are used in Computer Games, Control of Traffic Lights and in Defense System. A set of instruction permanent program feed to them. As they have to perform only one job so they are very fast.
"Types of Computers which can perform all types of jobs and can run all types of programs are called General Purpose Computers".
Those computers are performing variety of jobs and use for General Purpose. For example with a personal computer a user can perform typing, can play games, can make graphics and can do arithmetic operations. General Purpose Computers are versatile but they are slow in processing and less efficient as compare to Dedicated Computers.
Classifications of Computer Classifications of Computer
Computers are classified into different categories according to their physical size, cost and speed. We can general classified them into 05 categories. (Classifications of Computer)
1. Very Small (Micro Controllers)
2. Small (Micro Computers)
3. Medium (Mini Computers)
4. Large (Mainframe)
5. Very Large (Supper Computer)
Jul 12, 2011 | Computers & Internet
How to use olympus telephone pickup tp7
Look this instructions is the same operation Comparable Models:
  • SONY ECM-TL1 Cellular, Cordless, Analog, Digital, VoIP Telephone Record Adapter
  • Olympus TP7 Cellular, Cordless, Analog, Digital, VoIP Telephone Record Adapter
  • TC-L Cellular, Cordless, Analog, Digital, VoIP Telephone Record Adapter
  • CC-10 Cellular, Cordless, Analog, Digital, VoIP Telephone Record Adapter
  • CC-20 Cellular, Cordless, Analog, Digital, VoIP Telephone Record Adapter
  • TC-W Cellular, Cordless, Analog, Digital, VoIP Telephone Record Adapter http://www.tvps.com/ecsdownloads/ECS-EBPR/ECS-EBPR-Cordless-Cellular-Telephone-Recording-Adaptor.pdf
Feb 11, 2010 | Olympus Audio Players & Recorders
After starting the computer the screen is black and only displays digital analog on screen and the blue light is flashing. It then displays a box say "check signal digital analog." please help me. Thanx.
This blue light flashing means there is power to monitor bu NO video signal. No Analog or digital Video . analog is the regular plug for PC to Monitor, the other is HDMI digital or other digital. Check signal digital/analog means again: No video signal from PC detected.
Daddy
Dec 02, 2009 | Samsung Syncmaster 940BW LCD Monitor
Analog
Seeing the word "analog" on your screen means the monitor has recognized video input on the vga "analog" input connection.
Most computers output "analog" vga (15 pin) which must be converted to digital for a flat panel monitor to display the image.
Many LCDs now have both analog and digital inputs.
Mike
May 01, 2008 | ViewSonic VP191b 19" LCD Monitor
Samsung 931B SyncmMaster
DO YOU MEAN WONT SWITCH FROM ANALOG TO DIGITAL!!!
THE ONLY WAY THIS WILL CHANGE IS IF YOU HAVE A DIGITAL INPUT SOURCE CONNECTED to this mointor like HDMI AS THIS MOINTOR AUTOMATICALLY SENSES ANALOG SIGNALS AND DIGITAL INPUT SIGNALS if a digital signal is available it will switch over if a digital input singal is not available you will only be able to use the analog option
Jan 11, 2008 | Samsung SyncMaster 930B 19" LCD Flat Panel...
Computers & Internet Logo
51 people viewed this question
David Payne
David Payne
