Question about Frigidaire Model: PHSC39EHSS
I have Frigidaire Professional model PHSC39EHSS1 side by side. The compressor wont running, the fan and light is on. It has variable speed compressor VCC3 and it has 127V AC between light blue and bla
Frigidaire Professional PHSC39EHSS1 side by side. VCC3 1156 9. Stainless Steel.
  • Frigidaire Master
  • 2,119 Answers
Schematics and parts lists and diagrams plus help. Searching Model For Search Your Way PHSC39EHSS 3
Posted on Nov 10, 2014
I have a Frigidaire gallery series fridge. The fan runs all the time and rarely turns off. The condenser kicks off and on normally and it's maintaining temperature but I don't know what it's causing the...
Hi Brandy,
As for your fans, the fans in the back of the unit, (bottom back of the unit, not inside) is called a condenser fan motor this only cools the compressor for the fridge. This fan only runs when the compressor is running. The other fan is in the freezer section and is a variable speed fans motor, this can do two different things with only one job. The fan itself can ramp up and down in speed to control air flow and temperature demand in the two sections. This can run a lot but should slow down when temperature is met or while in a defrost mode. So to sum up this answer, it is common to hear fans run in the newer unit over the older units. Believe it or not do save energy with just moving air over running the compressor all the time.
I hope this helps.
Oct 15, 2013 | Refrigerators
My frigidaire is not cooling. my fans run and my compressor tries to start every couple of minutes and runs for 5 to 10 seconds. keeps repeating this
That could be an overload unit is fault due to fatigue or the relay that need to change from start winding to run winding is fault.if not the compressor is short cycling due to less refegrant gas in the systerm.Find a leak and regas after sealing it
Aug 19, 2013 | Frigidaire Professional Series PHS68EJSB...
Frigidaire refrigerator/freezer side by side not kicking on. Both freezer and refrigerator not cooling.
If the unit is not cooling in either section of the appliance, you are experiencing some form of sealed system issue. This can include the compressor not working correctly, the evaporator fan not turning, or even coolant in the lines not at the correct levels to properly cool. If the compressor is running, humming, or even a little warm then that is typically normal. However if the compressor is running hot, then it is over working and the issue could be before the compressor in the evap fan, coil or coolant lines. Unless the unit is displaying an error code, often alpha-numeric, then you would need to contact your manufacturer and then a professional to move forward accurately.
Sep 03, 2012 | Frigidaire Refrigerators
Refrigerator Frigidaire model FRS6R5ESBY. My compressor won't turn on but I found the fan motor not working. Will the motor be the fix or is there a way to test before I spend the money?
A good test method is buy a rco-410 hard start relay. Once you have it, cut an old plug off something and leaving the plug intact, splice the two wires at the cut end with the two wires on thet really that don't have metal ends. Once that is done securly, unplug the fridgem take the really off the compressor and hook up the home made compressor tester. Once plugged in if the compressor is good it will come on, it it doesn't it's bad. This works becuase you remove any variables that are present with the machine hooked up normal.
May 31, 2012 | Frigidaire FRS3R5EMB Side by Side...
Fan moves slowly ,compressor still hot even with a portable fan blowing on condensor ,but temps are back to normal. What would cause the fan to blow slowly and there is no obsructions
Ralph78yanks,
Your condenser fan (fan motor by compressor) is a variable speed and controlled by a computer board and compressor speed. If the fan motor slows down and the compressor is running in high, the unit can over heat and cause temperature issues in refrigerator sections. GE has a program which can see actual fan RPMs of motor. As I research this incomplete model number (7 possible different models) I see they all use the same fan motor Part# WR60X10209, this is a DC motor. Make sure you fan has not melted also. The heat from the compressor can melt the should or blade when this motor fails. I hope this information helps you..
Jul 11, 2011 | GE Profile PSW26P Stainless Steel Side by...
Wont get cold
Things to check> Is there frost on the back wall of the freezer section( defrost problem)> Is the compressor running? Is the condenser fan in the rear bottom by compressor running? Is the evaporator fan (in the freezer) running?
Oct 02, 2010 | Frigidaire FRS26H5AS Side by Side...
Frigidaire Side By Side Not Cooling
That sounds like the start relay is buzzing. Unplug and lets check the compressor to see how hot and if too hot to hold your hand on the top of compressor we need to leave it unplugged until we find out if the start relay, start capacitor, overload or if the condenser fan stops after running a short while. Sea Breeze
Sep 13, 2009 | Frigidaire FRS3R5EMB Side by Side...
Compressor doesn't run
If the fan located next to the compresor works that means that the compresor relay is bad or the compresor burned out.
Jul 18, 2009 | Frigidaire FRS23R4A Side by Side...
Frigidaire FRS23H5AS side by side. condensor fan runs, no voltage to compressor
i replaced the control-defrost adaptive timer pc board after lighting storm and it worked fine for ten days then i turn off may power to my house to reground the house and my frig is doing the same thing fan not running evap freezing fan not running what is going on
Apr 08, 2008 | Frigidaire FRS23H5AS Side by Side...
Frigidaire Model: PHSC39EHSS Logo
142 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
