Question about Pool & Spa
How do you fix error code E90 in my intex spure spa pump?
I turn my pump on and the motor does not run. I get error code E90. I changed the filter and ran water through the filter spouts and it still give me error code E90.
  • Jeff Miller
    Jeff Miller May 03, 2016
    Its a bad pump. I can fix!
    majockus@citcom.net
You have an owners manual I hope, with
the codes & trouble charts
I would say call the pool & spa store & have
someone trouble shoot the problem
Posted on Nov 10, 2014
  • Jeff Miller
    majockus@citcom.net
5 Suggested Answers
  • 297 Answers
SOURCE: Where can I get a new motor for an Intex pump model 637 or 12R
first off water should not be getting to the armature area. be carefull with how you are taking care of your pump.
secondly a 1500 gallon pump is very weak I would advise at least 2500 or even the intex 4000
the most important part of pool maintenance is circulation.
if you have time check into electric motor rebuilding in your area
but sometimes that is more expensive than buying new
also if you have a valid receipt and the pump is less than 90 days old call intex and they will send out a new one within 24 hours
good luck
Posted on Jul 27, 2009
  • 351 Answers
SOURCE: This is my 3rd year using intex 8110 sytem. I
That code means the unit is in standby. It should start working if you set the opperational hours that you want in the program. Use the program guide in the manual.
Please Vote !!
Posted on Jun 02, 2010
MOTORWIZJ
  • 1383 Answers
SOURCE: Hello , I have a 5yr old pool complete with
ALWAYS FREE.. SO IT SEEMS THAT YOUR NOT GETTING AIR, THESE BLOWERS HAVE FOAM IN THEM AND CAN ,AFTER A FEW YEARS GET CRISPY AND BREAK UP AND PLUG THE AIR PUMPS SUCTION PORT. THE FOAM IS USED AS A AIR FILTER AND A NOISE REDUCER , WHEN THESE BLOWERS GO BAD 90% OF THEM CAN'T BE REPAIRED ! = JUNK.. TO SEE IF YOU HAVE A RESTRICTION IN YOUR LINE OR LINES ,USE A SHOP VAC TO **** AND BLOW THE LINES IN AND OUT.. THESE BLOWERS ARE HELD IN USUALLY WITH ONE SCREW AND ARE EASY TO REPLACE ONE MORE CHECK 4 YA IS, THERE MIGHT BE A CHECK VALVE INLINE ON THE BLOWER , IT MAY BE BAD . BEST WAY TO CHECK IS TURN THE BLOWER ON FIRST , THEN TURN THE WATER PUMP ON.. HEY IF'N I WAS OF HELP GIVE ME A REVIEW OR A THUMB.. JAY YOUR LOCAL POOL PUMP WHISPERER IN FLORIDA
Posted on Nov 16, 2010
Testimonial: "Thank you -- the 2hp motor provides air induction and bubbles. There is no foam to break off. I did blow system out , still the same. Will keep lookin"
SOURCE: Pump does not pump water
could be the capacitor blown.
Posted on Dec 30, 2012
How to fix e90 code? is there a fuse or reset button?
Question
What does code E90 mean? What should I do if code E90 appears on my air bubble spa control panel?
Answer
If alarm code E90 is displayed on the control panel, it means no water is flowing through the system. Check the attached troubleshooting guide.
Apr 04, 2016 | Intex Pool & Spa
Pump is not pumping water on intex purespa error E90, what could be the problem?
I to have run into this issue and i saw a repair using a piece of brass rod. If you open the motor cap where the impeller is located you will find the impeller guide shaft is made of a cheep piece of plastic and has broken it is a magnetic motor guided assembly and all it does is hold the impeller in the exact place. well i have found just the piece that you can fashion a quick fix from and you can find it at any hardware store. I happened to get mine from home Depot. buy a toilet handle brass lift kit paid 3.00 for it.
the larger piece is a perfect fit cut it to size and file the end of any sharp edges. works great
Apr 02, 2016 | Intex Pool & Spa
E70 and E90 error code on intex pure spa pump... what do these mean and how do I fix it?
If alarm code E90 is displayed on the control panel, it means no water is flowing through the system. Check with Intex for a repair manual ( On line and google..)
Feb 25, 2016 | Intex Pool & Spa
E90 Error,How do I fix or clear the E90 error I am getting on my spa?
What should I do if code E90 appears on - Intex ' Frequently ...
www.intexcorp.nl/faqsup/pub/FaqSupportServlet?action...
Jan 19, 2015 - What should I do if code E90 appears on my air bubble spa control panel? ... If alarm code E90 is displayed on the control panel, it means no ...
Oct 14, 2015 | Pool & Spa
How do you fix error code E90 in my intex pure spa pump? The control panel chirps and will not heat the water.
This fault code is No water flow sensed.
possible bad pump?
• Ensure the unit is plugged and switch on.• Ensure the outlet cover grid is clean and free
from obstructions.• Clean or replace the cartridge, see
Maintenance and Storage section.
• Ensure the in/outlet connections on the spa tub and filter pump are not blocked.
• If problem persists, contact Intex Service Center.
Corporate Tel # 1-800-234-6839
http://slink.intexdevelopment.com/b2cmnl/B2CMNLServlet?instantiate=B2cMnldownloadApp&action=pub_mnl&filnam=250IO_A0_1411_EN.pdf
http://www.intexcorp.com/support
Mar 21, 2015 | Intex Pool & Spa
My Intex portable spa comes up with error E98 when i turn and run. What is this and how do we fix it?
Sounds like bad news?
if you've resolved this, please comment back, and let this forum know your experience - success or : (
Use the comment link.
If your still dealing with this problem and/or for all others who need to contact Intex...
Support Intex
Feb 07, 2015 | Intex Pool & Spa
No water flow e90 fault code intex pure spa
Unplug the unit. The E90 code on the intex spa is due to a dirty water flow sensor. Remove the control panel and all the screw holding the casing on. In the white plastic piece on the discharge, top hose, you will see a silver nut with a black wire coming from it. That's the sensor. The black wire is plugged into a white wire, carefully unplug it and unscrew the sensor. Clean it good and blow out the hole it goes in. This will fix the code and you will be back in business!
Sep 27, 2013 | Intex 10x30" Metal Frame Pool w GFCI
Pool & Spa Logo
5,109 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
