Ue33 error code flashing - Televison & Video
  •  Brian Main
    Brian Main Nov 10, 2014
    Hi ian davis, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? Make and Model would be helpful.
    Top Expert:
  • Televison & ... Master
  • 74,887 Answers
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board is faulty.
Posted on Nov 10, 2014
What does a blinking orange light on 65" Mitsubishi dlp rear projection TV mean?
Self Diagnostics
The V18 Chassis features Self Diagnostics to aid in troubleshooting problems that may cause the set to
automatically turn off or "shut down." The "Timer/Power ON LED" provides an indication of the sets operation,
and the possible cause of a malfunction.
1. Initial Control Circuitry Check
Immediately after the TV is connected to an AC power source:
• The LED flashes three times ... indicating the Microprocessor has initialized and is functioning
properly.
• If the LED does not flash ... the Microprocessor is NOT functioning.
2. Error Code Operational Check
To activate the Error Code Mode, while the set is OFF, press the front panel "INPUT" and "MENU" buttons
at the same time and hold for 5 seconds. The LED will flash denoting a two digit Error Code.
Note: The Front Panel buttons must be used, NOT those on the Remote Control.
• The number of flashes indicates the value of the MSD (tens digit) of the Error Code.
• The flashing then pauses for approximately 1/2 second.
• The LED then flashes indicating the value of the LSD (ones digit) of the Error Code.
• The Error Code is repeated a total of 5 times.
Example: For Error Code is "24", the LED will flash 2 times, pause, and then flash 4 times.
3. Error Codes
The Error Code designations indicating a malfunction, or no malfunction, are listed below:
"12" ... indicates no error has occurred.
"21" ... X-Ray Protect circuit.
"22" ... Short Protect circuit.
"23" ... Horizontal Deflection failure.
"24" ... Vertical Deflection failure.
Jul 24, 2014 | Mitsubishi WS-65809 65" Rear Projection...
Tip
XBOX 360 Error Codes
There are several error codes you can get with an XBOX 360, the first step to resolving any problem is finding the root cause. The fault codes are primarily shows on the "ring" on the front of your console (this is the ring split into 4 segments that shows when controllers are connected and what player position they are).
  • 1 SEGMENT FLASHING RED - Thisindicates a displayable error code, the specific error code will bebeing displayed on the TV you have it connected too.
  • 2 SEGMENTS FLASHING RED - The console has overheated.
  • 3 SEGMENTS FLASHING RED - This is the somewhat infamous RROD (Red Ring Of Death).
  • 4 SEGMENTS FLASHING RED - AV cable not detected.
If you have 1 segment flashing red indicating a displayable specific error code then you can identify the fault from the list below.
  • E45 - Update Error.
  • E64, E65, E66 - DVD Drive Error.
  • E67, E68, E69, E79 -Hard Drive Error.
  • E71 - Update Error.
  • E72 - Unknown.
  • E73 - General Hardware Error.
  • E74 -AV cable error.
  • E76 - Unknown.
This is a basic overview of all the fault codes for the XBOX 360, for more in depth information on the faults and how to repair them please see my other tips!
Thanks!
on Mar 25, 2010 | Video Game Consoles & Games
Samsung rs2530 screen went blank except 1 lights bar flashing on freezer and wont cool
The one light flashing on the display is an error code. Depending on which light is flashing will tell you what the error code is. Check the link below to see if it has the error code. That should give you an idea of where to start.
Samsung Error Code List
Mar 16, 2012 | Samsung Refrigerators
My Mitsubishi ws a48 will not come on the timer lite blinks once then twice then goes off any help with this would be greatly appreciated i would also like to order a replacement remote for this tv it is a...
The flashes you've mentioned is a "12" error code which is no error has been detected by the processor.
Double check the error code by following the steps below.
Pressing the front panel "INPUT" and "MENU" buttons at the same time, and holding for 5 seconds,
activates the Error Code Mode.
Note: The front panel buttons must be used, NOT those on the Remote Control.
• The LED then flashes indicating the value of the *** (ones digit) of the Error Code.
Example: If the Error Code is "24", the LED will flash two times, pause, and then flash four
times.
Let me know the result.
Jdvillanueva
Aug 04, 2011 | Televison & Video
Machine stopped mid cycle and green light flashing under green start button
Many modern washing machines display error codes if they detect a fault, but not all washing machines display a readable error code, some indicate an error by flashing, or lighting some of the lights.
Hotpoint, Indesit, Zanussi error codes
Hotpoint, Indesit washing machines and Zanussi washing machines are some common appliances that display coded error codes. On their more expensive models, they display readable error codes but basic models (without digital displays) use flashing lights to convey the error fault code.
If your washing machine malfunctions and you can see some of the lights flashing, or one or more option lights have lit up, then make a note of which lights are flashing and which option lights are lit. NOTE: the error code list engineers have only shows the option lights by number and not by name. Therefore you need to report the lights as LED 1 and 3, or 2 and 4 etc. and NOT "delay timer" and "extra rinse". Count the lights from the left (or from the top if in a column) and report as "led 1 and 3" etc.
No Option lights?
With basic washing machines that have no option indicator lights, count the number of flashes. For example, the door locked indicator may flash 7 times, pause, and flash another 7 times in a constant cycle which would indicate error code 7.
This information is vital, and needs mentioning when reporting a fault.
Jan 18, 2011 | Zanussi FJS1225W Front Load Washer
Model WS55819, shut off and won't turn back on. The first few times I tried to turn it on, the indicator light came on and went off after a few seconds. Now there is nothing. I removed the panel from the...
Most common problem in WS-55819 is failure of convergence output chips and blown pico fuses in power supply section.
You need to read out error code in tv, procedure is as follows:
activates the Error Code Mode. The LED flashes denoting a two digit Error Code, or indicating no problem has occurred since the last Initialization.
Note: The front panel buttons must used, NOT those on the Remote Control.
times.
Error codes detail:
This way you can determine what section got problem in tv and causing problem.
Let me know if you need further info.
Thanks.
Dec 13, 2010 | Mitsubishi WS-55819 55" Rear Projection...
E25
hello,
All error codes start with the letter "E". An error code of E11 will have the five indicator lights flash once and the Start indicator light flash once.
Some models of Frigidaire washers come with a digital readout display that informs the operator of the unit's function and any errors.
Error codes indicate that a problem has occurred and should be addressed. Different models of Frigidaire washers may vary in their fault displays.
Some washer models use flashing lights at the unit's start, door lock, wash, rinse, final spin and control indicators to display error codes.
If the five indica
tor lights flash more than nine times, this signals a letter in the error code. The letter "A" stands for 10 flashes, "B" for 11, "C" for 12, "D" for 13, "E" for 14 and "F" for 15 flashes. An error code of EB2 will have the five indicator lights flash or blink 11 times, and the Start indicator light blink twice
hope this help?
thanks.
Oct 23, 2010 | Dishwashers
Green light flashes, will not print. Checked all
Hi can gave you the truble codes
  • Light Orange - 2 beeps: Remove any paper jammed
  • Light Orange - 3 beeps: Remove any paper jammed
  • Light Orange - 4 beeps: Add Ink
  • Light Orange - 5 beeps: Re-install cartridge or replace it
  • Light Orange - 6 beeps: Re-install cartridge or replace it
  • Light Orange - 7 beeps: Re-install cartridge or replace it
  • Light Orange - 8 beeps: Waste is almost full
  • Flash 1 x Orange - 10 beeps (error code 6100): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 2 x Orange - 10 beeps (error code 6300): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 3 x Orange - 10 beeps (error code 6800): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 4 x Orange - 10 beeps (error code 5100): Make sure nothing is blocking the cartridge movement, if not requires service.
  • Flash 5 x Orange - 10 beeps (error code 5400): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 6 x Orange - 10 beeps (error code 5B00): Waste full (make a reset)
  • Flash 7 x Orange - 10 beeps (error code 5200): Replace the BJ Cartridge(Printhead)
  • Flash 8 x Orange - 10 beeps (error code 5200): Replace the BJ Cartridge(Printhead)
  • Flash 9 x Orange - 10 beeps (error code 5600): Replace the BJ Cartridge(Printhead) or reinstall it
  • Feb 01, 2010 | Canon BJC 4400 InkJet Printer
    Tv says airflow restriction tv will turn off. there is no airlfow restriction
    I did not find a reference to airflow restriction in the service manual.
    I don't know if this will help, but here are the error codes:
    The TV must be in “Shut Down” and not manually switched Off, to perform the Error Code Operational
    Check. When the TV is switched Off, the code automatically resets to “12” No Error.
    Press the front panel “DEVICE” and “MENU” buttons at the same time, and hold for 5 seconds to
    activate the Error Code Operational Check. The LED will then flash denoting a two digit Code.
    Example: If the Error Code is “32”, the LED will flash three times, pause, and then flash two times.
    4. Error Codes
    The Error Code designations are listed below:
    Error Code Probable Cause
    12 No error detected
    22 Recovery from momentary Reset
    32 Lamp Cover open
    33 Air Filter Cover open
    34 Lamp abnormality
    35 Chassis Fan failure
    36 Exhaust (Back Cover) or Lamp Ballast Fan failure
    37 Engine (DMD or Lamp) Fan failure
    38 Excess Lamp Temperature
    39 Excess DMD Temperature
    41 Short Detected
    44 DVI Cable (between Chassis and Engine) disconnected
    Oct 20, 2009 | Mitsubishi WD-62525 62" Rear Projection...
    Both lights are blinking and will not print
    they call that flash codes or error codes. please count
    count how many times the lights flash, here is what they mean
    Alarm / Power light flashes orange 7 times consecutively (ink cartridge installed incorrectly)
    Alarm / Power light flashes orange 5 times consecutively (Print Head Error)
    Alarm / Power light flashes orange 4 times consecutively (Out of Ink Error)
    Alarm / Power light flashes orange 3 times consecutively (Paper Jam Error / Cover Error)
    Alarm / Power light flashes orange 2 times consecutively (Load Paper / Paper Feed Error)
    Alarm / Power light flashes orange 16 times consecutively (This FINE Cartridge has previously been used)
    Alarm / Power light flashes orange 15 times consecutively (FINE cartridge not recognized)
    Sep 20, 2009 | Canon Pixma iP2600 Photo InkJet Printer
    Televison & Video Logo
    52 people viewed this question
    Top Televison & Video Experts
